Go Back   Vista Forums > Vista Newsgroups > Vista music pictures video
RB
Vista - Problems running multple sound devices
07-03-2006   #1
blackgold9
I use a program called Virtual DJ for, well, dj'ing. My setup utilizes two
external soundcards/controllers which are run simultaneously for mixing
tracks. On windows xp this works perfectly,but run under vista, the tracks
skip ahead randomly. This is without high cpu usage or i/o activity. This
does not happen if i remove the controllers and use the internal soundcard
(which is not an acceptable solution). Can anyone offer some feedback on how
to stabalize the audio ?
RB
Similar Threads for: Problems running multple sound devices
Big Problems with Vista x64 and Bluetooth Sound Devices Sound & Audio
Vista Desktop Will Not Stop My USB Devices From Running. Vista General
Getting sound on two devices Vista General
Sound to 2 playback devices Vista hardware & devices
Using multiple sound devices? Vista hardware & devices
