| | Sound problem with intel Desktop Board D945GPM and Vista Home prem Have two sound problems one minor and one major. Minor: I am on dial up and when I dial up no sound of dialing. Major: Cannot record sound. In contro panel -Sound- recording it states that no recording devices are installed yet it is built in the motherboard and used to work in XP. Any advise on how to get and install drives to correct the problem. Nine in windows update. Thanks John W |
| | Re: Sound problem with intel Desktop Board D945GPM and Vista Home prem The latest audio driver for Vista on Intel Desktop Board D945GPM appears to be here: http://downloadcenter.intel.com/filt...4&submit=Go%21 You may also have to right-click the Sound icon in the notification area, and choose Recording Devices. On the Recording tab of Sound, right-click an empty spot of the window, and put a checkmark next to "Show Disabled Devices" and "Show Disconnected Devices". "goldens" <goldens@discussions.microsoft.com> wrote in message news:9AB987F5-E3A8-469D-9B4A-5ED5635974A0@microsoft.com... > Have two sound problems one minor and one major. > Minor: > I am on dial up and when I dial up no sound of dialing. > Major: > Cannot record sound. In contro panel -Sound- recording it states that no > recording devices are installed yet it is built in the motherboard and > used > to work in XP. Any advise on how to get and install drives to correct the > problem. Nine in windows update. > Thanks > John W |
| | Re: Sound problem with intel Desktop Board D945GPM and Vista Home "dean-dean" wrote: > The latest audio driver for Vista on Intel Desktop Board D945GPM appears to > be here: > > http://downloadcenter.intel.com/filt...4&submit=Go%21 > > You may also have to right-click the Sound icon in the notification area, > and choose Recording Devices. On the Recording tab of Sound, right-click an > empty spot of the window, and put a checkmark next to "Show Disabled > Devices" and "Show Disconnected Devices". > > "goldens" <goldens@discussions.microsoft.com> wrote in message > news:9AB987F5-E3A8-469D-9B4A-5ED5635974A0@microsoft.com... > > Have two sound problems one minor and one major. > > Minor: > > I am on dial up and when I dial up no sound of dialing. > > Major: > > Cannot record sound. In contro panel -Sound- recording it states that no > > recording devices are installed yet it is built in the motherboard and > > used > > to work in XP. Any advise on how to get and install drives to correct the > > problem. Nine in windows update. > > Thanks > > John W > > |
| | Re: Sound problem with intel Desktop Board D945GPM and Vista Home Thanks Dean, I did download the latest drivers from intel along with a bios update and the sound recording works. For some reason the installiation took out three programs which I had to reload but now vista is working fine except for the minor problem of no dial sound when the modem is dialing. I had such a problem installing Vista that I think I will leave the vista upgrade for my dell lap top in the box and keep using Windows Xp on the Dell. "dean-dean" wrote: > The latest audio driver for Vista on Intel Desktop Board D945GPM appears to > be here: > > http://downloadcenter.intel.com/filt...4&submit=Go%21 > > You may also have to right-click the Sound icon in the notification area, > and choose Recording Devices. On the Recording tab of Sound, right-click an > empty spot of the window, and put a checkmark next to "Show Disabled > Devices" and "Show Disconnected Devices". > > "goldens" <goldens@discussions.microsoft.com> wrote in message > news:9AB987F5-E3A8-469D-9B4A-5ED5635974A0@microsoft.com... > > Have two sound problems one minor and one major. > > Minor: > > I am on dial up and when I dial up no sound of dialing. > > Major: > > Cannot record sound. In contro panel -Sound- recording it states that no > > recording devices are installed yet it is built in the motherboard and > > used > > to work in XP. Any advise on how to get and install drives to correct the > > problem. Nine in windows update. > > Thanks > > John W > > |
| | Re: Sound problem with intel Desktop Board D945GPM and Vista Home I'm glad to hear your sound recording is working. Your dialing sound, I think, is a function of the Modem driver, which you may also have to find a Vista compatible driver for, from the manufacturer. You may have already done this, but in Device Mangager, double-click on the device under Modems, and check to see if it has a volume control on one of the tabs. "goldens" <goldens@discussions.microsoft.com> wrote in message news:97059E3F-E822-4968-8A95-15CD7448C197@microsoft.com... > Thanks Dean, > I did download the latest drivers from intel along with a bios update > and the sound recording works. For some reason the installiation took out > three programs which I had to reload but now vista is working fine except > for > the minor problem of no dial sound when the modem is dialing. I had such a > problem installing Vista that I think I will leave the vista upgrade for > my > dell lap top in the box and keep using Windows Xp on the Dell. > > "dean-dean" wrote: > >> The latest audio driver for Vista on Intel Desktop Board D945GPM appears >> to >> be here: >> >> http://downloadcenter.intel.com/filt...4&submit=Go%21 >> >> You may also have to right-click the Sound icon in the notification area, >> and choose Recording Devices. On the Recording tab of Sound, right-click >> an >> empty spot of the window, and put a checkmark next to "Show Disabled >> Devices" and "Show Disconnected Devices". >> >> "goldens" <goldens@discussions.microsoft.com> wrote in message >> news:9AB987F5-E3A8-469D-9B4A-5ED5635974A0@microsoft.com... >> > Have two sound problems one minor and one major. >> > Minor: >> > I am on dial up and when I dial up no sound of dialing. >> > Major: >> > Cannot record sound. In contro panel -Sound- recording it states that >> > no >> > recording devices are installed yet it is built in the motherboard and >> > used >> > to work in XP. Any advise on how to get and install drives to correct >> > the >> > problem. Nine in windows update. >> > Thanks >> > John W >> >> |
| Possible 2 factory reset a Medion desktop pc that has vista home prem OS, w/o a disk? | General Discussion | |||
| Vista 64 Home Prem. jumps to desktop while playing WoW. | Vista Games | |||
| Vista Home Prem. Problem -- anyone seen this?? | Vista performance & maintenance | |||
| Intel on-board sound not working | Vista hardware & devices | |||
| 5.1 sound problem with Realtek ACL655 on board sound | Vista hardware & devices | |||
