Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Problems With the Installation System in Vista
LinkBack Thread Tools Display Modes
Old 08-06-2007   #1 (permalink)
Roger Stenson
Guest
Hi I have recently had various components upgraded on my Vista Ulitmate
desktop by a computer Service Point, mostly graphics and audio hardware
On return VB6/ SP6 wont run. It says it is preparing to install. If I let it
run after a very long 'eventually' it gives me a message saying my install
server is not running
It was running perfectly before I took it in
I have restored the machine to the point before it went to be serviced. It
still had the problem
I have successfully reinstalled VB6 with SP 6. It still has the problem
I have no idea what to consider next and would be very grateful for some
advice
Roger Stenson
Display Modes
Vista Windows installation system Frederick Vista installation & setup 0 08-22-2008 01:20 PM
System crash during Vista Home Premium 64 installation JEFF Vista installation & setup 9 10-27-2007 05:33 PM
install vista on 2nd HDD ... installation can't change system driv culnaes Vista installation & setup 1 10-16-2006 12:07 PM
Installation/Running period problems, check my system for known in Wisgary Vista hardware & devices 3 06-20-2006 10:21 PM
Installation/Running period problems, check my system for known in Wisgary Vista hardware & devices 0 06-20-2006 09:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
