| | Vista POP3 Major Problem - Help MS Hi, We are having a major problem with POP3 in Vista. We are an ISP. Vista does not download mail using pop3 if there are large mails or attachments. Vista just states the server has timed out, we have tried increasing the timeout value also. We have installed a brand new installation of vista (with no anti-virus software, firewall disabled etc). When we try to download mail using pop3 (windows mail, outlook 2003, thunderbird) from our mail server it just times out, if there is a mail with an attachment or large email in the inbox. I've tried using RAW telnet commands to connect and it just hangs when you try to retrieve a message with attachments or large emails. Every other OS/mail client combination works fine with our mail platform. I have checked our external firewalls and cannot see any strange errors or port usage. Just shows as pop3 connecting, the firewall isn't blocking anything. This is obviously a problem with Vista and how MS have used the pop3 code, have they followed the RFC!!? MS need to fix this but I can't find anything on their site about, but plenty of people are having this problem. This is extremely frustrating as our customers are starting to use Vista and we cannot do anything to help them!! They assume it is our fault, which it is not. If anyone has a fix or suggestions please can you share them. Many Thanks Matt |
| | RE: Vista POP3 Major Problem - Help MS My problem is that I cannot send messages that have a fille attached that is more than a simple Word Doc. If i am sending anything around 3 - 5mb, it just times out, kind of like you said. is this the same problem? and is there no fix at this point? "Matt_Gsy" wrote: > Hi, > We are having a major problem with POP3 in Vista. We are an ISP. > Vista does not download mail using pop3 if there are large mails or > attachments. Vista just states the server has timed out, we have tried > increasing the timeout value also. > We have installed a brand new installation of vista (with no anti-virus > software, firewall disabled etc). > When we try to download mail using pop3 (windows mail, outlook 2003, > thunderbird) from our mail server it just times out, if there is a mail with > an attachment or large email in the inbox. > I've tried using RAW telnet commands to connect and it just hangs when you > try to retrieve a message with attachments or large emails. > Every other OS/mail client combination works fine with our mail platform. > I have checked our external firewalls and cannot see any strange errors or > port usage. Just shows as pop3 connecting, the firewall isn't blocking > anything. > This is obviously a problem with Vista and how MS have used the pop3 code, > have they followed the RFC!!? > MS need to fix this but I can't find anything on their site about, but > plenty of people are having this problem. > > This is extremely frustrating as our customers are starting to use Vista and > we cannot do anything to help them!! > > They assume it is our fault, which it is not. > > If anyone has a fix or suggestions please can you share them. > > Many Thanks > > Matt > |
| | Re: Vista POP3 Major Problem - Help MS "Matt_Gsy" <MattGsy@discussions.microsoft.com> wrote in message news:6BE1C775-EF54-429C-AFE4-C1009CE20F4D@microsoft.com... > Hi, > We are having a major problem with POP3 in Vista. We are an ISP. > Vista does not download mail using pop3 if there are large mails or > attachments. Vista just states the server has timed out, we have tried > increasing the timeout value also. > We have installed a brand new installation of vista (with no anti-virus > software, firewall disabled etc). > When we try to download mail using pop3 (windows mail, outlook 2003, > thunderbird) from our mail server it just times out, if there is a mail > with > an attachment or large email in the inbox. > I've tried using RAW telnet commands to connect and it just hangs when you > try to retrieve a message with attachments or large emails. > Every other OS/mail client combination works fine with our mail platform. > I have checked our external firewalls and cannot see any strange errors or > port usage. Just shows as pop3 connecting, the firewall isn't blocking > anything. > This is obviously a problem with Vista and how MS have used the pop3 code, > have they followed the RFC!!? > MS need to fix this but I can't find anything on their site about, but > plenty of people are having this problem. > > This is extremely frustrating as our customers are starting to use Vista > and > we cannot do anything to help them!! > > They assume it is our fault, which it is not. > > If anyone has a fix or suggestions please can you share them. > > Many Thanks > > Matt > This is usually caused by an anti-spam program or an anti-virus set to scan email. Have your customers turn off email scanning in their anti-virus. It provides no added protection. After doing so it may be necessary to reset the server names in OE. The Other E-Mail Threat: File Corruption in Outlook Express Published: November 18, 2004 By Tom Koch http://www.microsoft.com/windows/IE/...orruption.mspx Email scanning slows down Sending and Receiving, sometimes enough that OE times out. Since some of the received messages have large (often virus) attachments, which exasperates the problem. Some Comcast users have found it necessary to totally uninstall Norton and switch to the free AVG with mail scanning off. Norton invented email scanning and here's what they say: "Disabling Email Scanning does not leave you unprotected against viruses that are distributed as email attachments. Norton AntiVirus Auto-Protect scans incoming files as they are saved to your hard drive, including email and email attachments. Email Scanning is just another layer on top of this. To make sure that Auto-Protect is providing the maximum protection, keep Auto-Protect enabled and run LiveUpdate regularly to ensure that you have the most recent virus definitions." http://service1.symantec.com/SUPPORT...256c7500723cf0 "...your computer is protected if Auto-Protect is enabled. Auto-Protect scans any incoming files, including email attachments, when the files are saved to your hard drive." http://service1.symantec.com/SUPPORT...01100907323806 "NAV provides multiple layers of protection. Email scanning is just one of those layers. Even if you are not running Email Scanning, your computer is protected against viruses that are distributed as email attachments by NAV Auto-Protect. Auto-Protect will scan any incoming files, including email attachments, as they are saved to your hard drive. To make sure that Auto-Protect is providing the maximum protection, keep Auto-Protect enabled and run LiveUpdate regularly to ensure that you have the most recent virus definitions." http://service1.symantec.com/SUPPORT...rc=bar_sch_nam See also http://help.expedient.com/mailnews/n...ntivirus.shtml So Symantec used to say this often and clearly. The newer stuff doesn't have the statement included as it was considered an embarrassment. If you know anyone who programs for Norton try to get them to talk about it. -- Frank Saunders, MS-MVP OE/WM http://www.fjsmjs.com Answer in newsgroup. Don't expect an answer to email. |
| | Re: Vista POP3 Major Problem - Help MS thanks for the detailed reply. unfortunately i have already turned off the email scan feature, and it still will not send the emails with attachments larger than a simple Word doc. any thoughts? "Frank Saunders, MS-MVP OE/WM" wrote: > "Matt_Gsy" <MattGsy@discussions.microsoft.com> wrote in message > news:6BE1C775-EF54-429C-AFE4-C1009CE20F4D@microsoft.com... > > Hi, > > We are having a major problem with POP3 in Vista. We are an ISP. > > Vista does not download mail using pop3 if there are large mails or > > attachments. Vista just states the server has timed out, we have tried > > increasing the timeout value also. > > We have installed a brand new installation of vista (with no anti-virus > > software, firewall disabled etc). > > When we try to download mail using pop3 (windows mail, outlook 2003, > > thunderbird) from our mail server it just times out, if there is a mail > > with > > an attachment or large email in the inbox. > > I've tried using RAW telnet commands to connect and it just hangs when you > > try to retrieve a message with attachments or large emails. > > Every other OS/mail client combination works fine with our mail platform. > > I have checked our external firewalls and cannot see any strange errors or > > port usage. Just shows as pop3 connecting, the firewall isn't blocking > > anything. > > This is obviously a problem with Vista and how MS have used the pop3 code, > > have they followed the RFC!!? > > MS need to fix this but I can't find anything on their site about, but > > plenty of people are having this problem. > > > > This is extremely frustrating as our customers are starting to use Vista > > and > > we cannot do anything to help them!! > > > > They assume it is our fault, which it is not. > > > > If anyone has a fix or suggestions please can you share them. > > > > Many Thanks > > > > Matt > > > > This is usually caused by an anti-spam program or an anti-virus set to scan > email. > > Have your customers turn off email scanning in their anti-virus. It > provides no added protection. After doing so it may be necessary to reset > the server names in OE. > > The Other E-Mail Threat: File Corruption in Outlook Express > Published: November 18, 2004 > By Tom Koch > http://www.microsoft.com/windows/IE/...orruption.mspx > > Email scanning slows down Sending and Receiving, sometimes enough that OE > times out. Since some of the received messages have large (often virus) > attachments, which exasperates the problem. > Some Comcast users have found it necessary to totally uninstall Norton and > switch to the free AVG with mail scanning off. Norton invented email > scanning and here's what they say: > > "Disabling Email Scanning does not leave you unprotected against viruses > that > are distributed as email attachments. Norton AntiVirus Auto-Protect scans > incoming files as they are saved to your hard drive, including email and > email attachments. Email Scanning is just another layer on top of this. To > make sure that Auto-Protect is providing the maximum protection, keep > Auto-Protect enabled and run LiveUpdate regularly to ensure that you have > the most recent virus definitions." > http://service1.symantec.com/SUPPORT...256c7500723cf0 > > "...your computer is protected if Auto-Protect is enabled. Auto-Protect > scans any incoming files, including email attachments, when the files are > saved to your hard drive." > http://service1.symantec.com/SUPPORT...01100907323806 > > "NAV provides multiple layers of protection. Email scanning is just one of > those layers. Even if you are not running Email Scanning, your computer is > protected against viruses that are distributed as email attachments by NAV > Auto-Protect. Auto-Protect will scan any incoming files, including email > attachments, as they are saved to your hard drive. To make sure that > Auto-Protect is providing the maximum protection, keep Auto-Protect enabled > and run LiveUpdate regularly to ensure that you have the most recent virus > definitions." > http://service1.symantec.com/SUPPORT...rc=bar_sch_nam > > See also > http://help.expedient.com/mailnews/n...ntivirus.shtml > > So Symantec used to say this often and clearly. The newer stuff doesn't > have the statement included as it was considered an embarrassment. If you > know anyone who programs for Norton try to get them to talk about it. > > -- > Frank Saunders, MS-MVP OE/WM > http://www.fjsmjs.com > Answer in newsgroup. Don't expect an answer to email. > > |
| | Re: Vista POP3 Major Problem - Help MS If it's that Windows Mail won't send, then it's not a POP3 problem, It's an SMTP problem. How big does an attachment have to be to cause a problem? I'd like to do some experimenting. "ScottM" <ScottM@discussions.microsoft.com> wrote in message news:42779D76-AD1B-40C5-9943-05E1C0DB6040@microsoft.com... > thanks for the detailed reply. unfortunately i have already turned off > the > email scan feature, and it still will not send the emails with attachments > larger than a simple Word doc. any thoughts? > > "Frank Saunders, MS-MVP OE/WM" wrote: > >> "Matt_Gsy" <MattGsy@discussions.microsoft.com> wrote in message >> news:6BE1C775-EF54-429C-AFE4-C1009CE20F4D@microsoft.com... >> > Hi, >> > We are having a major problem with POP3 in Vista. We are an ISP. >> > Vista does not download mail using pop3 if there are large mails or >> > attachments. Vista just states the server has timed out, we have tried >> > increasing the timeout value also. >> > We have installed a brand new installation of vista (with no anti-virus >> > software, firewall disabled etc). >> > When we try to download mail using pop3 (windows mail, outlook 2003, >> > thunderbird) from our mail server it just times out, if there is a mail >> > with >> > an attachment or large email in the inbox. >> > I've tried using RAW telnet commands to connect and it just hangs when >> > you >> > try to retrieve a message with attachments or large emails. >> > Every other OS/mail client combination works fine with our mail >> > platform. >> > I have checked our external firewalls and cannot see any strange errors >> > or >> > port usage. Just shows as pop3 connecting, the firewall isn't blocking >> > anything. >> > This is obviously a problem with Vista and how MS have used the pop3 >> > code, >> > have they followed the RFC!!? >> > MS need to fix this but I can't find anything on their site about, but >> > plenty of people are having this problem. >> > >> > This is extremely frustrating as our customers are starting to use >> > Vista >> > and >> > we cannot do anything to help them!! >> > >> > They assume it is our fault, which it is not. >> > >> > If anyone has a fix or suggestions please can you share them. >> >> This is usually caused by an anti-spam program or an anti-virus set to >> scan >> email. >> >> Have your customers turn off email scanning in their anti-virus. It >> provides no added protection. After doing so it may be necessary to >> reset >> the server names in OE. >> >> The Other E-Mail Threat: File Corruption in Outlook Express >> Published: November 18, 2004 >> By Tom Koch >> http://www.microsoft.com/windows/IE/...orruption.mspx |
| | #6 (permalink) |
| | Re: Vista POP3 Major Problem - Help MS The people telling you that this is an AntiVirus issue obviously has not dealt with this. I assure you that it is windows. Don't disable antivius, your customers will not appreciate it. It is an issue with windows. I even did a clean re-install on a brand new hard drive with no antivirus software installed. Same problem present. And, yes, I am extremely familiar with setting up and maintaining software, computers, and very adept at troubleshooting. WINDOWS MAIL has major issues. A few people on here repost the same answer to every similar question and if you will notice, the issue never gets resolved. Bill Gates and his cronies are our only hope... (if ever that happens). Good Day. neospyce "Matt_Gsy" <MattGsy@discussions.microsoft.com> wrote in message news:6BE1C775-EF54-429C-AFE4-C1009CE20F4D@microsoft.com... > Hi, > We are having a major problem with POP3 in Vista. We are an ISP. > Vista does not download mail using pop3 if there are large mails or > attachments. Vista just states the server has timed out, we have tried > increasing the timeout value also. > We have installed a brand new installation of vista (with no anti-virus > software, firewall disabled etc). > When we try to download mail using pop3 (windows mail, outlook 2003, > thunderbird) from our mail server it just times out, if there is a mail > with > an attachment or large email in the inbox. > I've tried using RAW telnet commands to connect and it just hangs when you > try to retrieve a message with attachments or large emails. > Every other OS/mail client combination works fine with our mail platform. > I have checked our external firewalls and cannot see any strange errors or > port usage. Just shows as pop3 connecting, the firewall isn't blocking > anything. > This is obviously a problem with Vista and how MS have used the pop3 code, > have they followed the RFC!!? > MS need to fix this but I can't find anything on their site about, but > plenty of people are having this problem. > > This is extremely frustrating as our customers are starting to use Vista > and > we cannot do anything to help them!! > > They assume it is our fault, which it is not. > > If anyone has a fix or suggestions please can you share them. > > Many Thanks > > Matt > |
| | #7 (permalink) |
| | Re: Vista POP3 Major Problem - Help MS I don't know how long you have been following the posts in this newsgroup, but I've had several users respond back that their Windows Mail starting working again after uninstalling McAfee or Norton Antivirus. I think we are dealing with several different issues, some of which are caused by antivirus email scanning, and some are caused by something else. To be sure, one should install a different (better) antivirus after uninstalling McAfee or Norton Antivirus. Gary VanderMolen <msbecca421@yahoo.com> wrote in message news:%23x$s05MeHHA.3884@TK2MSFTNGP04.phx.gbl... > The people telling you that this is an AntiVirus issue obviously has not > dealt with this. I assure you that it is windows. Don't disable antivius, > your customers will not appreciate it. It is an issue with windows. I even > did a clean re-install on a brand new hard drive with no antivirus software > installed. Same problem present. And, yes, I am extremely familiar with > setting up and maintaining software, computers, and very adept at > troubleshooting. WINDOWS MAIL has major issues. A few people on here repost > the same answer to every similar question and if you will notice, the issue > never gets resolved. Bill Gates and his cronies are our only hope... (if > ever that happens). Good Day. > > neospyce |
| | #8 (permalink) |
| | Re: Vista POP3 Major Problem - Help MS And it's the windows 98 groups had the same problems from the same suppliers, and it's nine years on. And email scanning is stupid anyway, the data has already (or may have been - some programs have options to only do high risk files, in which case the email part shouldn't bother either) been scanned by the same program when it read or wrote to the disk. So a feature meant for looking good in product comparisons. "Gary VanderMolen" <gary@NoMail.invalid> wrote in message news:eZEhvWNeHHA.4004@TK2MSFTNGP06.phx.gbl... >I don't know how long you have been following the posts > in this newsgroup, but I've had several users respond back > that their Windows Mail starting working again after > uninstalling McAfee or Norton Antivirus. > > I think we are dealing with several different issues, some > of which are caused by antivirus email scanning, and some > are caused by something else. > > To be sure, one should install a different (better) antivirus > after uninstalling McAfee or Norton Antivirus. > > Gary VanderMolen > > <msbecca421@yahoo.com> wrote in message > news:%23x$s05MeHHA.3884@TK2MSFTNGP04.phx.gbl... >> The people telling you that this is an AntiVirus issue obviously has not >> dealt with this. I assure you that it is windows. Don't disable antivius, >> your customers will not appreciate it. It is an issue with windows. I >> even did a clean re-install on a brand new hard drive with no antivirus >> software installed. Same problem present. And, yes, I am extremely >> familiar with setting up and maintaining software, computers, and very >> adept at troubleshooting. WINDOWS MAIL has major issues. A few people on >> here repost the same answer to every similar question and if you will >> notice, the issue never gets resolved. Bill Gates and his cronies are our >> only hope... (if ever that happens). Good Day. >> >> neospyce > |
| | #9 (permalink) |
| | Re: Vista POP3 Major Problem - Help MS Exactly. All the AV software now includes "email scanning", which translates in OE and WinMail into loss of functionality. steve <.> wrote in message news:ODltJTQeHHA.4020@TK2MSFTNGP06.phx.gbl... > And it's the windows 98 groups had the same problems from the same > suppliers, and it's nine years on. And email scanning is stupid anyway, > the data has already (or may have been - some programs have options to > only do high risk files, in which case the email part shouldn't bother > either) been scanned by the same program when it read or wrote to the > disk. > > So a feature meant for looking good in product comparisons. > > "Gary VanderMolen" <gary@NoMail.invalid> wrote in message > news:eZEhvWNeHHA.4004@TK2MSFTNGP06.phx.gbl... >>I don't know how long you have been following the posts >> in this newsgroup, but I've had several users respond back >> that their Windows Mail starting working again after >> uninstalling McAfee or Norton Antivirus. >> >> I think we are dealing with several different issues, some >> of which are caused by antivirus email scanning, and some >> are caused by something else. >> >> To be sure, one should install a different (better) antivirus >> after uninstalling McAfee or Norton Antivirus. >> >> Gary VanderMolen >> >> <msbecca421@yahoo.com> wrote in message >> news:%23x$s05MeHHA.3884@TK2MSFTNGP04.phx.gbl... >>> The people telling you that this is an AntiVirus issue obviously has not >>> dealt with this. I assure you that it is windows. Don't disable >>> antivius, your customers will not appreciate it. It is an issue with >>> windows. I even did a clean re-install on a brand new hard drive with no >>> antivirus software installed. Same problem present. And, yes, I am >>> extremely familiar with setting up and maintaining software, computers, >>> and very adept at troubleshooting. WINDOWS MAIL has major issues. A few >>> people on here repost the same answer to every similar question and if >>> you will notice, the issue never gets resolved. Bill Gates and his >>> cronies are our only hope... (if ever that happens). Good Day. >>> >>> neospyce >> > |
| | #10 (permalink) |
| | Re: Vista POP3 Major Problem - Help MS You don't know what you are talking about. You may have problems with a clean install, but others are clearly having problems with machines supplied by the manufacturers with antivirus and antispam CRAPWARE on them and they clearly are causing issues for users. And I am a volunteer here. I am not a croney. steve <msbecca421@yahoo.com> wrote in message news:%23x$s05MeHHA.3884@TK2MSFTNGP04.phx.gbl... > The people telling you that this is an AntiVirus issue obviously has not > dealt with this. I assure you that it is windows. Don't disable antivius, > your customers will not appreciate it. It is an issue with windows. I even > did a clean re-install on a brand new hard drive with no antivirus > software installed. Same problem present. And, yes, I am extremely > familiar with setting up and maintaining software, computers, and very > adept at troubleshooting. WINDOWS MAIL has major issues. A few people on > here repost the same answer to every similar question and if you will > notice, the issue never gets resolved. Bill Gates and his cronies are our > only hope... (if ever that happens). Good Day. > > neospyce > > > "Matt_Gsy" <MattGsy@discussions.microsoft.com> wrote in message > news:6BE1C775-EF54-429C-AFE4-C1009CE20F4D@microsoft.com... >> Hi, >> We are having a major problem with POP3 in Vista. We are an ISP. >> Vista does not download mail using pop3 if there are large mails or >> attachments. Vista just states the server has timed out, we have tried >> increasing the timeout value also. >> We have installed a brand new installation of vista (with no anti-virus >> software, firewall disabled etc). >> When we try to download mail using pop3 (windows mail, outlook 2003, >> thunderbird) from our mail server it just times out, if there is a mail >> with >> an attachment or large email in the inbox. >> I've tried using RAW telnet commands to connect and it just hangs when >> you >> try to retrieve a message with attachments or large emails. >> Every other OS/mail client combination works fine with our mail platform. >> I have checked our external firewalls and cannot see any strange errors >> or >> port usage. Just shows as pop3 connecting, the firewall isn't blocking >> anything. >> This is obviously a problem with Vista and how MS have used the pop3 >> code, >> have they followed the RFC!!? >> MS need to fix this but I can't find anything on their site about, but >> plenty of people are having this problem. >> >> This is extremely frustrating as our customers are starting to use Vista >> and >> we cannot do anything to help them!! >> >> They assume it is our fault, which it is not. >> >> If anyone has a fix or suggestions please can you share them. >> >> Many Thanks >> >> Matt >> > |
| Major Vista Boot Problem | General Discussion | |||
| major problem with 7950 gx2 and vista ult. | Graphic cards | |||
| major problem with Vista Business | Vista General | |||
| Vista POP3 Major Problem - Help MS | Vista General | |||
| Re: Vista POP3 Major Problem - Help MS | Vista mail | |||
