| | 2 network card don't work help Hi, I moved from a XP 64 sitem with 2 NIC ( one for the external IP and one for the intrenal ) to a new Vista 64, but I'm not able to have both card working. If I enable both card I can't go in internet, if I disable the internal one Internet works fine but I lose the internal Lan. I use the same setting as I have in the Old PC, any one have some ideas ?? Thanks, Palol |
| | Re: 2 network card don't work help Posting the result of ipconfig /all here may help. -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "paolol" <paolol@xxxxxx> wrote in message news:uaF45vwOIHA.5980@xxxxxx Quote: > Hi, I moved from a XP 64 sitem with 2 NIC ( one for the external IP and > one for the intrenal ) to a new Vista 64, but I'm not able to have both > card working. > If I enable both card I can't go in internet, if I disable the internal > one Internet works fine but I lose the internal Lan. > I use the same setting as I have in the Old PC, any one have some ideas ?? > Thanks, > Palol |
| | Re: 2 network card don't work help I am having the same issue as Paolol. I have two networks that I need to connect to simultaneously. One provides internet, the other is internal. I am able to do this just fine on XP Pro. Here is my ipconfig settings: Microsoft Windows [Version 6.0.6000] Copyright (c) 2006 Microsoft Corporation. All rights reserved. C:\Users\Mark>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : Shop_Mobile Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No Wireless LAN adapter Wireless Network Connection 4: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : NETGEAR WG111v2 54Mbps Wireless USB 2.0 A dapter #2 Physical Address. . . . . . . . . : 00-18-4D-FE-03-2F DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Wireless LAN adapter Wireless Network Connection: Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Dell Wireless 1390 WLAN Mini-Card Physical Address. . . . . . . . . : 00-1C-26-4A-44-E7 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::f1ed:e118:b1ff:de62%10(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.1.109(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Monday, December 10, 2007 10:54:34 AM Lease Expires . . . . . . . . . . : Tuesday, December 11, 2007 10:54:33 AM Default Gateway . . . . . . . . . : fe80::4c27:f26c:14ed:6286%10 192.168.1.10 DHCP Server . . . . . . . . . . . : 192.168.1.10 DHCPv6 IAID . . . . . . . . . . . : 167779366 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-0E-67-57-16-00-1C-23-85-D9-57 DNS Servers . . . . . . . . . . . : fe80::4c27:f26c:14ed:6286%10 205.171.3.65 205.171.2.65 NetBIOS over Tcpip. . . . . . . . : Enabled Ethernet adapter Local Area Connection: Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controlle r Physical Address. . . . . . . . . : 00-1C-23-85-D9-57 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes "Robert L. (MS-MVP)" wrote: Quote: > Posting the result of ipconfig /all here may help. > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > > > "paolol" <paolol@xxxxxx> wrote in message > news:uaF45vwOIHA.5980@xxxxxx Quote: > > Hi, I moved from a XP 64 sitem with 2 NIC ( one for the external IP and > > one for the intrenal ) to a new Vista 64, but I'm not able to have both > > card working. > > If I enable both card I can't go in internet, if I disable the internal > > one Internet works fine but I lose the internal Lan. > > I use the same setting as I have in the Old PC, any one have some ideas ?? > > Thanks, > > Palol |
| | Re: 2 network card don't work help Ethernet adapter Local Area Connection is disconnected. Media State . . . . . . . . . . . : Media disconnected We need to check status of both LANs. -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Michael" <Michael@xxxxxx> wrote in message news:417FBDA4-CFD4-464F-8687-1B45721C5769@xxxxxx Quote: >I am having the same issue as Paolol. I have two networks that I need to > connect to simultaneously. One provides internet, the other is internal. > I > am able to do this just fine on XP Pro. Here is my ipconfig settings: > > Microsoft Windows [Version 6.0.6000] > Copyright (c) 2006 Microsoft Corporation. All rights reserved. > > C:\Users\Mark>ipconfig /all > > Windows IP Configuration > > Host Name . . . . . . . . . . . . : Shop_Mobile > Primary Dns Suffix . . . . . . . : > Node Type . . . . . . . . . . . . : Hybrid > IP Routing Enabled. . . . . . . . : No > WINS Proxy Enabled. . . . . . . . : No > > Wireless LAN adapter Wireless Network Connection 4: > > Media State . . . . . . . . . . . : Media disconnected > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : NETGEAR WG111v2 54Mbps Wireless USB > 2.0 A > dapter #2 > Physical Address. . . . . . . . . : 00-18-4D-FE-03-2F > DHCP Enabled. . . . . . . . . . . : Yes > Autoconfiguration Enabled . . . . : Yes > > Wireless LAN adapter Wireless Network Connection: > > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : Dell Wireless 1390 WLAN Mini-Card > Physical Address. . . . . . . . . : 00-1C-26-4A-44-E7 > DHCP Enabled. . . . . . . . . . . : Yes > Autoconfiguration Enabled . . . . : Yes > Link-local IPv6 Address . . . . . : > fe80::f1ed:e118:b1ff:de62%10(Preferred) > IPv4 Address. . . . . . . . . . . : 192.168.1.109(Preferred) > Subnet Mask . . . . . . . . . . . : 255.255.255.0 > Lease Obtained. . . . . . . . . . : Monday, December 10, 2007 10:54:34 > AM > Lease Expires . . . . . . . . . . : Tuesday, December 11, 2007 10:54:33 > AM > Default Gateway . . . . . . . . . : fe80::4c27:f26c:14ed:6286%10 > 192.168.1.10 > DHCP Server . . . . . . . . . . . : 192.168.1.10 > DHCPv6 IAID . . . . . . . . . . . : 167779366 > DHCPv6 Client DUID. . . . . . . . : > 00-01-00-01-0E-67-57-16-00-1C-23-85-D9-57 > > DNS Servers . . . . . . . . . . . : fe80::4c27:f26c:14ed:6286%10 > 205.171.3.65 > 205.171.2.65 > NetBIOS over Tcpip. . . . . . . . : Enabled > > Ethernet adapter Local Area Connection: > > Media State . . . . . . . . . . . : Media disconnected > Connection-specific DNS Suffix . : > Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated > Controlle > r > Physical Address. . . . . . . . . : 00-1C-23-85-D9-57 > DHCP Enabled. . . . . . . . . . . : No > Autoconfiguration Enabled . . . . : Yes > > > "Robert L. (MS-MVP)" wrote: > Quote: >> Posting the result of ipconfig /all here may help. >> >> -- >> Bob Lin, MS-MVP, MCSE & CNE >> Networking, Internet, Routing, VPN Troubleshooting on >> http://www.ChicagoTech.net >> How to Setup Windows, Network, VPN & Remote Access on >> http://www.HowToNetworking.com >> >> >> "paolol" <paolol@xxxxxx> wrote in message >> news:uaF45vwOIHA.5980@xxxxxx Quote: >> > Hi, I moved from a XP 64 sitem with 2 NIC ( one for the external IP and >> > one for the intrenal ) to a new Vista 64, but I'm not able to have both >> > card working. >> > If I enable both card I can't go in internet, if I disable the internal >> > one Internet works fine but I lose the internal Lan. >> > I use the same setting as I have in the Old PC, any one have some ideas >> > ?? >> > Thanks, >> > Palol |
| | Re: 2 network card don't work help Hi, this are mine ---- Scheda Ethernet Rete Esterna: Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : Realtek RTL8139/810x Family Fast Ethernet NIC Indirizzo fisico. . . . . . . . . . . : 00-40-F4-79-6F-8E DHCP abilitato. . . . . . . . . . . . : No Configurazione automatica abilitata : SŤ Indirizzo IPv4. . . . . . . . . . . . : 82.187.159.xxx(Preferenziale) Subnet mask . . . . . . . . . . . . . : 255.255.255.240 Gateway predefinito . . . . . . . . . : 82.187.159.xxx Server DNS . . . . . . . . . . . . . : 208.67.222.222 212.216.112.112 NetBIOS su TCP/IP . . . . . . . . . . : Disattivato Scheda Ethernet rete Interna: Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : NVIDIA nForce Networking Controller Indirizzo fisico. . . . . . . . . . . : 00-18-F3-FD-14-1E DHCP abilitato. . . . . . . . . . . . : No Configurazione automatica abilitata : SŤ Indirizzo IPv4. . . . . . . . . . . . : 192.168.0.32(Preferenziale) Subnet mask . . . . . . . . . . . . . : 255.255.255.0 Indirizzo IPv4. . . . . . . . . . . . : 192.168.2.32(Preferenziale) Subnet mask . . . . . . . . . . . . . : 255.255.255.0 Gateway predefinito . . . . . . . . . : 192.168.2.1 Server DNS . . . . . . . . . . . . . : 192.168.0.208 208.67.222.222 Server WINS primario . . . . . . . . : 192.168.0.208 NetBIOS su TCP/IP . . . . . . . . . . : Attivato Scheda Ethernet Hamachi: Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : Hamachi Network Interface Indirizzo fisico. . . . . . . . . . . : 7A-79-05-0D-97-6C DHCP abilitato. . . . . . . . . . . . : SŤ Configurazione automatica abilitata : SŤ Indirizzo IPv4. . . . . . . . . . . . : 5.xxx.xxx.xxx(Preferenziale) Subnet mask . . . . . . . . . . . . . : 255.0.0.0 Lease ottenuto. . . . . . . . . . . . : lunedŤ 10 dicembre 2007 9.50.34 Scadenza lease . . . . . . . . . . . : martedŤ 11 dicembre 2007 11.10.09 Gateway predefinito . . . . . . . . . : 5.0.0.1 Server DHCP . . . . . . . . . . . . . : 5.0.0.1 NetBIOS su TCP/IP . . . . . . . . . . : Attivato Scheda Tunnel Connessione alla rete locale (LAN)*: Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : Microsoft ISATAP Adapter Indirizzo fisico. . . . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP abilitato. . . . . . . . . . . . : No Configurazione automatica abilitata : SŤ Indirizzo IPv6 locale rispetto al collegamento . : fe80::5efe:192.168.0.32%18(Preferenziale) Indirizzo IPv6 locale rispetto al collegamento . : fe80::5efe:192.168.2.32%18(Preferenziale) Gateway predefinito . . . . . . . . . : Server DNS . . . . . . . . . . . . . : 192.168.0.208 208.67.222.222 NetBIOS su TCP/IP . . . . . . . . . . : Disattivato Scheda Tunnel Connessione alla rete locale (LAN)* 2: Suffisso DNS specifico per connessione: Descrizione . . . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Indirizzo fisico. . . . . . . . . . . : 02-00-54-55-4E-01 DHCP abilitato. . . . . . . . . . . . : No Configurazione automatica abilitata : SŤ Indirizzo IPv6 . . . . . . . . . . . . . . . . . : 2001:0:4136:e390:388a:15c2:3f57:fddf(Preferenziale) Indirizzo IPv6 locale rispetto al collegamento . : fe80::388a:15c2:3f57:fddf%9(Preferenziale) Gateway predefinito . . . . . . . . . : NetBIOS su TCP/IP . . . . . . . . . . : Disattivato --- thanks, Paolol |
| | #6 (permalink) |
| | Re: 2 network card don't work help When I connect to one, the other goes disconnected. When I then connect to the other, the first shows disconnected. The problem is that I am not able to connect to both at the same time. "Robert L. (MS-MVP)" wrote: Quote: > Ethernet adapter Local Area Connection is disconnected. > > Media State . . . . . . . . . . . : Media disconnected > > We need to check status of both LANs. > > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > > > "Michael" <Michael@xxxxxx> wrote in message > news:417FBDA4-CFD4-464F-8687-1B45721C5769@xxxxxx Quote: > >I am having the same issue as Paolol. I have two networks that I need to > > connect to simultaneously. One provides internet, the other is internal. > > I > > am able to do this just fine on XP Pro. Here is my ipconfig settings: > > > > Microsoft Windows [Version 6.0.6000] > > Copyright (c) 2006 Microsoft Corporation. All rights reserved. > > > > C:\Users\Mark>ipconfig /all > > > > Windows IP Configuration > > > > Host Name . . . . . . . . . . . . : Shop_Mobile > > Primary Dns Suffix . . . . . . . : > > Node Type . . . . . . . . . . . . : Hybrid > > IP Routing Enabled. . . . . . . . : No > > WINS Proxy Enabled. . . . . . . . : No > > > > Wireless LAN adapter Wireless Network Connection 4: > > > > Media State . . . . . . . . . . . : Media disconnected > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : NETGEAR WG111v2 54Mbps Wireless USB > > 2.0 A > > dapter #2 > > Physical Address. . . . . . . . . : 00-18-4D-FE-03-2F > > DHCP Enabled. . . . . . . . . . . : Yes > > Autoconfiguration Enabled . . . . : Yes > > > > Wireless LAN adapter Wireless Network Connection: > > > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : Dell Wireless 1390 WLAN Mini-Card > > Physical Address. . . . . . . . . : 00-1C-26-4A-44-E7 > > DHCP Enabled. . . . . . . . . . . : Yes > > Autoconfiguration Enabled . . . . : Yes > > Link-local IPv6 Address . . . . . : > > fe80::f1ed:e118:b1ff:de62%10(Preferred) > > IPv4 Address. . . . . . . . . . . : 192.168.1.109(Preferred) > > Subnet Mask . . . . . . . . . . . : 255.255.255.0 > > Lease Obtained. . . . . . . . . . : Monday, December 10, 2007 10:54:34 > > AM > > Lease Expires . . . . . . . . . . : Tuesday, December 11, 2007 10:54:33 > > AM > > Default Gateway . . . . . . . . . : fe80::4c27:f26c:14ed:6286%10 > > 192.168.1.10 > > DHCP Server . . . . . . . . . . . : 192.168.1.10 > > DHCPv6 IAID . . . . . . . . . . . : 167779366 > > DHCPv6 Client DUID. . . . . . . . : > > 00-01-00-01-0E-67-57-16-00-1C-23-85-D9-57 > > > > DNS Servers . . . . . . . . . . . : fe80::4c27:f26c:14ed:6286%10 > > 205.171.3.65 > > 205.171.2.65 > > NetBIOS over Tcpip. . . . . . . . : Enabled > > > > Ethernet adapter Local Area Connection: > > > > Media State . . . . . . . . . . . : Media disconnected > > Connection-specific DNS Suffix . : > > Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated > > Controlle > > r > > Physical Address. . . . . . . . . : 00-1C-23-85-D9-57 > > DHCP Enabled. . . . . . . . . . . : No > > Autoconfiguration Enabled . . . . : Yes > > > > > > "Robert L. (MS-MVP)" wrote: > > Quote: > >> Posting the result of ipconfig /all here may help. > >> > >> -- > >> Bob Lin, MS-MVP, MCSE & CNE > >> Networking, Internet, Routing, VPN Troubleshooting on > >> http://www.ChicagoTech.net > >> How to Setup Windows, Network, VPN & Remote Access on > >> http://www.HowToNetworking.com > >> > >> > >> "paolol" <paolol@xxxxxx> wrote in message > >> news:uaF45vwOIHA.5980@xxxxxx > >> > Hi, I moved from a XP 64 sitem with 2 NIC ( one for the external IP and > >> > one for the intrenal ) to a new Vista 64, but I'm not able to have both > >> > card working. > >> > If I enable both card I can't go in internet, if I disable the internal > >> > one Internet works fine but I lose the internal Lan. > >> > I use the same setting as I have in the Old PC, any one have some ideas > >> > ?? > >> > Thanks, > >> > Palol > >> |
| Can not get graphics card to work- help | Graphic cards | |||
| Trouble getting Hyper-V Virtual Network to work with second Network Adapter | Virtual Server | |||
| Network discovery desn't work on my private network | Vista networking & sharing | |||
| PCI parallel card can not work | Vista hardware & devices | |||
| will this card work with vista | Vista installation & setup | |||
