Vista - Set my Wireless as Default Connection
Old 11-03-2007   #1 (permalink)
celeste
Vista keeps trying to connect using my blackberry modem (and the blackberry
isn't even in the same room, bluetooth on my blackberry is turned off, etc.)
When this happens, I lose internet services -- even though I'm still
connected to my wireless router.
I selected the blackberry modem in Vista's network connections and
unselected "default" (which it just automatically enabled when I configured
the blackberry modem) However, it continues to try to connect using the
modem which isn't even attached, (even though I'm already connected via my
home wireless connection.) Plus, I can not select my home wireless router as
my default connection (have searched all over windows, but no place to select
it as default.)
Mostly, the problem occurs when I use IE (it isn't as bad when I browse with
firefox) but becuase of my job, I am required to use multiple browsers.
(And, my bluetooth doesn't even work on Vista, but I posted about that
problem already and have yet to find a solution to disable bluetooth.)
And, where besides here, would I report a problem with Windows Vista??
(I really dislike Vista.)
Old 11-03-2007   #2 (permalink)
Robert L. \(MS-MVP\)
Re: Set my Wireless as Default Connection
You may want to modify the gateway metric #. This link may help too.
RoutingRouting issue if the LAN and VPN are in different subnets Routing
order .... ADD Adds a route - route ADD 157.0.0.0 MASK 255.0.0.0 157.55.80.1
METRIC 3 IF 2 ...
www.chicagotech.net/routing.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"celeste" <celeste@xxxxxx> wrote in message
news:7BB89F62-5696-4CD2-A73F-83C20E887214@xxxxxx
> blackberry
> etc.)
> configured
> as
> select
> it as default.)
> with
Cannot find wireless networks/Cannot enable wireless connection Network & Sharing
Wireless connection works, cable connection does not! Vista General
Losing wireless connection to specific wireless network Vista networking & sharing
Developing a wireless connection without a wireless router. Vista networking & sharing
Blackberry Dialup connection interupts wireless connection Vista networking & sharing
