Vista - wired network problems
Old 01-08-2008   #1 (permalink)
fiery
I have a wired network with a broadband router attached. I have an XP
computer and a Vista Home premium computer on it. Recently I have tried to
add a new computer that runs Vista Home Ultimate on it. The linksys set up
program shows that it is attached to the network, but the internet nor file
sharing work. After speding a hour with Linksys tech, they determined that
there is something in the Vista version that last computer has that won't let
it work on the network. Even pings to the router are unsucessful. Anyone
have any ideas what I can do to fix this?
Old 01-08-2008   #2 (permalink)
Robert L. \(MS-MVP\)
Re: wired network problems
Posting the result of ipconfig /all here may help.
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"fiery" <fiery@xxxxxx> wrote in message
news:75235898-877B-45CF-9E01-F9C8727F8348@xxxxxx
> to
> up
> file
> that
> let
Old 01-09-2008   #3 (permalink)
fiery
Here is the results of ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : BOS-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : NVIDIA nForce Networking Controller
Physical Address. . . . . . . . . : 00-1A-92-40-EC-82
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::9dd6:de56:ccf8:55e%8(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.102(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Wednesday, January 09, 2008 7:19:19 PM
Lease Expires . . . . . . . . . . : Friday, January 11, 2008 7:19:18 PM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 201333394
DNS Servers . . . . . . . . . . . : 204.127.203.135
216.148.225.135
NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
isatap.{66FB05C3-26A1-4D96-955F-F3C3D4EB9
3B0}
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Link-local IPv6 Address . . . . . : fe80::5efe:192.168.1.102%10(Preferred)
216.148.225.135
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
IPv6 Address. . . . . . . . . . . :
2001:0:4137:9e50:24c6:35b5:3f57:fe99(Pref
erred)
Link-local IPv6 Address . . . . . : fe80::24c6:35b5:3f57:fe99%9(Preferred)
Default Gateway . . . . . . . . . : ::
Today to further run a check I took the xp computer off the network and
reconnected it on the network cable running to the vista ulitmate computer,
the XP computer worked fine. I then put the vista ultimate machine in the XP
computers spot and it appeared to work as well. I then ran free speed tests
on both machines and found that they both d/l about 7000+k and 512 K upload
which is fine. However, I then switched the computers back to their original
position as we need the vista machine where it is currently located and it
again runs very slowly. It takes about 5 minutes for the avg web page to
load if it does at all, the same for email. Some other details I left out
yesterday is that I am connected to the internet through a Motorola 5100
broadband modem and the router is a Linksys befsr41 ver 2.1. I want to thank
you for your taking the time to help me with this issue. Thanks, Fiery
> > to
> > up
> > file
> > that
> > let
Wired network lag spikes Vista networking & sharing
USB (Wired) Network Card? Network & Sharing
Wired Network, but only wireless option shows in network setup Vista networking & sharing
Setting up a wired network to an already created wireless network Vista General
Problems switching wireless and wired network connections Vista networking & sharing
