| | Dual Lan but one ethernet cable problem Hey! I have dual lan on my motherboard and sometime when vista boots up the netwrok wont connect ot the internet, vista says plug the cable into the other port, so i do, and it works. but i have to do this evrey other time i boot up and its getting annoying. is there any way i can fix this problem? The LAN should work if an ethernet cable is plugged into it and not have to switch it around a lot Thanks! |
| | Re: Dual Lan but one ethernet cable problem If you disable one of ports, does that fix the problem? -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Bios Nova" <BiosNova@xxxxxx> wrote in message news:EAD650A8-D6BF-41D2-9EA2-877D4DB50CEA@xxxxxx Quote: > Hey! > > I have dual lan on my motherboard and sometime when vista boots up the > netwrok wont connect ot the internet, vista says plug the cable into the > other port, so i do, and it works. but i have to do this evrey other time > i > boot up and its getting annoying. is there any way i can fix this problem? > > The LAN should work if an ethernet cable is plugged into it and not have > to > switch it around a lot > > Thanks! |
| | Re: Dual Lan but one ethernet cable problem How do i go about disabling one of the ports? "Robert L. (MS-MVP)" wrote: Quote: > If you disable one of ports, does that fix the problem? > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > > > "Bios Nova" <BiosNova@xxxxxx> wrote in message > news:EAD650A8-D6BF-41D2-9EA2-877D4DB50CEA@xxxxxx Quote: > > Hey! > > > > I have dual lan on my motherboard and sometime when vista boots up the > > netwrok wont connect ot the internet, vista says plug the cable into the > > other port, so i do, and it works. but i have to do this evrey other time > > i > > boot up and its getting annoying. is there any way i can fix this problem? > > > > The LAN should work if an ethernet cable is plugged into it and not have > > to > > switch it around a lot > > > > Thanks! |
| Vista home premium 64 bit | Re: Dual Lan but one ethernet cable problem When you switch on your computer press the del key as it is in the memory test area. This will put you into your bios. You will have control over what parts of the motherboard are turned on and off. Refer to your manual if you have one. This will also free a small amount of resources. |
| | Re: Dual Lan but one ethernet cable problem Open Network and Sharing center. Select Manage network connections. Right click on one of connection, and then select disable. -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Bios Nova" <BiosNova@xxxxxx> wrote in message news:A0C09617-7A54-4F3A-B302-5817A83B61E9@xxxxxx Quote: > How do i go about disabling one of the ports? > > "Robert L. (MS-MVP)" wrote: > Quote: >> If you disable one of ports, does that fix the problem? >> >> -- >> Bob Lin, MS-MVP, MCSE & CNE >> Networking, Internet, Routing, VPN Troubleshooting on >> http://www.ChicagoTech.net >> How to Setup Windows, Network, VPN & Remote Access on >> http://www.HowToNetworking.com >> >> >> "Bios Nova" <BiosNova@xxxxxx> wrote in message >> news:EAD650A8-D6BF-41D2-9EA2-877D4DB50CEA@xxxxxx Quote: >> > Hey! >> > >> > I have dual lan on my motherboard and sometime when vista boots up the >> > netwrok wont connect ot the internet, vista says plug the cable into >> > the >> > other port, so i do, and it works. but i have to do this evrey other >> > time >> > i >> > boot up and its getting annoying. is there any way i can fix this >> > problem? >> > >> > The LAN should work if an ethernet cable is plugged into it and not >> > have >> > to >> > switch it around a lot >> > >> > Thanks! |
| | #6 (permalink) |
| | Re: Dual Lan but one ethernet cable problem ok i did that. it seems to be working now but it might happen agian (the problem has been known to go away for a while then come back) ill post back if it comes back. Thanks "Robert L. (MS-MVP)" wrote: Quote: > Open Network and Sharing center. Select Manage network connections. Right > click on one of connection, and then select disable. > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > > > "Bios Nova" <BiosNova@xxxxxx> wrote in message > news:A0C09617-7A54-4F3A-B302-5817A83B61E9@xxxxxx Quote: > > How do i go about disabling one of the ports? > > > > "Robert L. (MS-MVP)" wrote: > > Quote: > >> If you disable one of ports, does that fix the problem? > >> > >> -- > >> Bob Lin, MS-MVP, MCSE & CNE > >> Networking, Internet, Routing, VPN Troubleshooting on > >> http://www.ChicagoTech.net > >> How to Setup Windows, Network, VPN & Remote Access on > >> http://www.HowToNetworking.com > >> > >> > >> "Bios Nova" <BiosNova@xxxxxx> wrote in message > >> news:EAD650A8-D6BF-41D2-9EA2-877D4DB50CEA@xxxxxx > >> > Hey! > >> > > >> > I have dual lan on my motherboard and sometime when vista boots up the > >> > netwrok wont connect ot the internet, vista says plug the cable into > >> > the > >> > other port, so i do, and it works. but i have to do this evrey other > >> > time > >> > i > >> > boot up and its getting annoying. is there any way i can fix this > >> > problem? > >> > > >> > The LAN should work if an ethernet cable is plugged into it and not > >> > have > >> > to > >> > switch it around a lot > >> > > >> > Thanks! > >> |
| | #7 (permalink) |
| Vista home premium 64 bit | Re: Dual Lan but one ethernet cable problem I dont think it will come back. It can only use the ports that are enabled. |
| Cannot connect to internet using Ethernet Cable but can connect with USB cable | Network & Sharing | |||
| Should unplug my ethernet cable to format? | General Discussion | |||
| Ethernet cable question. | Vista General | |||
| Ethernet cable + system process bug | Vista hardware & devices | |||
| Blue screen after plugging in ethernet cable | Vista hardware & devices | |||
