| | Vista & XP Home Wireless Network Connection Please Help! I am trying to connect my Vista home basic wireless to my established XP home wireless network. I can see the network but it will not connect. I have checked the settings on Vista for file and print sharing and it is allowed. I have also checked the correct password is being used on the network. It is set to automatically connect. It is set to use WEP encryption. Any suggestions greatly appreciated! Thanks, Terry |
| | Re: Vista & XP Home Wireless Network Connection Please Help! Make sure you have assigned permission in the Security tab. Or this search result may help. Vista Permission IssuesCan't access Vista because of password protection Can't access Vista C because of no permission in Security · Can't Reading\Writing to External Hard Drive ... www.chicagotech.net/vista/vistapermission.htm -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Terry1302" <Terry1302@xxxxxx> wrote in message news:451D8E2B-0CA8-484B-8D82-90C80B65C80F@xxxxxx Quote: >I am trying to connect my Vista home basic wireless to my established XP >home > wireless network. I can see the network but it will not connect. I have > checked the settings on Vista for file and print sharing and it is > allowed. I > have also checked the correct password is being used on the network. It is > set to automatically connect. It is set to use WEP encryption. Any > suggestions greatly appreciated! > > Thanks, > Terry |
| | Re: Vista & XP Home Wireless Network Connection Please Help! I am not sure which security tab you are refering to. Under the wireless network properties security tab I have security type open - encryption type wep - and the security key entered. In the windows security center I am using norton's firewall and all other items are on. "Robert L. (MS-MVP)" wrote: Quote: > Make sure you have assigned permission in the Security tab. Or this search > result may help. > > Vista Permission IssuesCan't access Vista because of password protection > Can't access Vista C because of no permission in Security · Can't > Reading\Writing to External Hard Drive ... > www.chicagotech.net/vista/vistapermission.htm > > > -- > Bob Lin, MS-MVP, MCSE & CNE > Networking, Internet, Routing, VPN Troubleshooting on > http://www.ChicagoTech.net > How to Setup Windows, Network, VPN & Remote Access on > http://www.HowToNetworking.com > > > "Terry1302" <Terry1302@xxxxxx> wrote in message > news:451D8E2B-0CA8-484B-8D82-90C80B65C80F@xxxxxx Quote: > >I am trying to connect my Vista home basic wireless to my established XP > >home > > wireless network. I can see the network but it will not connect. I have > > checked the settings on Vista for file and print sharing and it is > > allowed. I > > have also checked the correct password is being used on the network. It is > > set to automatically connect. It is set to use WEP encryption. Any > > suggestions greatly appreciated! > > > > Thanks, > > Terry > |
| | Re: Vista & XP Home Wireless Network Connection Please Help! The link should have many cases. Basically, you open the properties of the shared folder and select Security tab. -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Terry1302" <Terry1302@xxxxxx> wrote in message news:E951D7AE-170A-450D-A6D0-EED024D1F044@xxxxxx Quote: >I am not sure which security tab you are refering to. > > Under the wireless network properties security tab I have security type > open > - encryption type wep - and the security key entered. > > In the windows security center I am using norton's firewall and all other > items are on. > > "Robert L. (MS-MVP)" wrote: > Quote: >> Make sure you have assigned permission in the Security tab. Or this >> search >> result may help. >> >> Vista Permission IssuesCan't access Vista because of password protection >> Can't access Vista C because of no permission in Security · Can't >> Reading\Writing to External Hard Drive ... >> www.chicagotech.net/vista/vistapermission.htm >> >> >> -- >> Bob Lin, MS-MVP, MCSE & CNE >> Networking, Internet, Routing, VPN Troubleshooting on >> http://www.ChicagoTech.net >> How to Setup Windows, Network, VPN & Remote Access on >> http://www.HowToNetworking.com >> >> >> "Terry1302" <Terry1302@xxxxxx> wrote in message >> news:451D8E2B-0CA8-484B-8D82-90C80B65C80F@xxxxxx Quote: >> >I am trying to connect my Vista home basic wireless to my established XP >> >home >> > wireless network. I can see the network but it will not connect. I have >> > checked the settings on Vista for file and print sharing and it is >> > allowed. I >> > have also checked the correct password is being used on the network. It >> > is >> > set to automatically connect. It is set to use WEP encryption. Any >> > suggestions greatly appreciated! >> > >> > Thanks, >> > Terry >> |
| Vista says my home network wireless is a hidden network | Network & Sharing | |||
| Wireless connection cut - Wndows Vista Home Premium SP1 | Vista networking & sharing | |||
| Windows Vista Home Premium - Wireless connection problem | Vista networking & sharing | |||
| Home LAN adding a PC using vista on a wireless connection | Vista networking & sharing | |||
| Vista - Wireless network connection | Vista hardware & devices | |||
