Vista - Dropped Internet Connnection related to Base Filtering Engine
Old 11-10-2007   #1 (permalink)
mazman
I have two hard wired PCs running Windows Vista Ultimate. Every few hours,
one of the two will drop their ability to connect to the internet "page not
found". The other will work just fine. Rebooting the PC will fix the problem,
though that's not the optimal solution. (I'm running the Trend Micro Internet
Security Antivirus/Firewall package on one machine and the Windows Firewall
on the other.)
After much trial & error, I have found that I can restablish the internet
connection by stopping and then starting the Base Filtering Engine. Is the
service is the cause of the problem or a result of it? Can/should I disable
this service?
Old 11-10-2007   #2 (permalink)
Robert L. \(MS-MVP\)
Re: Dropped Internet Connnection related to Base Filtering Engine
As we know BFE has som eissues. Have you try Vista update? Otherwise, SP1
may fix these issues.
Windows Vista Update and downloadThis update to address a set of known
application compatibility issues with Windows Vista - March 2007 Windows
Vista Application Compatibility Update ...
http://www.chicagotech.net/netforums...a5b3942f048156
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"mazman" <mazman@xxxxxx> wrote in message
news:624382D2-3F64-49AA-B19C-3C5EA1BF69C2@xxxxxx
> not
> problem,
> Internet
> Firewall
> on the other.)
> disable
> this service?
Old 11-10-2007   #3 (permalink)
mazman
I'm up to date on all the Vista Update downloand and the application
compatibility patch. It seems odd to my that I can't find any mention of this
anywhere in the Microsoft Knowledgebase. (BTW, I initially thought the
problem was with my router and I replaced it with no luck.)
> > not
> > problem,
> > Internet
> > Firewall
> > on the other.)
> > disable
> > this service?
Old 11-10-2007   #4 (permalink)
Can you try Microsoft Internet Connectivity Evaluation Tool to check any
issues?
http://www.chicagotech.net/netforums...hp?p=3548#3548
news:84183A45-E99A-4B17-A262-642AAE9A9D51@xxxxxx
> this
>> >hours,
>> > not
>> > problem,
>> > Internet
>> > Firewall
>> > on the other.)
>> > internet
>> > the
>> > disable
>> > this service?
Old 11-10-2007   #5 (permalink)
mazman
Tried that, and there were no problems. The router is a Linksys WRT54GX2
> issues?
> > this
> >> >hours,
> >> > not
> >> > problem,
> >> > Internet
> >> > Firewall
> >> > on the other.)
> >> > internet
> >> > the
> >> > disable
> >> > this service?
Old 11-10-2007   #6 (permalink)
mazman
Tried that and it passed. The router is a Linksys WRT54GX2
> issues?
> > this
> >> >hours,
> >> > not
> >> > problem,
> >> > Internet
> >> > Firewall
> >> > on the other.)
> >> > internet
> >> > the
> >> > disable
> >> > this service?
Old 11-11-2007   #7 (permalink)
Barb Bowman
out of curiosity, when a machine is in this state, what happens if
you open an elevated cmd prompt and run
ipconfig /flushdns [enter]
does this change anything?
On Sat, 10 Nov 2007 15:58:01 -0800, mazman
>> issues?
>> > this
>> >> >hours,
>> >> > not
>> >> > problem,
>> >> > Internet
>> >> > Firewall
>> >> > on the other.)
>> >> > internet
>> >> > the
>> >> > disable
>> >> > this service?
Barb Bowman
MS Windows-MVP
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
Old 11-11-2007   #8 (permalink)
mazman
I tried that, too. Does not help.
Also used Microsoft's "diagnose and repair" function. It says there is a
problem with the connection, tries to repair it by resetting the adapter, but
ultimately fails.
One other oddity: On one occasion I had a session of Virtual PC 2007 running
in a window and accessing the internet. Then my Vista internet connection
failed, but the Virtual PC connection kept going. How the heck does that
happen?
> >> issues?
> >> > this
> >> >> >hours,
> >> >> > not
> >> >> > problem,
> >> >> > Internet
> >> >> > Firewall
> >> >> > on the other.)
> >> >> > internet
> >> >> > the
> >> >> > disable
> >> >> > this service?
> Barb Bowman
> MS Windows-MVP
Old 11-12-2007   #9 (permalink)
Barb Bowman
that's weird, and to be honest, I don't know.
are any power management features turned on for these NICs? is there
data being transferred when they "stop"?
On Sun, 11 Nov 2007 07:38:00 -0800, mazman
>ultimately fails.
>happen?
>> >> issues?
>> >> > this
>> >> >> >hours,
>> >> >> > not
>> >> >> > problem,
>> >> >> > Internet
>> >> >> > Firewall
>> >> >> > on the other.)
>> >> >> > internet
>> >> >> > the
>> >> >> > disable
>> >> >> > this service?
>> Barb Bowman
>> MS Windows-MVP
Barb Bowman
MS Windows-MVP
Old 11-12-2007   #10 (permalink)
mazman
I agree that it is very weird. No power options are turned on for the NICs. I
also can't locate anything in the Event Viewer indicating a problem.
I did discover that the Internet Connection Sharing service was turned on
and that the Base Filtering Engine interacts with that service, so I turned
ICS off yesterday. Only time will tell if that's the solution to the issue.
> >ultimately fails.
> >happen?
> >> >> issues?
> >> >> > this
> >> >> >> >hours,
> >> >> >> > not
> >> >> >> > problem,
> >> >> >> > Internet
> >> >> >> > Firewall
> >> >> >> > on the other.)
> >> >> >> > internet
> >> >> >> > the
> >> >> >> > disable
> >> >> >> > this service?
> >> Barb Bowman
> >> MS Windows-MVP
> Barb Bowman
> MS Windows-MVP
Help with Windows Firewall and Base Filtering Engine Vista General
Base Filtering Engine Prevents Ethernet Connectivity Vista networking & sharing
Base Filtering Engine wont start Vista General
The Base Filtering Engine service terminated Vista security
Base Filtering Engine in Vista causing very slow DNS lookups and slow internet performance Vista security
