| | Re: Wireless network signal problems az_golfer typed: Quote: > I could use some help here. I have a dual boot computer. Had XP Pro > installed for last few years, added a hard drive and installed Vista > Home Premium, no issues there. My problem lies in when I boot to > Vista, the signal strength of my wireless network is very low, > usually 1-11 Mbps. When I boot to XP Pro, the signal is 48-54 Mbps. I > am using all the same hardware, have installed all the lastest > drivers from Linksys, but no change. I talked to Linksys support and > thet say it is something in Vista causing the problem. I have tried > everything I can think of with no luck. if anybody can help me with > this issue, that would be great. Thanx....AC the following: change the WLAN-channel and see if there is an improvement. This has helped me already in several situations. Axel. |
| | Wireless network signal problems I could use some help here. I have a dual boot computer. Had XP Pro installed for last few years, added a hard drive and installed Vista Home Premium, no issues there. My problem lies in when I boot to Vista, the signal strength of my wireless network is very low, usually 1-11 Mbps. When I boot to XP Pro, the signal is 48-54 Mbps. I am using all the same hardware, have installed all the lastest drivers from Linksys, but no change. I talked to Linksys support and thet say it is something in Vista causing the problem. I have tried everything I can think of with no luck. if anybody can help me with this issue, that would be great. Thanx....AC |
| | Re: Wireless network signal problems Not the problem, have tried all the channels available, no differance. Thanx for the info though....AC "Axel Göller" wrote: Quote: > az_golfer typed: > Quote: > > I could use some help here. I have a dual boot computer. Had XP Pro > > installed for last few years, added a hard drive and installed Vista > > Home Premium, no issues there. My problem lies in when I boot to > > Vista, the signal strength of my wireless network is very low, > > usually 1-11 Mbps. When I boot to XP Pro, the signal is 48-54 Mbps. I > > am using all the same hardware, have installed all the lastest > > drivers from Linksys, but no change. I talked to Linksys support and > > thet say it is something in Vista causing the problem. I have tried > > everything I can think of with no luck. if anybody can help me with > > this issue, that would be great. Thanx....AC > If it has to do with some Vista-internal - sorry, I wouldn't know. But try > the following: change the WLAN-channel and see if there is an improvement. > This has helped me already in several situations. > Axel. > > |
| | Re: Wireless network signal problems are you using an XP driver or a Vista driver on Vista? which driver exactly? posting the TEXT output of ipconfig /all from an elevated command prompt may help. On Fri, 2 Nov 2007 13:48:11 -0700, az_golfer <azgolfer@xxxxxx> wrote: Quote: >Not the problem, have tried all the channels available, no differance. Thanx >for the info though....AC > >"Axel Göller" wrote: > Quote: >> az_golfer typed: >> Quote: >> > I could use some help here. I have a dual boot computer. Had XP Pro >> > installed for last few years, added a hard drive and installed Vista >> > Home Premium, no issues there. My problem lies in when I boot to >> > Vista, the signal strength of my wireless network is very low, >> > usually 1-11 Mbps. When I boot to XP Pro, the signal is 48-54 Mbps. I >> > am using all the same hardware, have installed all the lastest >> > drivers from Linksys, but no change. I talked to Linksys support and >> > thet say it is something in Vista causing the problem. I have tried >> > everything I can think of with no luck. if anybody can help me with >> > this issue, that would be great. Thanx....AC >> If it has to do with some Vista-internal - sorry, I wouldn't know. But try >> the following: change the WLAN-channel and see if there is an improvement. >> This has helped me already in several situations. >> Axel. >> >> Barb Bowman MS Windows-MVP http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| | Re: Wireless network signal problems I am using the XP driver in XP and the Vista driver in Vista. Both came straight from Linksys. The XP driver version is 2.0.2.0 dated 4/13/05 and the Vista driver is version 3.0.2.0 dated 12/27/06. Thanx for the info. Any other ideas?....AC "Barb Bowman" wrote: Quote: > are you using an XP driver or a Vista driver on Vista? which driver > exactly? > > posting the TEXT output of > > ipconfig /all > > from an elevated command prompt may help. > > On Fri, 2 Nov 2007 13:48:11 -0700, az_golfer > <azgolfer@xxxxxx> wrote: > Quote: > >Not the problem, have tried all the channels available, no differance. Thanx > >for the info though....AC > > > >"Axel Göller" wrote: > > Quote: > >> az_golfer typed: > >> > >> > I could use some help here. I have a dual boot computer. Had XP Pro > >> > installed for last few years, added a hard drive and installed Vista > >> > Home Premium, no issues there. My problem lies in when I boot to > >> > Vista, the signal strength of my wireless network is very low, > >> > usually 1-11 Mbps. When I boot to XP Pro, the signal is 48-54 Mbps. I > >> > am using all the same hardware, have installed all the lastest > >> > drivers from Linksys, but no change. I talked to Linksys support and > >> > thet say it is something in Vista causing the problem. I have tried > >> > everything I can think of with no luck. if anybody can help me with > >> > this issue, that would be great. Thanx....AC > >> > >> If it has to do with some Vista-internal - sorry, I wouldn't know. But try > >> the following: change the WLAN-channel and see if there is an improvement. > >> This has helped me already in several situations. > >> Axel. > >> > >> > > Barb Bowman > MS Windows-MVP > http://www.microsoft.com/windowsxp/e...ts/bowman.mspx > http://blogs.digitalmediaphile.com/barb/ > |
| | #6 (permalink) |
| | Re: Wireless network signal problems Here is the connection from ipconfig..... Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Linksys Wireless-G USB Network Adapter Physical Address. . . . . . . . . : 00-12-17-89-CE-89 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::f521:3191:9466:bad1%11(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.101(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Friday, November 02, 2007 8:08:50 PM Lease Expires . . . . . . . . . . : Saturday, November 03, 2007 8:08:49 PM Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DHCPv6 IAID . . . . . . . . . . . : 150999575 DNS Servers . . . . . . . . . . . : 205.171.2.65 205.171.3.65 NetBIOS over Tcpip. . . . . . . . : Enabled "Barb Bowman" wrote: Quote: > are you using an XP driver or a Vista driver on Vista? which driver > exactly? > > posting the TEXT output of > > ipconfig /all > > from an elevated command prompt may help. > > On Fri, 2 Nov 2007 13:48:11 -0700, az_golfer > <azgolfer@xxxxxx> wrote: > Quote: > >Not the problem, have tried all the channels available, no differance. Thanx > >for the info though....AC > > > >"Axel Göller" wrote: > > Quote: > >> az_golfer typed: > >> > >> > I could use some help here. I have a dual boot computer. Had XP Pro > >> > installed for last few years, added a hard drive and installed Vista > >> > Home Premium, no issues there. My problem lies in when I boot to > >> > Vista, the signal strength of my wireless network is very low, > >> > usually 1-11 Mbps. When I boot to XP Pro, the signal is 48-54 Mbps. I > >> > am using all the same hardware, have installed all the lastest > >> > drivers from Linksys, but no change. I talked to Linksys support and > >> > thet say it is something in Vista causing the problem. I have tried > >> > everything I can think of with no luck. if anybody can help me with > >> > this issue, that would be great. Thanx....AC > >> > >> If it has to do with some Vista-internal - sorry, I wouldn't know. But try > >> the following: change the WLAN-channel and see if there is an improvement. > >> This has helped me already in several situations. > >> Axel. > >> > >> > > Barb Bowman > MS Windows-MVP > http://www.microsoft.com/windowsxp/e...ts/bowman.mspx > http://blogs.digitalmediaphile.com/barb/ > |
| | #7 (permalink) |
| | Re: Wireless network signal problems try updating the driver from device manager, update driver. the newest driver may not necessarily be from Linksys. I'd also unbind/uncheck IPv6. XP and Vista report the link speed differently. the Linksys utility reports differently that Windows native tools. If you transfer the same file from each OS, how long does it take? On Fri, 2 Nov 2007 18:36:01 -0700, az_golfer <azgolfer@xxxxxx> wrote: Quote: >I am using the XP driver in XP and the Vista driver in Vista. Both came >straight from Linksys. The XP driver version is 2.0.2.0 dated 4/13/05 and the >Vista driver is version 3.0.2.0 dated 12/27/06. Thanx for the info. Any other >ideas?....AC > >"Barb Bowman" wrote: > Quote: >> are you using an XP driver or a Vista driver on Vista? which driver >> exactly? >> >> posting the TEXT output of >> >> ipconfig /all >> >> from an elevated command prompt may help. >> >> On Fri, 2 Nov 2007 13:48:11 -0700, az_golfer >> <azgolfer@xxxxxx> wrote: >> Quote: >> >Not the problem, have tried all the channels available, no differance. Thanx >> >for the info though....AC >> > >> >"Axel Göller" wrote: >> > >> >> az_golfer typed: >> >> >> >> > I could use some help here. I have a dual boot computer. Had XP Pro >> >> > installed for last few years, added a hard drive and installed Vista >> >> > Home Premium, no issues there. My problem lies in when I boot to >> >> > Vista, the signal strength of my wireless network is very low, >> >> > usually 1-11 Mbps. When I boot to XP Pro, the signal is 48-54 Mbps. I >> >> > am using all the same hardware, have installed all the lastest >> >> > drivers from Linksys, but no change. I talked to Linksys support and >> >> > thet say it is something in Vista causing the problem. I have tried >> >> > everything I can think of with no luck. if anybody can help me with >> >> > this issue, that would be great. Thanx....AC >> >> >> >> If it has to do with some Vista-internal - sorry, I wouldn't know. But try >> >> the following: change the WLAN-channel and see if there is an improvement. >> >> This has helped me already in several situations. >> >> Axel. >> >> >> >> >> >> Barb Bowman >> MS Windows-MVP >> http://www.microsoft.com/windowsxp/e...ts/bowman.mspx >> http://blogs.digitalmediaphile.com/barb/ >> Barb Bowman MS Windows-MVP http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| Wireless network problems, Vista/XP network | Network & Sharing | |||
| Wireless signal | Vista performance & maintenance | |||
| 360 Wireless Signal Receiver + Wireless Controller | Vista Games | |||
| Power in network signal wireless (notebook acer 5570z, chip athero | Vista networking & sharing | |||
| wireless signal strength problems | Vista General | |||
