| | Multi-boot setup process does not work as advertised in FAQs Your FAQs tell how to multiboot install but doesn't tell you how to clear a jam. When I install Vista on another partititon, I get a message at end of install: "Windows Cannot Upgrade Boot Configuration. Installation Cannot Proceed." If I install Vista on the main partition overwriting XP, I can install. But then I lose Windows XP. Please update your records as to inform users how to work around this OS limitation. -- Those willing to sacrifice freedom for safety are deprived both freedom and safety... ---------------- This post is a suggestion for Microsoft, and Microsoft responds to the suggestions with the most votes. To vote for this suggestion, click the "I Agree" button in the message pane. If you do not see the button, follow this link to open the suggestion in the Microsoft Web-based Newsreader and then click "I Agree" in the message pane. http://windowshelp.microsoft.com/com...allation_setup |
| | RE: Multi-boot setup process does not work as advertised in FAQs http://www.vistabootpro.org/ "Aymincendiary" wrote: > Your FAQs tell how to multiboot install but doesn't tell you how to clear a > jam. > > When I install Vista on another partititon, I get a message at end of install: > > "Windows Cannot Upgrade Boot Configuration. Installation Cannot Proceed." > > If I install Vista on the main partition overwriting XP, I can install. But > then I lose Windows XP. > > Please update your records as to inform users how to work around this OS > limitation. > -- > Those willing to sacrifice freedom for safety are deprived both freedom and > safety... > > ---------------- > This post is a suggestion for Microsoft, and Microsoft responds to the > suggestions with the most votes. To vote for this suggestion, click the "I > Agree" button in the message pane. If you do not see the button, follow this > link to open the suggestion in the Microsoft Web-based Newsreader and then > click "I Agree" in the message pane. > > http://windowshelp.microsoft.com/com...allation_setup |
| | RE: Multi-boot setup process does not work as advertised in FAQs I appreciate the link for the editing application. To work, I would need a successful install of Vista. I'm not getting that with the current XP install on my computer, even though it is on a separate partiton. The problem lies with that particular install of XP. Once it's gone, Vista installs fine. However, I still need XP with all my apps. The editing program isn't needed then if I take XP out of the equation. I have an email session going with tech support at MS. I'd like to see what he has to say about this one. I sent all my computer's configuration when I initiated the support session so he/she can wade thru the boot.ini and the system partition and see what's going on. No one has ever reported this particular error when it comes to a multiboot setup (WINDOWS CANNOT UPDATE BOOT CONFIGURATION. SETUP CANNOT PROCEED). FYI, RC2 did not have this problem. Thanks! Chris -- Those willing to sacrifice freedom for safety are deprived both freedom and safety... "Mick Murphy" wrote: Quote: > http://www.vistabootpro.org/ > > "Aymincendiary" wrote: > Quote: > > Your FAQs tell how to multiboot install but doesn't tell you how to clear a > > jam. > > > > When I install Vista on another partititon, I get a message at end of install: > > > > "Windows Cannot Upgrade Boot Configuration. Installation Cannot Proceed." > > > > If I install Vista on the main partition overwriting XP, I can install. But > > then I lose Windows XP. > > > > Please update your records as to inform users how to work around this OS > > limitation. > > -- > > Those willing to sacrifice freedom for safety are deprived both freedom and > > safety... > > > > ---------------- > > This post is a suggestion for Microsoft, and Microsoft responds to the > > suggestions with the most votes. To vote for this suggestion, click the "I > > Agree" button in the message pane. If you do not see the button, follow this > > link to open the suggestion in the Microsoft Web-based Newsreader and then > > click "I Agree" in the message pane. > > > > http://windowshelp.microsoft.com/com...allation_setup |
| | Re: Multi-boot setup process does not work as advertised in FAQs Aymincendiary wrote: Quote: > I appreciate the link for the editing application. > > To work, I would need a successful install of Vista. I'm not getting that > with the current XP install on my computer, even though it is on a separate > partiton. > > The problem lies with that particular install of XP. Once it's gone, Vista > installs fine. However, I still need XP with all my apps. The editing program > isn't needed then if I take XP out of the equation. > > I have an email session going with tech support at MS. I'd like to see what > he has to say about this one. I sent all my computer's configuration when I > initiated the support session so he/she can wade thru the boot.ini and the > system partition and see what's going on. No one has ever reported this > particular error when it comes to a multiboot setup (WINDOWS CANNOT UPDATE > BOOT CONFIGURATION. SETUP CANNOT PROCEED). > > FYI, RC2 did not have this problem. GoBack? Some sort of security program that would prevent changes? That's what it sounds like. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: Multi-boot setup process does not work as advertised in FAQs I'll give it a look and get back to you. Thanks! -- Those willing to sacrifice freedom for safety are deprived both freedom and safety... "Malke" wrote: Quote: > Aymincendiary wrote: Quote: > > I appreciate the link for the editing application. > > > > To work, I would need a successful install of Vista. I'm not getting that > > with the current XP install on my computer, even though it is on a separate > > partiton. > > > > The problem lies with that particular install of XP. Once it's gone, Vista > > installs fine. However, I still need XP with all my apps. The editing program > > isn't needed then if I take XP out of the equation. > > > > I have an email session going with tech support at MS. I'd like to see what > > he has to say about this one. I sent all my computer's configuration when I > > initiated the support session so he/she can wade thru the boot.ini and the > > system partition and see what's going on. No one has ever reported this > > particular error when it comes to a multiboot setup (WINDOWS CANNOT UPDATE > > BOOT CONFIGURATION. SETUP CANNOT PROCEED). > > > > FYI, RC2 did not have this problem. > Do you have some program installed in XP "protecting" the mbr such as > GoBack? Some sort of security program that would prevent changes? That's > what it sounds like. > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| | #6 (permalink) |
| | Re: Multi-boot setup process does not work as advertised in FAQs You don't provide the information necessary to help. A complete description of your HD(s) would be a good start. drive number 0 Partition 1, System,primary,active, etc, Partition 2 etc. drive number 1, etc "Aymincendiary" <zbar2005@xxxxxx> wrote in message news:E937D63C-D8C9-4286-94F2-EA765692320C@xxxxxx Quote: > Your FAQs tell how to multiboot install but doesn't tell you how to clear > a > jam. > > When I install Vista on another partititon, I get a message at end of > install: > > "Windows Cannot Upgrade Boot Configuration. Installation Cannot Proceed." > > If I install Vista on the main partition overwriting XP, I can install. > But > then I lose Windows XP. > > Please update your records as to inform users how to work around this OS > limitation. > -- > Those willing to sacrifice freedom for safety are deprived both freedom > and > safety... > > ---------------- > This post is a suggestion for Microsoft, and Microsoft responds to the > suggestions with the most votes. To vote for this suggestion, click the "I > Agree" button in the message pane. If you do not see the button, follow > this > link to open the suggestion in the Microsoft Web-based Newsreader and then > click "I Agree" in the message pane. > > http://windowshelp.microsoft.com/com...allation_setup |
| Advertised Shortcuts in a setup and deployment project | .NET General | |||
| Out-File -Force doesn't seem to work as advertised | PowerShell | |||
| Setup Configuration for Multi-boot | Vista installation & setup | |||
| The multi-desktop kludge for process isolation | Vista security | |||
| Multi boot setup with XP and Vista | Vista installation & setup | |||
