| | Problem PPPOE connection From Vista,a pppoe connection is created using the 'Get Connected wizard' or rasphone.exe, it shows up as a 'Dial-up connection' in the network connections folder. When you right click on the client connection created, click on Properties, it says 'Connect using Modem '. |
| | RE: Problem PPPOE connection error code: CoId={A875E3C3-01A0-49BE-B964-E5AE95EE7A4D}: The user jackie-vista\jackie dialed a connection named Broadband Connection which has failed. The error code returned on failure is 0. CoId={A875E3C3-01A0-49BE-B964-E5AE95EE7A4D}: The user jackie-vista\jackie is trying to establish a link to the Remote Access Server for the connection named Broadband Connection using the following device: Server address/Phone Number = Device = ThinkPad Modem Port = COM3 MediaType = MODEM. CoId={A875E3C3-01A0-49BE-B964-E5AE95EE7A4D}: The user jackie-vista\jackie has started dialing a Dial-up connection using a per-user connection profile named Broadband Connection. The connection settings are: Dial-in User = VpnStrategy =Not Applicable DataEncryption = Requested PrerequisiteEntry = CompartmentsEnabled = No AutoLogon = No UseRasCredentials = No CustomAuthKey = AuthRestriction Mask = 0x00000228 RasIpv4DefaultGateway = Yes Ipv4AddressAssignment = By Server Ipv4DNSServerAssignment = By Server RasIpv6DefaultGateway = Yes Ipv6DNSServerAssignment = By Server IpDnsFlags = IpNBTEnabled = No UseFlags = Internet Connection IpSecFlags = No Pre-shared key ConnectOnWinlogon = No. "jackie" wrote: Quote: > From Vista,a pppoe connection is created using the 'Get Connected wizard' or > rasphone.exe, it shows up as a 'Dial-up connection' in the network > connections folder. When you right click on the client connection created, > click on Properties, it says 'Connect using Modem '. |
| | Re: Problem PPPOE connection On 14 Lis 2007, 10:50, jackie <jac...@xxxxxx> wrote: Quote: > error code: > CoId={A875E3C3-01A0-49BE-B964-E5AE95EE7A4D}: The user jackie-vista\jackie > dialed a connection named Broadband Connection which has failed. The error > code returned on failure is 0. > > CoId={A875E3C3-01A0-49BE-B964-E5AE95EE7A4D}: The user jackie-vista\jackie is > trying to establish a link to the Remote Access Server for the connection > named Broadband Connection using the following device: > Server address/Phone Number = > Device = ThinkPad Modem > Port = COM3 > MediaType = MODEM. > > CoId={A875E3C3-01A0-49BE-B964-E5AE95EE7A4D}: The user jackie-vista\jackie > has started dialing a Dial-up connection using a per-user connection profile > named Broadband Connection. The connection settings are: > Dial-in User = > VpnStrategy =Not Applicable > DataEncryption = Requested > PrerequisiteEntry = > CompartmentsEnabled = No > AutoLogon = No > UseRasCredentials = No > CustomAuthKey = > AuthRestriction Mask = 0x00000228 > RasIpv4DefaultGateway = Yes > Ipv4AddressAssignment = By Server > Ipv4DNSServerAssignment = By Server > RasIpv6DefaultGateway = Yes > Ipv6DNSServerAssignment = By Server > IpDnsFlags = > IpNBTEnabled = No > UseFlags = Internet Connection > IpSecFlags = No Pre-shared key > ConnectOnWinlogon = No. > > "jackie" wrote: Quote: > > From Vista,a pppoe connection is created using the 'Get Connected wizard' or > > rasphone.exe, it shows up as a 'Dial-up connection' in the network > > connections folder. When you right click on the client connection created, > > click on Properties, it says 'Connect using Modem '. http://www.questpro.eu |
| Networking: Connecting to a PPPoE connection | Vista General | |||
| Cannot browse with PPPoE connection | Vista networking & sharing | |||
| I have a LAN connection, but IE wants to open my PPPoE connection | Network & Sharing | |||
| Must broadband connection be pppoe? | Vista General | |||
| Internet connection problem (PPPoE) with Vista | Vista General | |||
