| | Help me connect. I just bought a laptop with wireless and vista. I have run the networking setup wizard on my home pc, which is a hp with xp. When I put the usb into my laptop to run the setup wizard, it goes through all the steps and then says it can not complete the wizard. I have tried every setting I can think of and can not seem to connect to my pc or use the printer connected to the pc. It doesn't even show up under my network connections. I have a linksys router and am able to use the internet on my laptop, but can't seem to set up the networking. |
| | Re: Help me connect. This how to may help, Vista How toVista How to. Vista Network Sharing · Vista Printer How to · Vista VPN How to .... How to: disable Vista password protected sharing . ... http://msvistahowto.googlepages.com/ -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "pamelajoy" <pamelajoy@xxxxxx> wrote in message news:83ACE2F1-6C59-4842-8A38-5F2FC6479E84@xxxxxx Quote: >I just bought a laptop with wireless and vista. I have run the networking > setup wizard on my home pc, which is a hp with xp. When I put the usb > into > my laptop to run the setup wizard, it goes through all the steps and then > says it can not complete the wizard. I have tried every setting I can > think > of and can not seem to connect to my pc or use the printer connected to > the > pc. It doesn't even show up under my network connections. I have a > linksys > router and am able to use the internet on my laptop, but can't seem to set > up > the networking. |
| Can Connect to Router but unable to connect to internet | Vista networking & sharing | |||
| "Connect automatically" checkmark disappears from "Dial-up Connect | Vista installation & setup | |||
| "Connect automatically" checkmark disappears from "Dial-up Connect | Vista networking & sharing | |||
| Can't connect to the internet, 3rd BRAND NEW computer that work connect! HELP! | Network & Sharing | |||
| Re: Can't Connect to Juniper Network Connect 5.4.0 | Vista General | |||
