| | Cannot Network Vista Home premium ( wireless) with XP (wired) Hi There, I have been trying to make this work and I could not. I read some threads and followed the instructions and I still cannot make it work. what happens: I am not able to have a home network with a DESKTOP running Vista home premiun (wireless) with my laptop running XP professional (wired). The gateway is a wireless router. Configuration: Router act as DCP server. Vista home premium had workgroup set to WORKGROUP Vista netork discovery, File, public folder, password and printer Sharing all enabled, and Network type = Private. The SSID network has a different name Enabled ports for UDP/TCP for windows vista firewall folowing the article. Network discovery was able to find the laptop but when browsing to Network in Vista I caould not see the laptop and I am not being able to ping from Vista to XP and Vice versa. But I can ping from both to the Router Windos XP Enabled ports for TCP and UDP follwing the article Workgroup is the same and was set to WORKGROUP I Tried to see the workgroup under XP by clicking on workgroup but for some reason it came with an error saying I was did not have privileges to check the SSID Network. I hope you can help me. |
| | Re: Cannot Network Vista Home premium ( wireless) with XP (wired) Thunder wrote: Quote: > Hi There, > > I have been trying to make this work and I could not. I read some threads > and followed the instructions and I still cannot make it work. > > what happens: > > I am not able to have a home network with a DESKTOP running Vista home > premiun (wireless) with my laptop running XP professional (wired). The > gateway is a wireless router. > > Configuration: > > Router act as DCP server. > Vista home premium had workgroup set to WORKGROUP > Vista netork discovery, File, public folder, password and printer Sharing > all enabled, and Network type = Private. > The SSID network has a different name > Enabled ports for UDP/TCP for windows vista firewall folowing the article. > > Network discovery was able to find the laptop but when browsing to Network > in Vista I caould not see the laptop and I am not being able to ping from > Vista to XP and Vice versa. But I can ping from both to the Router > > Windos XP > > Enabled ports for TCP and UDP follwing the article > Workgroup is the same and was set to WORKGROUP > > I Tried to see the workgroup under XP by clicking on workgroup but for some > reason it came with an error saying I was did not have privileges to check > the SSID Network. accounts/passwords on both machines. If you wish a machine to boot directly to the Desktop (into one particular user's account) for convenience, you can do this. The instructions at this link work for both XP and Vista: Configure Windows to Automatically Login (MVP Ramesh) - http://windowsxp.mvps.org/Autologon.htm Also check to make sure firewalls are configured correctly: Configure firewalls on all machines to allow the Local Area Network (LAN) traffic as trusted. With Windows Firewall, this means allowing File/Printer Sharing on the Exceptions tab. Normally running the Network Setup Wizard on XP will take care of this for those machines.The only "gotcha" is that this will turn on the XPSP2 Windows Firewall. If you aren't running a third-party firewall or have an antivirus with "Internet Worm Protection" (like Norton 2006/07) which acts as a firewall, then you're fine. With third-party firewalls, I usually configure the LAN allowance with an IP range. Ex. would be 192.168.1.0-192.168.1.254. Obviously you would substitute your correct subnet. Do not run more than one firewall. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: Cannot Network Vista Home premium ( wireless) with XP (wired) Sorry since when I need to have the same accounts ? I never use accounts. And yes Firewalls are configured in the proper range..... "Malke" wrote: Quote: > Thunder wrote: Quote: > > Hi There, > > > > I have been trying to make this work and I could not. I read some threads > > and followed the instructions and I still cannot make it work. > > > > what happens: > > > > I am not able to have a home network with a DESKTOP running Vista home > > premiun (wireless) with my laptop running XP professional (wired). The > > gateway is a wireless router. > > > > Configuration: > > > > Router act as DCP server. > > Vista home premium had workgroup set to WORKGROUP > > Vista netork discovery, File, public folder, password and printer Sharing > > all enabled, and Network type = Private. > > The SSID network has a different name > > Enabled ports for UDP/TCP for windows vista firewall folowing the article. > > > > Network discovery was able to find the laptop but when browsing to Network > > in Vista I caould not see the laptop and I am not being able to ping from > > Vista to XP and Vice versa. But I can ping from both to the Router > > > > Windos XP > > > > Enabled ports for TCP and UDP follwing the article > > Workgroup is the same and was set to WORKGROUP > > > > I Tried to see the workgroup under XP by clicking on workgroup but for some > > reason it came with an error saying I was did not have privileges to check > > the SSID Network. > The name of the SSID is irrelevant. Create identical user > accounts/passwords on both machines. If you wish a machine to boot > directly to the Desktop (into one particular user's account) for > convenience, you can do this. The instructions at this link work for > both XP and Vista: > > Configure Windows to Automatically Login (MVP Ramesh) - > http://windowsxp.mvps.org/Autologon.htm > > Also check to make sure firewalls are configured correctly: > > Configure firewalls on all machines to allow the Local Area Network > (LAN) traffic as trusted. With Windows Firewall, this means allowing > File/Printer Sharing on the Exceptions tab. Normally running the Network > Setup Wizard on XP will take care of this for those machines.The only > "gotcha" is that this will turn on the XPSP2 Windows Firewall. If you > aren't running a third-party firewall or have an antivirus with > "Internet Worm Protection" (like Norton 2006/07) which acts as a > firewall, then you're fine. With third-party firewalls, I usually > configure the LAN allowance with an IP range. Ex. would be > 192.168.1.0-192.168.1.254. Obviously you would substitute your correct > subnet. Do not run more than one firewall. > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| | Re: Cannot Network Vista Home premium ( wireless) with XP (wired) "Thunder" wrote ... Quote: > > I have been trying to make this work and I could not. I read some threads > and followed the instructions and I still cannot make it work. > > what happens: > > I am not able to have a home network with a DESKTOP running Vista home > premiun (wireless) with my laptop running XP professional (wired). The > gateway is a wireless router. > > Configuration: > > Router act as DCP server. > Vista home premium had workgroup set to WORKGROUP > Vista netork discovery, File, public folder, password and printer Sharing > all enabled, and Network type = Private. > The SSID network has a different name > Enabled ports for UDP/TCP for windows vista firewall folowing the article. > > Network discovery was able to find the laptop but when browsing to > Network > in Vista I caould not see the laptop and I am not being able to ping from > Vista to XP and Vice versa. But I can ping from both to the Router > > Windos XP > > Enabled ports for TCP and UDP follwing the article > Workgroup is the same and was set to WORKGROUP > > I Tried to see the workgroup under XP by clicking on workgroup but for > some > reason it came with an error saying I was did not have privileges to check > the SSID Network. > want to do and it's working fine. (except for the syncing!!!) The important thing is to ensure both computers have exactly the same name for the network and the router name/details are the same in both. I found I had to make the Network type ..public. It only means it's public on your network which is what you want. -- Regards Bob Hobden |
| | Re: Cannot Network Vista Home premium ( wireless) with XP (wired) Thunder wrote: Quote: > Sorry since when I need to have the same accounts ? > > I never use accounts. > > And yes Firewalls are configured in the proper range..... multi-user operating system, no matter if only one person is using it. In all multi-user operating systems - NT, Win2k, XP, Vista, Unix, Linux, Mac OSX - there is the one built-in account that is "god" on the system. In Windows terminology, that is "Administrator". In the *nix world, it is "root". This is a necessary account and is not normally used in everyday work. You cannot delete the built-in Administrator account nor would you ever want to. In fact, in Vista it is disabled by default. Then you have user accounts which may or may not have administrative privileges. Go to Control Panel>User Accounts and look at the name of the user accounts on both machines. If you have OEM machines (Dell, HP, etc.) and never set up a user account yourself, the user account will be something like HP_Administrator or Owner. For ease of networking, assign a password to this account and then use control userpasswords2 per the link I already gave you to set automatic log into the desired user account. Then create the identical user account and password on both machines. Note: Because the built-in Administrator account is disabled by default in Vista, it is wise to create at least one extra user account with administrative privileges along with your standard user account that you will be in for most of your computing life. You may never log into the extra account but if you need it in an emergency, you will be glad you were smart enough to create it ahead of time. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| VISTA Home Premium HP Pavilion a6120n, Limited or No Connectivity wired network | Network & Sharing | |||
| Access wired home network via wireless router. | Vista networking & sharing | |||
| Home Network setup with BOTH wireless and wired computers | Vista networking & sharing | |||
| Network wireless Vista and wired XP | Vista networking & sharing | |||
| Wired & Wireless Combo Home Network | Vista networking & sharing | |||
