Go Back   Vista Forums > Vista Newsgroups > Vista mail
Vista - Uninstall problem - uninstall not recognized by system
Old 11-08-2007   #1 (permalink)
KarenA
I recently uninstalled a program in order to install a new version. The old
version no longer shows up in my programs list (from the start button & then
programs). However it still shows up on the Control panel page used to
install or uninstall programs. When I try to install the new version of the
program I want - a drop down box appears stating that the old version still
exists and must be uninstalled in Windows Control panel. When I then go to
the control panel to try to uninstall for the second time I receive the
error message ""The specified module could not be found". So it seems that
the first uninstall did indeed uninstall the program - but it still shows up
on the control panel. Any ideas??
Old 11-08-2007   #2 (permalink)
Hal Hostetler [MVP P/I]
Re: Uninstall problem - uninstall not recognized by system
That's probably a Windows Installer error, I suspect the uninstall didn't
run correctly and damaged the installation. I think this utility will help:
http://support.microsoft.com/kb/290301
Description of the Windows Installer CleanUp Utility
The utility does NOT uninstall the program, it it removes all installation
records from Windows Installer so that a program can be re-installed to fix
the damage, then uninstalled correctly.
Hal
Hal Hostetler, CPBE -- hhh@xxxxxx
Senior Engineer/MIS -- MS MVP-Print/Imaging -- WA7BGX
http://www.kvoa.com -- "When News breaks, we fix it!"
KVOA Television, Tucson, AZ. NBC Channel 4
Live at Hot Licks - www.badnewsbluesband.com
"KarenA" <KAREN.FRAKES@xxxxxx> wrote in message
news:eZ4fZ4lIIHA.4592@xxxxxx
old
then
the
still
that
up
Solved Program wont uninstall it with Uninstall or Install Cleanup Utility Software
kb943411 hosed system. Won't uninstall. Won't reinstall Vista General
System Restore vs Uninstall Vista installation & setup
Uninstall Vista off of a dual boot system Vista installation & setup
Update Intel KCS slowed my system: how to uninstall it? Vista General
