Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Permissions Problem
LinkBack Thread Tools Display Modes
Old 10-23-2007   #1 (permalink)
Bob Hansen
Guest
Permissions Problem
Hi Group,
I have a small home network. My main desktop is wired to the router and has
Vista home premium. I also have a second desktop and a laptop, both with XP
and both wireless. When I try to access my folders on the Vista machine from
either of the other 2, The error message is
\\Bob-Desktop\ Bob Hansen is not accessible. You might not have permission
to use this network resource. Contact the administrator of this server to
find out if you have access permissions.
I have set all the folders to shared and all permissions to " let everyone
do everything.
I have also disabled the firewalls on all 3 which shouldn't be a problem as
I am behind a router.
The 2 XP machines access each other properly.
I'd appreciate any ideas you may have on fixing this problem.
Bob
Old 10-24-2007   #2 (permalink)
Mick Murphy
Guest
RE: Permissions Problem
http://technet.microsoft.com/en-au/l.../bb727037.aspx
Bob, did you have a look down the bottom of the above link re permissions,
sharing, etc.
And have you set the workgroup name the same for all computers?
Vista is different from XP in this sharing regard.
"Bob Hansen" wrote:
Quote:
> Hi Group,
> do everything.
> Bob
Display Modes
problem with Permissions- can anyone please help robinb Vista General 11 01-23-2008 06:32 PM
Permissions problem Frank M. Greco Vista General 11 10-19-2007 05:18 PM
Permissions problem? Nicholas Hall Vista General 1 05-09-2007 09:08 AM
Permissions problem? Nicholas Hall Vista installation & setup 1 05-09-2007 09:08 AM
permissions problem? Nicholas Hall Vista file management 1 05-07-2007 04:02 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
