Go Back   Vista Forums > Vista Newsgroups > Vista installation & setup
Vista - Is OPK required for individual system builder?
Old 10-11-2007   #1 (permalink)
Jim Horvath
I bought a motherboard, processor, memory, hard drive, chassis, etc. and
assembled my own system. I have now purchased an OEM license for Vista
Home Premium and wish to do a clean install on this system.
I understand that the OEM license will be irrevocably tied to this
system, and that I am responsible for my own "customer support".
My question is whether I am truly required to pre-install Vista using
the OEM pre-installation kit as is stated on the System Builder 1 pack
box (I have not yet broken the seal on the box). The OPK is not included
in the box, and I have not registered with MS as a "System Builder" to
download it as I am just building this computer for myself.
Can't I just install directly from the enclosed DVD as I have all
previous versions of Windows? Would this violate the OEM license?
Jim Horvath
Old 10-11-2007   #2 (permalink)
Carey Frisch [MVP]
Re: Is OPK required for individual system builder?
Just install Windows Vista normally.
Carey Frisch
Microsoft MVP
Windows Shell/User
"Jim Horvath" <not_here@xxxxxx_spam.org> wrote in message news:%23D3kl0DDIHA.4196@xxxxxx
Jim Horvath
Old 10-11-2007   #3 (permalink)
JRB Associates
Jim,
If you were to distribute the PC to anyone else, then the OPK is required to
brand the PC, marking you as the system builder. This is so that the final
end user will know who to contact for support. It also assists in
configuring the PC so that the final end user is presented with the license
screen (OOBE) to accept prior to use.
Since you will be the final end user, and provide your own support, then
nobody will say anything to you if you just install it.
John Baker
How To Create System Builder Image? Software
RE: Replacing System Builder software? Vista General
OEM system builder pack? Vista General
OEM system builder pack Vista General
64 Bit System Builder key on 32 Bit? Vista General
