Vista Networking 'Location' Problem
  1. #1
    Mike Halsey Guest
    I've bought a load of Belkin N1 Wireless kit for my new house and set it up
    across my network. Most PCs have a PCI card and they all connect to my
    router fine, though one was a tad fiddly. There is one PC however that's
    connected via a Belkin N1 USB Card.
    This PC sees the network but won't connect to it properly. What happens is
    this...
    It sees the SSID of the network in the network connections dialog, but when
    I connect the Network and Sharing Centre takes ages 'identifying' the network
    and eventually just calls it 'unidentified network', sets it as public and
    the settings won't let me see the other computers there even if I change the
    settings to private.
    All the other PCs recognise the network name "6Pax" correctly and ask me is
    it a "Home", "Work" or "Public" network.
    I can't try a PCI card in this other PC as it doesn't have a slot I can use.
    I've tried the latest driver, uninstalling, reinstalling and deleting all
    the stored settings for that network.
    If Vista recognises the SSID why won't it assign it as the network name and
    what can I do to force it to ask me if it's a Home, Work or Public network.
    This is a setup with five PCs, 1x Windows Server 2003 with N1 PCI (Fine), 1x
    Vista Ultimate (Fine), 1x XP Pro (Fine), 1x Laptop with XP Pro and Vista and
    Wireless G built in (Fine), 1x XP Home Premium N1 USB (Problem)
    I couldn't find a forum on the belkin site to post this on.
    HELP!
    Thanks in advance.
  2. #2
    Mike Halsey Guest
    RE: Vista Networking 'Location' Problem
    Sorry, that last bit should have read...
    1x Vista Home Premium N1 USB (Problem)
  3. #3
    Mick Murphy Guest
    http://technet.microsoft.com/en-au/l.../bb878035.aspx
    You might find something in the above!
    "Mike Halsey" wrote:
    > Hi,
    > this...
    > HELP!
    > Thanks in advance.
Vista Networking 'Location' Problem problems?
location type for networking? TidusCloudZack Vista networking & sharing 1 08 May 2008
Different Vista XP networking problem pwolsty Vista networking & sharing 8 13 Feb 2008
Vista/XP Networking Problem SlmJon Vista networking & sharing 5 14 Dec 2007
Vista Networking Problem Dippers Vista networking & sharing 7 13 Mar 2007
Vista public files location problem Rob Jas Vista file management 5 21 Feb 2007
