| | Enable one click instead of double click selection Please help...I cannot find the place where you check the box to enable one click selection instead of having to double click. Thanks so much for any help you can give me. |
| | Re: Enable one click instead of double click selection Start>Control panel>Folder options>General tab "genie616" <genie616@xxxxxx> wrote in message news:8D9D3CEE-64A5-445D-9F96-E2BBE2C658F2@xxxxxx Quote: > Please help...I cannot find the place where you check the box to enable > one > click selection instead of having to double click. > > Thanks so much for any help you can give me. |
| double click? | Vista General | |||
| Mouse Double-Click | Vista hardware & devices | |||
| Single Click Instead Of Double Click | Vista General | |||
| No double click | Vista General | |||
| hot to change mouse to single click instead of double click to ope | Vista hardware & devices | |||
