Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista Tutorial - 32bit AND 64bit Vista Ultimate? (Dual Boot Activation problems)
Old 07-21-2007   #1 (permalink)
Dan Ulrich
Guest
Running XP Pro and bought Vista Ultimate. I have setup XP, 32bit & 64bit
vista on 3 seperate partitions. I would like to see if I can get all my
Hardware working in 64bit, and see what the benifets are vs 32bit version.
(Intel 6600 w/4GB Ram)
I installed and configured 64bit first and have activiated the product using
the Key on the package. When I booted into 32bit and tried to activate it,
I get "The product key you typed is already in use".
I am pretty sure I will stick with 32bit, but was hoping to see over time if
64bit was what I wanted to use, and if all the drivers work. Can I not
active both my Vista copies? If I need to remove 1 copy, then, can I remove
the 64bit partition and just stick with XP and Vista 32 bit, or will trying
to remove it cause boot up issues?
Any links or pointers to how to do this would be great.
Old 07-22-2007   #2 (permalink)
Andrew McLaren
Guest
Re: 32bit AND 64bit Vista Ultimate? (Dual Boot Activation problems)
"Dan Ulrich" <DanUlrich@MSN.COM> wrote ...
> using the Key on the package. When I booted into 32bit and tried to
> activate it, I get "The product key you typed is already in use".
Hi Dan,
Yes, unfortunately this is how activation works in Vista. The second
instance of Windows, installed on a separate partition, asks to be activated
after it is first started. So far, so good. But when you go to activate,
Activation calculates an unique ID for the hardware, which is derived from
several factors including the identity of the drive it was booted from. Even
though Windows is booting from the same physical box, it is booting on a
different partition; so Activation calculates a different hardware ID for
that instance of Windows. Thus it thinks that it is on a different machine;
and says, No this Windows is already in use.
Personally I think this is a poor design on Microsoft's part - you should be
able to boot any number of instances of a Windows licence on the same
physical box, without penalty. Although, in fairness to Microsoft, they
probably didn't plan it this way deliberately. I suspect the Program
Managers in the Activation team just don't realise how common it is to dual
boot; so it's a kind of unintended side-effect of anti-piracy.
You can continue to use Windows for up to 30 days, without Activation. Most
things continue to work normally during that time. So one solution would be
to simply not activate, until you've decided whether to go 32 bit or 64
bit.Less than perfect, but it may be a solution.
Andrew McLaren
amclar (at) optusnet dot com dot au
Dual Boot - Vista 64bit and Vista 32bit - How? General Discussion
I have dual boot PC [VISTA 32BIT & 64BIT]---problems only in 64bit vista drivers Drivers
Vista 64bit or 32bit, or Dual Boot? Vista installation & setup
Dual Boot 32bit 64bit vista Vista installation & setup
installing into a 32bit and 64bit Dual Boot harddrive Vista installation & setup
