Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Installation freeze/ Very weird problem.
LinkBack Thread Tools Display Modes
Old 08-04-2007   #1 (permalink)
Tom VL
Guest
Hello,
I'm having problems with the Windows Vista installation.
Every time I try to start the installation when my computer's starts the
setup freezes when the loading bar with the green moving blocks come up. When
that happens I reset my computer again and again, and eventually it will come
to a point where it takes me into the installation.
Even then it literally takes 12 minutes to load up the first screen, when
you have to select your language, etc.. and the time in between the next
couple of screens takes that long as well.
When it comes to the point where my installation tells me it's about to
reset the computer, everything happens all over again. It freezes again when
the loading bar comes up (each time it freezes at a random time). Then after
resetting a couple of times it takes me to the completing installation
screen, then it freezes again and so I have to reset a couple of times.
Then it finally takes me into the OS, but tells me I have to reinstall Vista
because something went wrong.
I have tried the following solutions:
-Reburning the dvd at 1x AND 2x speed.
-Tried an OEM edition of Ultimate.
-Installing XP first then installing vista onto another partition.
-Installing XP first then installing vista through the image mounting
solution.
-Installing XP first then installing vista by upgrading.
-Used 2GB of Ram instead of 4GB.
Here are my computer's specifications.
-Core 2 Quad (Q6600)
-MSI P965 NEO-F
- 4 GB DDR2 800
-XFX Geforce 8800 GTX
- 1 Maxtor Sata2 Hard drive (160GB)
- 1 Sata dvd+-r writer
- 630 Watts PSU
Is anyone able to help me please?
Thanks,
Tom.
Old 08-04-2007   #2 (permalink)
Chad Harris
Guest
Re: Installation freeze/ Very weird problem.
Hi Tom--
I'm a little confused. Vista's installation setup is going to reboot a few
times--I don't remember exactly how many but you will see that loading bar
with the green moving blocks come up more than once during setup. Once you
have installed Vista, that loading bar means the kernel has loaded among
other things.
If you're selecting language, etc. you haven't completed the install
obviously.
It tells you to reload the OS because precisely what does it say? It
doesn't just say "something went wrong."
You're always strongly advised to install XP first if you're doing a dual
boot and it seems like that's what you're trying to do. You need to put
Vista on another partition or drive.
I'm sure you've done this but I'd clean the DVD. Knowing the exact setup
error could help us help you.
Good luck,
CH
"Tom VL" <Tom VL@discussions.microsoft.com> wrote in message
news:27376436-A9C0-469C-9A35-28D55967FA3B@microsoft.com...
> Hello,
> When
> come
> when
> after
> Vista
> solution.
> -MSI P965 NEO-F
> - 4 GB DDR2 800
> - 630 Watts PSU
> Thanks,
> Tom.
Old 08-05-2007   #3 (permalink)
lysander
Guest
RE: Installation freeze/ Very weird problem.
This is a very long shot but as you are dealing with a PC which I presume has
been in use for some time, I had similar problems some time back. The
culprit astonishingly was a Smartcard reader which I used to permanently
leave plugged into a USB port. Removed that and the loading returned to
normal speed. It used to take literally ten minutes to load between
functions if I left that device attached - but not every time which did not
help diagnosing the cause.
"Tom VL" wrote:
> Hello,
> solution.
> -MSI P965 NEO-F
> - 4 GB DDR2 800
> - 630 Watts PSU
> Thanks,
> Tom.
Old 08-05-2007   #4 (permalink)
Tom VL
Guest
Hello again,
Indeed the setup tells me it has to reboot a couple of times.
Then everything happens again, as in the freezing happens again.
The setup does not start over again.
Basically it restarts my pc.
It gets to the part where it loads in the kernel. Freeze, I reset
This time it will either; freeze when it's loading the kernel or freeze when
it says "Please wait while windows is loading for the first time". I reset,
again.
Then it takes me beyond the "Please wait while windows is loading for the
first time" screen again it takes me into Vista, where it tells me the
installation failed and that I should reinstall Vista.
I had no error screens popping up so everything should be alright. I think
it's because of the freezing and resetting that the installation get's
screwed up?
If this is still unclear, I could try to record it with my digital camera
and post a link.
Thanks again,
Tom
Old 08-05-2007   #5 (permalink)
Tom VL
Guest
Hello,
I have bought my pc 3 days ago to be exact.
Hope that clears that up.
--Tom
> "Tom VL" wrote:
> > Hello,
> > solution.
> > -MSI P965 NEO-F
> > - 4 GB DDR2 800
> > - 630 Watts PSU
> > Thanks,
> > Tom.
Old 08-05-2007   #6 (permalink)
John Barnes
Guest
Vista doesn't load the kernel. Vista has a new procedure where it lays down
a clean IMAGE of the entire system. You don't say if you are doing an
upgrade from another system or a custom install of a full version and
whether you are trying x86 or x64. When you say freeze, are you getting
anxious or how do you know it is frozen? Vista takes a lot longer to
install than XP and maybe you aren't letting it proceed before you assume it
is frozen. Upgrades can take hours. Custom installs can take up to an hour
+ depending on the speed of the processor and memory.
"Tom VL" <TomVL@discussions.microsoft.com> wrote in message
news:242210DA-3F69-49DB-822A-C35E9FF60897@microsoft.com...
> Hello again,
> when
> reset,
> again.
> screwed up?
> and post a link.
> Thanks again,
> Tom
Old 08-05-2007   #7 (permalink)
Chad Harris
Guest
John--
My statement was:
"Once you have installed Vista, that loading bar means the kernel has
loaded among
other things." Vista contains Ntoskrnl.exe located in C:\Windows\System32.
CH
"John Barnes" <jbarnes@email.net> wrote in message
news:OZ5v1$11HHA.2064@TK2MSFTNGP03.phx.gbl...
> down a clean IMAGE of the entire system. You don't say if you are doing
> an upgrade from another system or a custom install of a full version and
> it is frozen. Upgrades can take hours. Custom installs can take up to an
> hour + depending on the speed of the processor and memory.
>> Hello again,
>> when
>> reset,
>> again.
>> think
>> screwed up?
>> and post a link.
>> Thanks again,
>> Tom
Old 08-07-2007   #8 (permalink)
cquirke (MVP Windows shell/user)
Guest
On Sat, 4 Aug 2007 16:24:01 -0700, Tom VL <Tom
You sound like someone sawing off their limbs one by one, and
wondering why it hurts. I'd stop trying to run Windows on what is
clearly a sick PC, and re-establish my assumptions from hardware up:
- test RAM, eyeball motherboard capacitors etc.
- test physical HD (NOT USING CHKDSK /R)
- test file system, evacuate data before "fixing"
- formally manage malware
- only then, attempt to run Windows
At this point, you'll realize that Windows is like buying a car that
has the hood welded shut and no spare tyre; works great, but as soon
as it needs maintenance, you find the tool cupboard is bare.
Well, nearly bare; if you have a proper Vista DVD (as opposed to
Dubious Advantage royalty-OEM drekage), you at least have a dangerous
RAM tester and HD "fixer", and some chance of running malware
management tools formally (i.e. without running the infected OS).
To test RAM, you can go to a PC that doesn't suck, download the free
MemTest86, and run that to make a boot CDR. Then go back to the sick
PC and leave that CDR running for, say, 24 hours. After 24 hours, you
will see one of the following:
- RAM errors
- a locked up PC
- test still running, but wall time is < 24 hours due to PC resets
- test still running, wall time is 24 hours as expected, no errors
Only the last result is acceptable, allowing you to do the next step.
As I mentioned, you can also boot the Vista DVD and use that to test
the RAM, but it's a riskier process:
- test writes to HD, runs on next (HD) boot
- test is short, unless you override the defaults for 24 hours
- test results displayed on screen may not be cumulative
- tester writes results to the HD
- to see results, you have to boot the OS to reach Event Viewer
The last thing you want to do when RAM is bad, is access the HD at
all. Read operations can bit-flip to writes, sectors can be written
to the wrong locations, trashing the file system, etc.
To test the HD, I would use HD Tune from www.hdtune.com, which is
free, very thorough (full SMART details, surface scan) and safe (it
doesn't try to "fix" anything, though the HD itself might).
HD Tune is a Windows-based tool, and as we discussed earlier, you do
NOT want to run Windows yet (every Windows session writes to the HD,
and bad exits leave this corrupted even if whatever is wrong with the
PC hasn't already corrupted the HD).
However, if you know someone with Windows XP SP2 or Server 2003, you
can download Bart PE Builder, integrate HD Tune as a plug-in, build a
Bart CDR, boot your sick PC from this, and run HD Tune from there.
Unfortunately, HD Tune will not run from WinPE 2.0 or Vista DVD boot.
I've bugged this to MS, but they won't fix it; I guess they can't see
why we'd want to check HDs without "fixing" them.
So you can look for similar tools, and at this point someone will
mention tools from the HD vendor. These tools may be safe, in that
they may run from CDR boot, but they may also be skimpy. Suspect this
if the "full" test takes only a few minutes to run - you may find they
merely report the SMART summary, which is nearly always "OK" until the
HD is not only dying, but has multiple bits rotting off.
Last, there's ChkDsk /R, which will scan the surface of the HD and
"fix" bad clusters, having first "fixed" the file system on the "sick
HD that it hasn't tested yet. Wrong priorities; test the physical
first, ABORT without "fixing", evacuate contents, and only then you
can pretend to "fix" what is physically broken, just for laffs.
Nature's trying to tell you something. Listen up ;-)
DON'T do that either.
<destructive crater-digging snipped>
>-MSI P965 NEO-F
>- 4 GB DDR2 800
>- 630 Watts PSU
As above. Looks like new hardware, which could be on the steep part
of the failure curve (as in, "defective manufacture, not caught by
pre-sale testing"). Err... are you overclocking?
Nice kit, tho. Are you on Vista64 or Vista32? I ask, due to the 4G
RAM that wouldn't be fully addressable by Vista32. I'd prolly rather
go with Vista32 and less RAM, myself.
Shame about the piddly little Maxtor... is that carried over from a
previous PC, or do you really have an application that needs heroic
processor and RAM and never touches the HD, so the small cost of
doubling capacity and halving head travel is not worthwhile?
Who is General Failure and
why is he reading my disk?
Display Modes
Vista Crash/Freeze from fresh installation -_-;; Koopa Vista General 6 03-29-2008 08:30 PM
Installation Freeze goforthd Vista installation & setup 1 05-08-2007 02:27 PM
Vista Installation freeze up issue a major problem for Microsoft.. The CAT Vista installation & setup 2 03-05-2007 03:30 PM
Vista Installation Freeze Sparky Vista installation & setup 4 02-03-2007 09:53 AM
After setting SN will freeze over installation Peri Vista General 0 06-12-2006 12:30 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
