| | Help Please Going Crazy I have the new vista with the windows mail and i had no problem adding my aol, verizon dsl to the windows mail but i am having trouble adding my verizon dsl with msn (hotmail) premium to the windows mail. What is the proper incoming and outgoing code, I never had a problem before with msn (hotmail) with outlook. what is this beta program through windows mail that takes a couple of weeks. Any help would make my day. ajnitti@msn.com |
| | Re: Help Please Going Crazy POP3: incoming.verizon.net SMTP: outgoing.verizon.net SMTP requires authentification. BTJustice "ajnitti" <ajnitti@discussions.microsoft.com> wrote in message news:9CFB1390-DE8F-4035-AEC1-DEBE0C13933D@microsoft.com... >I have the new vista with the windows mail and i had no problem adding my > aol, verizon dsl to the windows mail but i am having trouble adding my > verizon dsl with msn (hotmail) premium to the windows mail. What is the > proper incoming and outgoing code, I never had a problem before with msn > (hotmail) with outlook. what is this beta program through windows mail > that > takes a couple of weeks. Any help would make my day. ajnitti@msn.com |
| | RE: Help Please Going Crazy I got my aol and verizon to work but i still can not get my msn/hotmail email to work. I see on other post that some how the windows mail can be tricked to accept msn/hotmail mail. Could you please direct me in the right direction or give m the proper steps to trick windows mail. Thank you for any help. -------------------------------------------------------------------------------------------- > I have the new vista with the windows mail and i had no problem adding my > aol, verizon dsl to the windows mail but i am having trouble adding my > verizon dsl with msn (hotmail) premium to the windows mail. What is the > proper incoming and outgoing code, I never had a problem before with msn > (hotmail) with outlook. what is this beta program through windows mail that > takes a couple of weeks. Any help would make my day. ajnitti@msn.com |
| | Re: Help Please Going Crazy BTJ gave you the correct servers. Now you need to trick the dumb wizard in WinMail so you can enter and use the msn.com email that Verizon gave you. So, using the wizard, set up everything the way it should be, except for the email ID use your email-ID@dummy.com. After it is all set up, go back via Tools /Accounts / select that acct / Properties... and edit the email back to your email-ID@msn.com. Then, you should be good to go. Also, if you have trouble sending mail, make sure that the SMTP (outgoing) ID is set to your entire email address, not just your 'email-ID.' |
| | Re: Help Please Going Crazy can you please show me an example, i think i am doing it wrong. is msn/hotmail HTTP or incoming.hotmail.com and outging.hotmail.com, Can please give me the proper information to type in to complete the wizard.Thank you "Billusa" wrote: > BTJ gave you the correct servers. Now you need to trick the dumb wizard in > WinMail so you can enter and use the msn.com email that Verizon gave you. > > So, using the wizard, set up everything the way it should be, except for the > email ID use your email-ID@dummy.com. After it is all set up, go back via > Tools /Accounts / select that acct / Properties... and edit the email back > to your email-ID@msn.com. > > Then, you should be good to go. Also, if you have trouble sending mail, > make sure that the SMTP (outgoing) ID is set to your entire email address, > not just your 'email-ID.' > > |
| | #6 (permalink) |
| | Re: Help Please Going Crazy First of all, what does Verizon tell you the servers are called? Secondly, what was the setup you had when you had it on Outlook, before? The exact names, etc. I'm afraid that you are not providing enough info. |
| | #7 (permalink) |
| | Re: Help Please Going Crazy I checked my outlook account on my xp computer and it only has hotmail/msn as a url no incoming or outgoing set up. My vista computer will not accept the http url that follows - http://services.msn.com/svcs/hotmail/httpmail.asp "Billusa" wrote: > First of all, what does Verizon tell you the servers are called? > Secondly, what was the setup you had when you had it on Outlook, before? > The exact names, etc. > > I'm afraid that you are not providing enough info. > > |
| | #8 (permalink) |
| | Re: Help Please Going Crazy Windows Mail does not support HTML-based email. |
| i am going CRAZY, | Vista mail | |||
| DEP Got my pc crazy!!!! | System Security | |||
| What is all this crazy chatter going on? Just FYI | Vista General | |||
| Harddrive going crazy | Vista performance & maintenance | |||
| Am I Crazy? | Vista General | |||
