| | #2 Automatically connect to wireless on bootup To Barb, I followed your advice and here is the new thread with my problem of automatically connecting wireless on boot-up. As I mentioned in the previous thread, I borrowed another notebook which happened to have XP. It booted up and found the wireless connection right off and worked beautifully. I did it a couple of times and each time with success. You asked for the results of the ipconfig/all before I format the HD. Here it is: Microsoft Windows [Version 6.0.6000] Copyright (c) 2006 Microsoft Corporation. All rights reserved. C:\Users\Kathleen&Norm>ipconfig/all Windows IP Configuration Host Name . . . . . . . . . . . . : NormsToy Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : domain.invalid Wireless LAN adapter Wireless Network Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network Con nection Physical Address. . . . . . . . . : 00-19-D2-2E-25-87 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::9847:a675:c39:ab76%17(Preferred) Autoconfiguration IPv4 Address. . : 169.254.171.118(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . : DHCPv6 IAID . . . . . . . . . . . : 335550930 DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Local Area Connection: Connection-specific DNS Suffix . : domain.invalid Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection Physical Address. . . . . . . . . : 00-A0-D1-65-BC-85 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::196b:6a35:affd:4093%8(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : November-07-07 9:11:05 AM Lease Expires . . . . . . . . . . : November-10-07 12:30:58 PM Default Gateway . . . . . . . . . : 192.168.1.254 DHCP Server . . . . . . . . . . . : 192.168.1.254 DHCPv6 IAID . . . . . . . . . . . : 184590545 DNS Servers . . . . . . . . . . . : 192.168.1.254 192.168.1.254 NetBIOS over Tcpip. . . . . . . . : Enabled Tunnel adapter Local Area Connection* 6: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : 6TO4 Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 9: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 02-00-54-55-4E-01 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2001:0:4136:e38e:4c4:96a:3f57:febd(Prefer red) Link-local IPv6 Address . . . . . : fe80::4c4:96a:3f57:febd%9(Preferred) Default Gateway . . . . . . . . . : :: NetBIOS over Tcpip. . . . . . . . : Disabled Tunnel adapter Local Area Connection* 10: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::5efe:169.254.171.118%23(Preferred) Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 fec0:0:0:ffff::2%1 fec0:0:0:ffff::3%1 NetBIOS over Tcpip. . . . . . . . : Disabled Tunnel adapter Local Area Connection* 11: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : isatap.phub.net.cable.rogers.com Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Tunnel adapter Local Area Connection* 15: Connection-specific DNS Suffix . : domain.invalid Description . . . . . . . . . . . : isatap.domain.invalid Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.66%16(Preferred) Default Gateway . . . . . . . . . : DNS Servers . . . . . . . . . . . : 192.168.1.254 192.168.1.254 NetBIOS over Tcpip. . . . . . . . : Disabled C:\Users\Kathleen&Norm> I am getting my original disks of programs together but I won't be able to do the formatting and reinstall for a couple of days - other things get in the way! We have a long weekend this weekend, so Monday may be the best time. If I should do anything else before formatting, please let me know. Thank you so much for your direction. Norm. |
| | Re: #2 Automatically connect to wireless on bootup OK. I still think that given the malware issue and the uncertain state of your computer, it is time to format. On Fri, 9 Nov 2007 13:34:01 -0800, Norm75 <Norm75@xxxxxx> wrote: Quote: >To Barb, I followed your advice and here is the new thread with my problem of >automatically connecting wireless on boot-up. As I mentioned in the previous >thread, I borrowed another notebook which happened to have XP. It booted up >and found the wireless connection right off and worked beautifully. I did it >a couple of times and each time with success. > >You asked for the results of the ipconfig/all before I format the HD. Here >it is: > >Microsoft Windows [Version 6.0.6000] >Copyright (c) 2006 Microsoft Corporation. All rights reserved. > >C:\Users\Kathleen&Norm>ipconfig/all > >Windows IP Configuration > > Host Name . . . . . . . . . . . . : NormsToy > Primary Dns Suffix . . . . . . . : > Node Type . . . . . . . . . . . . : Hybrid > IP Routing Enabled. . . . . . . . : No > WINS Proxy Enabled. . . . . . . . : No > DNS Suffix Search List. . . . . . : domain.invalid > >Wireless LAN adapter Wireless Network Connection: > > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network >Con >nection > Physical Address. . . . . . . . . : 00-19-D2-2E-25-87 > DHCP Enabled. . . . . . . . . . . : Yes > Autoconfiguration Enabled . . . . : Yes > Link-local IPv6 Address . . . . . : fe80::9847:a675:c39:ab76%17(Preferred) > Autoconfiguration IPv4 Address. . : 169.254.171.118(Preferred) > Subnet Mask . . . . . . . . . . . : 255.255.0.0 > Default Gateway . . . . . . . . . : > DHCPv6 IAID . . . . . . . . . . . : 335550930 > DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 > fec0:0:0:ffff::2%1 > fec0:0:0:ffff::3%1 > NetBIOS over Tcpip. . . . . . . . : Enabled > >Ethernet adapter Local Area Connection: > > Connection-specific DNS Suffix . : domain.invalid > Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection > Physical Address. . . . . . . . . : 00-A0-D1-65-BC-85 > DHCP Enabled. . . . . . . . . . . : Yes > Autoconfiguration Enabled . . . . : Yes > Link-local IPv6 Address . . . . . : fe80::196b:6a35:affd:4093%8(Preferred) > IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred) > Subnet Mask . . . . . . . . . . . : 255.255.255.0 > Lease Obtained. . . . . . . . . . : November-07-07 9:11:05 AM > Lease Expires . . . . . . . . . . : November-10-07 12:30:58 PM > Default Gateway . . . . . . . . . : 192.168.1.254 > DHCP Server . . . . . . . . . . . : 192.168.1.254 > DHCPv6 IAID . . . . . . . . . . . : 184590545 > DNS Servers . . . . . . . . . . . : 192.168.1.254 > 192.168.1.254 > NetBIOS over Tcpip. . . . . . . . : Enabled > >Tunnel adapter Local Area Connection* 6: > > Media State . . . . . . . . . . . : Media disconnected > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : 6TO4 Adapter > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > DHCP Enabled. . . . . . . . . . . : No > Autoconfiguration Enabled . . . . : Yes > >Tunnel adapter Local Area Connection* 9: > > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface > Physical Address. . . . . . . . . : 02-00-54-55-4E-01 > DHCP Enabled. . . . . . . . . . . : No > Autoconfiguration Enabled . . . . : Yes > IPv6 Address. . . . . . . . . . . : >2001:0:4136:e38e:4c4:96a:3f57:febd(Prefer >red) > Link-local IPv6 Address . . . . . : fe80::4c4:96a:3f57:febd%9(Preferred) > Default Gateway . . . . . . . . . : :: > NetBIOS over Tcpip. . . . . . . . : Disabled > >Tunnel adapter Local Area Connection* 10: > > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : Microsoft ISATAP Adapter > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > DHCP Enabled. . . . . . . . . . . : No > Autoconfiguration Enabled . . . . : Yes > Link-local IPv6 Address . . . . . : >fe80::5efe:169.254.171.118%23(Preferred) > > Default Gateway . . . . . . . . . : > DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 > fec0:0:0:ffff::2%1 > fec0:0:0:ffff::3%1 > NetBIOS over Tcpip. . . . . . . . : Disabled > >Tunnel adapter Local Area Connection* 11: > > Media State . . . . . . . . . . . : Media disconnected > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : isatap.phub.net.cable.rogers.com > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > DHCP Enabled. . . . . . . . . . . : No > Autoconfiguration Enabled . . . . : Yes > >Tunnel adapter Local Area Connection* 15: > > Connection-specific DNS Suffix . : domain.invalid > Description . . . . . . . . . . . : isatap.domain.invalid > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > DHCP Enabled. . . . . . . . . . . : No > Autoconfiguration Enabled . . . . : Yes > Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.66%16(Preferred) > Default Gateway . . . . . . . . . : > DNS Servers . . . . . . . . . . . : 192.168.1.254 > 192.168.1.254 > NetBIOS over Tcpip. . . . . . . . : Disabled > >C:\Users\Kathleen&Norm> > >I am getting my original disks of programs together but I won't be able to >do the formatting and reinstall for a couple of days - other things get in >the way! We have a long weekend this weekend, so Monday may be the best time. > >If I should do anything else before formatting, please let me know. Thank >you so much for your direction. > >Norm. Barb Bowman MS Windows-MVP http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| | Re: #2 Automatically connect to wireless on bootup To Barb, it's taken this long but I called Toshiba (computer is under warranty) and took it into an authorized place here in Vancouver. They found that the wireless card was faulty. Hope to get it back tomorrow. I still want to format the hard drive as I feel I may have caused some problems with Vista OS during my trying to solve the problem. Have cleared all the data and app. progrmas. Have the recovery disks so hopefully it will go OK. I tried earlier to format but Vista wouldn't let me. Will give it another try on the weekend. Is there a "secret" to formatting with Vista? Thanks again for all your earlier help. Norm. "Barb Bowman" wrote: Quote: > OK. I still think that given the malware issue and the uncertain > state of your computer, it is time to format. > > On Fri, 9 Nov 2007 13:34:01 -0800, Norm75 > <Norm75@xxxxxx> wrote: > Quote: > >To Barb, I followed your advice and here is the new thread with my problem of > >automatically connecting wireless on boot-up. As I mentioned in the previous > >thread, I borrowed another notebook which happened to have XP. It booted up > >and found the wireless connection right off and worked beautifully. I did it > >a couple of times and each time with success. > > > >You asked for the results of the ipconfig/all before I format the HD. Here > >it is: > > > >Microsoft Windows [Version 6.0.6000] > >Copyright (c) 2006 Microsoft Corporation. All rights reserved. > > > >C:\Users\Kathleen&Norm>ipconfig/all > > > >Windows IP Configuration > > > > Host Name . . . . . . . . . . . . : NormsToy > > Primary Dns Suffix . . . . . . . : > > Node Type . . . . . . . . . . . . : Hybrid > > IP Routing Enabled. . . . . . . . : No > > WINS Proxy Enabled. . . . . . . . : No > > DNS Suffix Search List. . . . . . : domain.invalid > > > >Wireless LAN adapter Wireless Network Connection: > > > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network > >Con > >nection > > Physical Address. . . . . . . . . : 00-19-D2-2E-25-87 > > DHCP Enabled. . . . . . . . . . . : Yes > > Autoconfiguration Enabled . . . . : Yes > > Link-local IPv6 Address . . . . . : fe80::9847:a675:c39:ab76%17(Preferred) > > Autoconfiguration IPv4 Address. . : 169.254.171.118(Preferred) > > Subnet Mask . . . . . . . . . . . : 255.255.0.0 > > Default Gateway . . . . . . . . . : > > DHCPv6 IAID . . . . . . . . . . . : 335550930 > > DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 > > fec0:0:0:ffff::2%1 > > fec0:0:0:ffff::3%1 > > NetBIOS over Tcpip. . . . . . . . : Enabled > > > >Ethernet adapter Local Area Connection: > > > > Connection-specific DNS Suffix . : domain.invalid > > Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection > > Physical Address. . . . . . . . . : 00-A0-D1-65-BC-85 > > DHCP Enabled. . . . . . . . . . . : Yes > > Autoconfiguration Enabled . . . . : Yes > > Link-local IPv6 Address . . . . . : fe80::196b:6a35:affd:4093%8(Preferred) > > IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred) > > Subnet Mask . . . . . . . . . . . : 255.255.255.0 > > Lease Obtained. . . . . . . . . . : November-07-07 9:11:05 AM > > Lease Expires . . . . . . . . . . : November-10-07 12:30:58 PM > > Default Gateway . . . . . . . . . : 192.168.1.254 > > DHCP Server . . . . . . . . . . . : 192.168.1.254 > > DHCPv6 IAID . . . . . . . . . . . : 184590545 > > DNS Servers . . . . . . . . . . . : 192.168.1.254 > > 192.168.1.254 > > NetBIOS over Tcpip. . . . . . . . : Enabled > > > >Tunnel adapter Local Area Connection* 6: > > > > Media State . . . . . . . . . . . : Media disconnected > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : 6TO4 Adapter > > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > > DHCP Enabled. . . . . . . . . . . : No > > Autoconfiguration Enabled . . . . : Yes > > > >Tunnel adapter Local Area Connection* 9: > > > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface > > Physical Address. . . . . . . . . : 02-00-54-55-4E-01 > > DHCP Enabled. . . . . . . . . . . : No > > Autoconfiguration Enabled . . . . : Yes > > IPv6 Address. . . . . . . . . . . : > >2001:0:4136:e38e:4c4:96a:3f57:febd(Prefer > >red) > > Link-local IPv6 Address . . . . . : fe80::4c4:96a:3f57:febd%9(Preferred) > > Default Gateway . . . . . . . . . : :: > > NetBIOS over Tcpip. . . . . . . . : Disabled > > > >Tunnel adapter Local Area Connection* 10: > > > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : Microsoft ISATAP Adapter > > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > > DHCP Enabled. . . . . . . . . . . : No > > Autoconfiguration Enabled . . . . : Yes > > Link-local IPv6 Address . . . . . : > >fe80::5efe:169.254.171.118%23(Preferred) > > > > Default Gateway . . . . . . . . . : > > DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 > > fec0:0:0:ffff::2%1 > > fec0:0:0:ffff::3%1 > > NetBIOS over Tcpip. . . . . . . . : Disabled > > > >Tunnel adapter Local Area Connection* 11: > > > > Media State . . . . . . . . . . . : Media disconnected > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : isatap.phub.net.cable.rogers.com > > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > > DHCP Enabled. . . . . . . . . . . : No > > Autoconfiguration Enabled . . . . : Yes > > > >Tunnel adapter Local Area Connection* 15: > > > > Connection-specific DNS Suffix . : domain.invalid > > Description . . . . . . . . . . . : isatap.domain.invalid > > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 > > DHCP Enabled. . . . . . . . . . . : No > > Autoconfiguration Enabled . . . . : Yes > > Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.66%16(Preferred) > > Default Gateway . . . . . . . . . : > > DNS Servers . . . . . . . . . . . : 192.168.1.254 > > 192.168.1.254 > > NetBIOS over Tcpip. . . . . . . . : Disabled > > > >C:\Users\Kathleen&Norm> > > > >I am getting my original disks of programs together but I won't be able to > >do the formatting and reinstall for a couple of days - other things get in > >the way! We have a long weekend this weekend, so Monday may be the best time. > > > >If I should do anything else before formatting, please let me know. Thank > >you so much for your direction. > > > >Norm. > > Barb Bowman > MS Windows-MVP > http://www.microsoft.com/windowsxp/e...ts/bowman.mspx > http://blogs.digitalmediaphile.com/barb/ > |
| | Re: #2 Automatically connect to wireless on bootup typically you boot from the recovery disk and it should ask you if you want to reinstall your apps or install clean. do you get a choice? what do you see? On Thu, 22 Nov 2007 19:29:00 -0800, Norm75 <Norm75@xxxxxx> wrote: Quote: >To Barb, it's taken this long but I called Toshiba (computer is under >warranty) and took it into an authorized place here in Vancouver. They found >that the wireless card was faulty. Hope to get it back tomorrow. > >I still want to format the hard drive as I feel I may have caused some >problems with Vista OS during my trying to solve the problem. Have cleared >all the data and app. progrmas. Have the recovery disks so hopefully it will >go OK. I tried earlier to format but Vista wouldn't let me. Will give it >another try on the weekend. Is there a "secret" to formatting with Vista? > >Thanks again for all your earlier help. > >Norm. > >"Barb Bowman" wrote: > Quote: >> OK. I still think that given the malware issue and the uncertain >> state of your computer, it is time to format. >> >> On Fri, 9 Nov 2007 13:34:01 -0800, Norm75 >> <Norm75@xxxxxx> wrote: >> Quote: >> >To Barb, I followed your advice and here is the new thread with my problem of >> >automatically connecting wireless on boot-up. As I mentioned in the previous >> >thread, I borrowed another notebook which happened to have XP. It booted up >> >and found the wireless connection right off and worked beautifully. I did it >> >a couple of times and each time with success. >> > >> >You asked for the results of the ipconfig/all before I format the HD. Here >> >it is: >> > >> >Microsoft Windows [Version 6.0.6000] >> >Copyright (c) 2006 Microsoft Corporation. All rights reserved. >> > >> >C:\Users\Kathleen&Norm>ipconfig/all >> > >> >Windows IP Configuration >> > >> > Host Name . . . . . . . . . . . . : NormsToy >> > Primary Dns Suffix . . . . . . . : >> > Node Type . . . . . . . . . . . . : Hybrid >> > IP Routing Enabled. . . . . . . . : No >> > WINS Proxy Enabled. . . . . . . . : No >> > DNS Suffix Search List. . . . . . : domain.invalid >> > >> >Wireless LAN adapter Wireless Network Connection: >> > >> > Connection-specific DNS Suffix . : >> > Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network >> >Con >> >nection >> > Physical Address. . . . . . . . . : 00-19-D2-2E-25-87 >> > DHCP Enabled. . . . . . . . . . . : Yes >> > Autoconfiguration Enabled . . . . : Yes >> > Link-local IPv6 Address . . . . . : fe80::9847:a675:c39:ab76%17(Preferred) >> > Autoconfiguration IPv4 Address. . : 169.254.171.118(Preferred) >> > Subnet Mask . . . . . . . . . . . : 255.255.0.0 >> > Default Gateway . . . . . . . . . : >> > DHCPv6 IAID . . . . . . . . . . . : 335550930 >> > DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 >> > fec0:0:0:ffff::2%1 >> > fec0:0:0:ffff::3%1 >> > NetBIOS over Tcpip. . . . . . . . : Enabled >> > >> >Ethernet adapter Local Area Connection: >> > >> > Connection-specific DNS Suffix . : domain.invalid >> > Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network Connection >> > Physical Address. . . . . . . . . : 00-A0-D1-65-BC-85 >> > DHCP Enabled. . . . . . . . . . . : Yes >> > Autoconfiguration Enabled . . . . : Yes >> > Link-local IPv6 Address . . . . . : fe80::196b:6a35:affd:4093%8(Preferred) >> > IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred) >> > Subnet Mask . . . . . . . . . . . : 255.255.255.0 >> > Lease Obtained. . . . . . . . . . : November-07-07 9:11:05 AM >> > Lease Expires . . . . . . . . . . : November-10-07 12:30:58 PM >> > Default Gateway . . . . . . . . . : 192.168.1.254 >> > DHCP Server . . . . . . . . . . . : 192.168.1.254 >> > DHCPv6 IAID . . . . . . . . . . . : 184590545 >> > DNS Servers . . . . . . . . . . . : 192.168.1.254 >> > 192.168.1.254 >> > NetBIOS over Tcpip. . . . . . . . : Enabled >> > >> >Tunnel adapter Local Area Connection* 6: >> > >> > Media State . . . . . . . . . . . : Media disconnected >> > Connection-specific DNS Suffix . : >> > Description . . . . . . . . . . . : 6TO4 Adapter >> > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 >> > DHCP Enabled. . . . . . . . . . . : No >> > Autoconfiguration Enabled . . . . : Yes >> > >> >Tunnel adapter Local Area Connection* 9: >> > >> > Connection-specific DNS Suffix . : >> > Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface >> > Physical Address. . . . . . . . . : 02-00-54-55-4E-01 >> > DHCP Enabled. . . . . . . . . . . : No >> > Autoconfiguration Enabled . . . . : Yes >> > IPv6 Address. . . . . . . . . . . : >> >2001:0:4136:e38e:4c4:96a:3f57:febd(Prefer >> >red) >> > Link-local IPv6 Address . . . . . : fe80::4c4:96a:3f57:febd%9(Preferred) >> > Default Gateway . . . . . . . . . : :: >> > NetBIOS over Tcpip. . . . . . . . : Disabled >> > >> >Tunnel adapter Local Area Connection* 10: >> > >> > Connection-specific DNS Suffix . : >> > Description . . . . . . . . . . . : Microsoft ISATAP Adapter >> > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 >> > DHCP Enabled. . . . . . . . . . . : No >> > Autoconfiguration Enabled . . . . : Yes >> > Link-local IPv6 Address . . . . . : >> >fe80::5efe:169.254.171.118%23(Preferred) >> > >> > Default Gateway . . . . . . . . . : >> > DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1 >> > fec0:0:0:ffff::2%1 >> > fec0:0:0:ffff::3%1 >> > NetBIOS over Tcpip. . . . . . . . : Disabled >> > >> >Tunnel adapter Local Area Connection* 11: >> > >> > Media State . . . . . . . . . . . : Media disconnected >> > Connection-specific DNS Suffix . : >> > Description . . . . . . . . . . . : isatap.phub.net.cable.rogers.com >> > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 >> > DHCP Enabled. . . . . . . . . . . : No >> > Autoconfiguration Enabled . . . . : Yes >> > >> >Tunnel adapter Local Area Connection* 15: >> > >> > Connection-specific DNS Suffix . : domain.invalid >> > Description . . . . . . . . . . . : isatap.domain.invalid >> > Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 >> > DHCP Enabled. . . . . . . . . . . : No >> > Autoconfiguration Enabled . . . . : Yes >> > Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.66%16(Preferred) >> > Default Gateway . . . . . . . . . : >> > DNS Servers . . . . . . . . . . . : 192.168.1.254 >> > 192.168.1.254 >> > NetBIOS over Tcpip. . . . . . . . : Disabled >> > >> >C:\Users\Kathleen&Norm> >> > >> >I am getting my original disks of programs together but I won't be able to >> >do the formatting and reinstall for a couple of days - other things get in >> >the way! We have a long weekend this weekend, so Monday may be the best time. >> > >> >If I should do anything else before formatting, please let me know. Thank >> >you so much for your direction. >> > >> >Norm. >> >> Barb Bowman >> MS Windows-MVP >> http://www.microsoft.com/windowsxp/e...ts/bowman.mspx >> http://blogs.digitalmediaphile.com/barb/ >> Barb Bowman MS Windows-MVP http://www.microsoft.com/windowsxp/e...ts/bowman.mspx http://blogs.digitalmediaphile.com/barb/ |
| Will not automatically connect to wireless network | Vista networking & sharing | |||
| Automatically connect to wireless on boot-up | Vista networking & sharing | |||
| Laptop will not automatically connect to wireless | Network & Sharing | |||
| Will not automatically connect to preferred Wireless | Vista General | |||
| Connect to Wireless Network automatically | Vista networking & sharing | |||
