Go Back   Vista Forums > Vista Newsgroups > Vista mail
Vista - Need HELP with REJECTED newsgroup POSTS - Error Message 441 Posting Failed (Rejected by POST filter)
Old 02-29-2008   #11 (permalink)
Carmen
Re: Need HELP with REJECTED newsgroup POSTS - Error Message 441 Posting Failed (Rejected by POST filter)
Hmmm. I can. Clue or just annoying?
Carmen
"Carmen" <chthomp@xxxxxx> wrote in message
news:upjbckweIHA.532@xxxxxx
Quote:
> Carmen again, just seeing if I can send posts to the microsoft groups
> using the same setting that don't work for the alt groups.
> "Gary VanderMolen" <gary@xxxxxx> wrote in message
> news:%23QeONBdeIHA.148@xxxxxx
Quote:
>> Glad to have helped.
>> Gary VanderMolen, MS-MVP (WLMail)
>> "Charlie" <charlie@xxxxxx> wrote in message
>> news:Tjmxj.100096$_m.1892@xxxxxx
Quote:
>>> My wife thanks you!! I thank you!! and my mother thanks you too!!
>>> Charlie
>>> TYVM to all that replied...
>>> news:OjYhvSYeIHA.6136@xxxxxx
>>>> Try this:
>>>> Tools, Options, Send, in the News Sending Format section be sure
>>>> that Plain Text is selected. Click on Plain Text Settings, select
>>>> Uuencode, OK. Try posting.
>>>> news:Lcfxj.85698$Mu4.20016@xxxxxx
>>>>>I am posting for my wife who is unable to post anything to any
>>>>>newsgroup from her Windows Vista Home Premium PC. She is using
>>>>>Windows Mail. Below is the
>>>>> error message she continues to receive.
>>>>> Windows Mail could not post your message. Subject 'testing', Account:
>>>>> 'newsgroups.bellsouth.net', Server: 'newsgroups.bellsouth.net',
>>>>> Protocol:
>>>>> NNTP, Server Response: '441 Posting Failed (Rejected by POST filter)',
>>>>> Port:
>>>>> 119, Secure(SSL): No, Server Error: 441, Error Number: 0x800CCCA9
>>>>> When she contacts Bellsouth support rarely does anyone there even know
>>>>> what a newsgroup is.
>>>>> Any and all help is much appreciated. She will be monitoring this
>>>>> newsgroup for your words of enlightenment!!!
>>>>> Thank you,
>>>>> Charlie
Old 02-29-2008   #12 (permalink)
Carmen
Hey, I fixed it! The trick is to go into the HTML settings as well, and
choose "Base 64" for the Mime settings. Don't know *why* it worked, but I
was just able to post to one of my ALT groups after doing that.
If Windows were a smoothie, it'd be broccoli smoothie with caramel and
whipped cream - sometimes it's just *wrong*.
<G>
Carmen
>> Charlie
Quote:
>>> Try this:
>>>>I am posting for my wife who is unable to post anything to any newsgroup
>>>> Protocol:
>>>> Port:
>>>> Thank you,
>>>> Charlie
Old 02-29-2008   #13 (permalink)
Gary VanderMolen
Thanks for that update. My previous guidance was for those who post
to Usenet in plain text. Most newsgroups frown on posting with HTML.
"Carmen" <chthomp@xxxxxx> wrote in message news:uzFO7tweIHA.1900@xxxxxx
Quote:
> Hey, I fixed it! The trick is to go into the HTML settings as well, and choose "Base 64" for the Mime settings. Don't know
> *why* it worked, but I was just able to post to one of my ALT groups after doing that.
> If Windows were a smoothie, it'd be broccoli smoothie with caramel and whipped cream - sometimes it's just *wrong*.
> <G>
> Carmen
> "Gary VanderMolen" <gary@xxxxxx> wrote in message news:%23QeONBdeIHA.148@xxxxxx
>> "Charlie" <charlie@xxxxxx> wrote in message news:Tjmxj.100096$_m.1892@xxxxxx
>>> Charlie
>>> "Gary VanderMolen" <gary@xxxxxx> wrote in message news:OjYhvSYeIHA.6136@xxxxxx
>>>> Try this:
>>>> "Charlie" <charlie@xxxxxx> wrote in message news:Lcfxj.85698$Mu4.20016@xxxxxx
>>>>>I am posting for my wife who is unable to post anything to any newsgroup from her Windows Vista Home Premium PC. She is using
>>>>> 'newsgroups.bellsouth.net', Server: 'newsgroups.bellsouth.net', Protocol:
>>>>> NNTP, Server Response: '441 Posting Failed (Rejected by POST filter)', Port:
>>>>> When she contacts Bellsouth support rarely does anyone there even know what a newsgroup is.
>>>>> Any and all help is much appreciated. She will be monitoring this newsgroup for your words of enlightenment!!!
>>>>> Thank you,
>>>>> Charlie
Old 02-29-2008   #14 (permalink)
Carmen
news:el6U%23TxeIHA.1208@xxxxxx
I know, and have (and did already have) the Outgoing posts set to "plain
text". That's why I'm not sure why changing the HTML settings to Base 64
would affect my ability to post when HTML isn't even selected. Odd.
Carmen
>> <G>
>> Carmen
>>>> Charlie
>>>>> Try this:
>>>>>> Protocol:
>>>>>> filter)', Port:
>>>>>> Thank you,
>>>>>> Charlie
Old 02-29-2008   #15 (permalink)
"Carmen" <carmensrt@xxxxxx> wrote in message
news:4c5be9bb-7725-4444-ac64-24b6f3ac38ea@xxxxxx
Quote:
>> "Charlie" <char...@xxxxxx> wrote in
>> messagenews:Tjmxj.100096$_m.1892@xxxxxx
Quote:
>> > Charlie
Quote:
>> > "Gary VanderMolen" <g...@xxxxxx> wrote in
>> > messagenews:OjYhvSYeIHA.6136@xxxxxx
>> >> Try this:
>> >> messagenews:Lcfxj.85698$Mu4.20016@xxxxxx
>> >>> Protocol:
>> >>> filter)', Port:
Quote:
>> >>> Thank you,
>> >>> Charlie
> Have you got any more ideas I could try? The UUencode trick does not
> work for me. I can download and read the newsgroups no problem, but I
> get the same error code the OP does when trying to reply using WM.
> Vista, Windows Mail, Firefox for a browser if that matters. Google
> Groups are okay, but not ideal.
> Thank you for any ideas anyone may have,
> Carmen
What newsgroup server are you using?
For the newsgroups.bellsouth.net server, click on Tools, then Options,
then Send. Under News Sending Format, click on HTML Settings,
then the triangle. The choice None does not work; I use Quoted
Printable, and as far as I know, Base 64 also works. Click on OK,
then under News Sending Format, click on Plain Text Settings.
If you have not selected Uuencode, as I did, make the same setting
under MIME. Click on OK. Under News Sending Format, make
sure you selected Plain Text unless you post only to newsgroups
with .binaries. in the name. Click on Apply, then OK.
I don't know if you can use this server if you are not a bellsouth.net
AT&T customer; perhaps other AT&T customers can, but I haven't
seen anything on this.
Old 02-29-2008   #16 (permalink)
If you're using the Microsoft Communities server, apparantly you
can.
news:uI4mgmweIHA.1132@xxxxxx
> Carmen
>>>> Charlie
>>>>> Try this:
>>>>>> Protocol:
>>>>>> filter)', Port:
>>>>>> Thank you,
>>>>>> Charlie
Old 02-29-2008   #17 (permalink)
I suspect that Windows Mail automatically switches to HTML if you
add any attachments to the message you post.
news:eeHUaYxeIHA.5280@xxxxxx
> Carmen
>>> <G>
>>> Carmen
>>>>> Charlie
>>>>>> Try this:
>>>>>>> Account:
>>>>>>> Protocol:
>>>>>>> filter)', Port:
>>>>>>> Thank you,
>>>>>>> Charlie
Old 02-29-2008   #18 (permalink)
Gary VanderMolen
Most news servers don't care which MIME format you use for posting.
The Bellsouth news server is one of he few that is fussy about it.
<robertmiles@xxxxxx> wrote in message news:OkoEz4xeIHA.3400@xxxxxx
> can.
> "Carmen" <chthomp@xxxxxx> wrote in message news:uI4mgmweIHA.1132@xxxxxx
>> Carmen
>> "Carmen" <chthomp@xxxxxx> wrote in message news:upjbckweIHA.532@xxxxxx
Quote:
>>> Carmen again, just seeing if I can send posts to the microsoft groups using the same setting that don't work for the alt
>>> groups.
>>>>> Charlie
>>>>>> Try this:
>>>>>>>using
>>>>>>> Thank you,
>>>>>>> Charlie
Old 02-29-2008   #19 (permalink)
Carmen
news:OoreF6xeIHA.1164@xxxxxx
Anything is possible I guess. My husband just bought me this computer
preloaded with Vista (I'd been using - and was comfortable with Win2K) so
I'm not familiar enough with the OS to guess one way or another. It's been
a steep learning curve, and I'm still looking for answers to for one of the
most annoying bugs. My monitor screen comes on for about 30 seconds, then
goes to black for about 15 seconds upon first "waking up" the monitor. No
error message accompanies it either, so I can't search for answers based on
that.
I miss 2K.
Carmen
>> Carmen
>>>> and choose "Base 64" for the Mime settings. Don't know *why* it
>>>> that.
>>>> <G>
>>>> Carmen
>>>>>> Charlie
>>>>>>> Try this:
>>>>>>>> Account:
>>>>>>>> Protocol:
>>>>>>>> filter)', Port:
>>>>>>>> Thank you,
>>>>>>>> Charlie
Old 02-29-2008   #20 (permalink)
Carmen
> can.
Too bad they only carry Microsoft discussion groups. That server is less
troublesome than the Bellsouth newsserver.
Carmen
>> Carmen
>>>>> Charlie
>>>>>> Try this:
>>>>>>> Account:
>>>>>>> Protocol:
>>>>>>> filter)', Port:
>>>>>>> Thank you,
>>>>>>> Charlie
Rejected message to Hotmail account Live Mail
server rejected Vista mail
rejected mail Vista mail
Rejected by MSCONFIG! System Security
Posting error message and double posts Vista General
