Vista - Remote Connection, VNC? VPN? HELP!
Old 10-21-2007   #1 (permalink)
mikeleblanc19
Goal:
I would like to be able to connect remotely to a remote PC. I would
like to use UltraVNC's add-on that you can create an EXE file so they
(remote computer) just need to open the EXE, and double click to make
a connection.
Equipement/Software:
- Vista Home Premium
- Linksys WRTG-54 router
- VNC Server
- IP address provided by DynDNS
- Using the Windows Firewall
Steps Taken:
I must advise that I'm not the smartest when it comes to networks. I'm
able to connect through a local computer with VNC, now I just need to
figure out how to make a connection externally. I've added port 5500
associated with my private IP address through my router. Made sure
port 5500 wasn't blocked by Windows firewall. I've set up the DMZ to
my IP address (private). Now when I go on another computer on my LAN,
using XP-Home, try to connect to the ip address provided by DynDNS, it
just times out and doesn't make a connection. I'm able to make a
connection trying to connect using the IP address provided by the
router. I've even gave up and tried VPN, doesn't work either, I just
need some help, I know I'm doing something wrong, but what? I need
some feedback.
Mike
Old 10-21-2007   #2 (permalink)
Jeffrey Randow
Re: Remote Connection, VNC? VPN? HELP!
Are you use your PC internal IP address hasn't changed?
Jeffrey Randow
jeffreycentex@xxxxxx
Windows Networking MVP 2001-2006
http://www.networkblog.net
On Sun, 21 Oct 2007 16:35:55 -0700, mikeleblanc19@xxxxxx wrote:
Quote:
>Goal:
>a connection.
>- VNC Server
>Steps Taken:
>some feedback.
>Mike
invalid connection file on remote desktop connection Vista General
Fixed! Remote Desktop Connection (RDC) SLOW/NO Connection Issue Vista networking & sharing
VB.NET application cliick-once deployment via internet - Error - Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. .NET General
Can't login to remote comp. using Remote Desktop Connection on Vis Vista account administration
remote desktop connection? AKA remote access? Vista General
