Vista - switching from wireless to wired networking does not work
Old 12-10-2007   #1 (permalink)
dna86
With XP, I could be working on wireless, then plug in an ethernet cable and
traffic instantly switches over to the faster wired network. With Vista, this
does not work. Plugging in a wired cable does not switch the traffic. I have
to disable the wireless connection and restart explorer. Is there a way to
get this to work? Is it a security issue?
Old 12-11-2007   #2 (permalink)
Robert L. \(MS-MVP\)
Re: switching from wireless to wired networking does not work
You may need to modify the router metric. Posting the result of routing
table here my help.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"dna86" <dna86@xxxxxx> wrote in message
news:7AFAE03A-BC01-4607-930C-EF73E591B1CC@xxxxxx
> and
> this
> have
Old 12-11-2007   #3 (permalink)
dna86
The metric values for the two cards are the same. Here is a copy of the route
table:
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.149 20
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.145 20
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.0.0 255.255.255.0 On-link 192.168.0.149 276
192.168.0.0 255.255.255.0 On-link 192.168.0.145 276
192.168.0.145 255.255.255.255 On-link 192.168.0.145 276
192.168.0.149 255.255.255.255 On-link 192.168.0.149 276
192.168.0.255 255.255.255.255 On-link 192.168.0.149 276
192.168.0.255 255.255.255.255 On-link 192.168.0.145 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.0.149 276
224.0.0.0 240.0.0.0 On-link 192.168.0.145 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.0.149 276
255.255.255.255 255.255.255.255 On-link 192.168.0.145 276
Is it possible to set something in the registry so the wired adapter gets a
lower metric?
"Robert L. (MS-MVP)" wrote:
> table here my help.
> > and
> > this
> > have
Old 12-14-2007   #4 (permalink)
This search result may help.
RoutingRoute command and examples Routing issue if the LAN and VPN are in
different subnets Routing order .... Network Destination Netmask Gateway
Interface Metric ...
www.chicagotech.net/routing.htm
news:E8D50328-1213-4F66-9CA9-1DA23D8CC825@xxxxxx
> route
> table:
> IPv4 Route Table
> Active Routes:
> Metric
> a
> lower metric?
>> table here my help.
>> > and
>> > Vista,
>> > this
>> > have
>> > to
Switching from wireless to wired on desktop Network & Sharing
Wireless/Wired networking? Vista networking & sharing
Vista wirelss networking no work, wired networking works Vista networking & sharing
Problems switching wireless and wired network connections Vista networking & sharing
Wireless and Wired Networking help Vista networking & sharing
