| | Sound distortion with Easycap USB capture card. Help please! I am trying to capture vhs video from my camcorder using Easycap USB capture card and Ulead studio software. I am having problems with the sound which is distorted. I think it may be something to do with the input source which is showing only one option which is "Master volume". This I think should be the same as the usb line. All the other settings appear to be set correctly. Does anyone know what the solution to this could be. I am using Windows Vista Ultimate. Thanks Eric |
| Video Capture card?? | Vista hardware & devices | |||
| Capture card help | General Discussion | |||
| Sound Recorder USB Microphone Distortion | Vista General | |||
| Sound -distortion in Vista64 | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
