Thanx for the response Charlie, but the same thing works under XP 32 and XP
64 bit version I have tried all version. Same cable same router it works.
Only when its under Vista Environment it doesn't work. And I see the
connectivity meaning the lights turn on both on the laptop and on the router
showing that there is some thing linking but nothing further.
I am suspecting two things:
1- The drivers are not the right ones, therefore it has problem running.
2- The Vista has TCP/IPv4 and TCP/IPv6 Protocols that either requires
special settings or specific cables. Generic cables won't work (i guess).
Please help, I am still looking.......
"Charlie" wrote:
> Could be a hardware problem.
> "DevLoy" <DevLoy@xxxxxx> wrote in message
> news:A3308160-8B09-42B8-B230-D97F4754DE3C@xxxxxx
> > Hi,
> > I have Acer Ferrari 5000. I have recently installed Vista Ultimate 64bit
> > on
> > it. Everything seems to work fine except the Ethernet. Vista installed the
> > drivers for the "Broadcom Gigabit Ethernet".
> > The diagnosis says "A Cable is not plugged into ethernet adapter". I am
> > using same cable, same router and everything and it works like a charm on
> > XP
> > 32 and 64 bit. I have tried to reinstall the drivers for the Ethernet, no
> > change.
> > The yellow light on the side of the Jack lights up and so does the light
> > on
> > the Router, that shows the cable is connected, but for some reason the
> > connection is not made. I am using USB router to connect to the internet
> > instead.
> > PLEASE HELP, I have been searching online for quite long, no answers.
> > Thanx >
