Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Problems using external T.V as external second monitor vai S-Video
Old 09-23-2007   #1 (permalink)
Temet Nosce
Hello, Any help would be appreciated (not with spelling though). I am using a
Sony VAIO VGN-AR41L with Windows home vista. I have connected a T.V vai
S-Video and used the set up process in Control Panel Mobile Pc, and in Nvidia
control panel for the second monitor to act as an extension of my desk top.
This works fine untill i run another application on my laptop desktop. If i
start a game (Battlefield 2 SF) and have a movie/visulistion window or
explorer Tab.open in the other screen (2) it gets moved over to the far right
of (2) and off the screen. If i touch it with mouse pointer to drag it over
my game minimise's to taskbar on (1) and the external application resumes. If
i start with the application running between both screens and start the game
on (1) the tile application Tab that was running between the two screens is
the centred in (2). I've tried adjusting screen size in setup e.t.c, and have
tried to use windows help but no luck in resolvung this problem.
Old 09-23-2007   #2 (permalink)
JW
Re: Problems using external T.V as external second monitor vai S-Video
Normally S-Video has problems with any resolution higher then 800x600 some
S-Video connections can handle 1024x7868.
If your game is using a higher resolution this is probably what is causing
the problem.
"Temet Nosce" <TemetNosce@xxxxxx> wrote in message
news:B74E5E70-7C3F-4EBB-8F09-A9C29CC8C2D0@xxxxxx
> using a
> Nvidia
> top.
> i
> right
> over
> If
> game
> is
> have
External monitor display Vista hardware & devices
KVM with External Monitor Vista General
working with an external monitor Vista music pictures video
External monitor Vista General
External LCD Monitor has no red color Vista General
