| | Wireless Network Adhoc Problems! Hello, I have two laptops on Vista Ultimate and my main computer on XP Home. I have a cable modem which is going through my PC and is being shared via Ad Hoc to the laptops. My problem is that only one laptop can use the internet at a time. They both connect to the network ok, but only one can access the internet. When they were on Xp they could both be on the internet at the same time. I know it’s nothing wrong with them because if I disconnect one the other will work and vice versa. I am using windows inbuilt wireless utility if that helps. Does anyone have any ideas (please don’t tell me to get a router as I like using Ad Hoc)? Thanks for your time, BMS |
| | RE: Wireless Network Adhoc Problems! "BMS_Online" wrote: Quote: > Hello, > > I have two laptops on Vista Ultimate and my main computer on XP Home. I have > a cable modem which is going through my PC and is being shared via Ad Hoc to > the laptops. My problem is that only one laptop can use the internet at a > time. They both connect to the network ok, but only one can access the > internet. When they were on Xp they could both be on the internet at the same > time. I know it’s nothing wrong with them because if I disconnect one the > other will work and vice versa. I am using windows inbuilt wireless utility > if that helps. Does anyone have any ideas (please don’t tell me to get a > router as I like using Ad Hoc)? Quote: > > Thanks for your time, > BMS > |
| Network Defaulting to Adhoc | Vista networking & sharing | |||
| 64 bit vista home premium adhoc network connections | Network & Sharing | |||
| adhoc wireless - How to auto connect?? | Network & Sharing | |||
| Setting up an AdHoc Network | Vista networking & sharing | |||
| XP Host - Vista Client On Adhoc Network | Vista networking & sharing | |||
