Vista - PC will not connect
Old 12-15-2007   #1 (permalink)
Daniel
PC will not connect
Hi
I have Vista Ultimate networked to a XP Pro PC, the Network is visible on
both PC's, and I can access
the XP Pro fully from the Vista PC and I can access the Vista second hard
drive fully from the XP PC,
but when I try to access the C: Drive on the Vista PC from the XP PC I can
a message that I do not
have permisssion.
I have the same permissions set for both drives on the Vista PC, that is
full access to everything by all user,
only one on each PC.
Is there a setting I may be missing?
I have UAC turned off.
thanks
Daniel
Old 12-15-2007   #2 (permalink)
Robert L. \(MS-MVP\)
Re: PC will not connect
In the C drive, also check the Security tab and make sure everyone has write
permission. This link may help too. Please post back with the result.
Vista Permission IssuesCan I assume the external drive used to be connecting
to other computer and you just re-connect it the the Vista? Check the
permission using this command: . ...
www.chicagotech.net/vista/vistapermission.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"Daniel" <noone@xxxxxx> wrote in message
news:eFnVh91PIHA.3676@xxxxxx
Quote:
> Hi
> can a message that I do not
> have permisssion.
> thanks
> Daniel
Old 12-16-2007   #3 (permalink)
Daniel
Bob
thanks for the advice and link, you got got in one, it
was the User Permissions in the security tab.
Thanks for your help
regards
Daniel
"Robert L. (MS-MVP)" <noreply@xxxxxx> wrote in message
news:F90DB701-DBFE-4263-A042-AF97A8FABE63@xxxxxx
> write permission. This link may help too. Please post back with the
> result.
> connecting to other computer and you just re-connect it the the Vista?
> Check the permission using this command: . ...
Quote:
>> Hi
>> have permisssion.
>> thanks
>> Daniel
Old 12-16-2007   #4 (permalink)
Thank you for the update.
news:O6SexD6PIHA.536@xxxxxx
Quote:
> Bob
> regards
> Daniel
>> result.
Quote:
>>> Hi
>>> on both PC's, and I can access
>>> hard drive fully from the XP PC,
>>> have permisssion.
>>> thanks
>>> Daniel
Can Connect to Router but unable to connect to internet Vista networking & sharing
"Connect automatically" checkmark disappears from "Dial-up Connect Vista installation & setup
"Connect automatically" checkmark disappears from "Dial-up Connect Vista networking & sharing
Can't connect to the internet, 3rd BRAND NEW computer that work connect! HELP! Network & Sharing
Re: Can't Connect to Juniper Network Connect 5.4.0 Vista General
