Vista - I have a problem with my network location
Old 01-13-2008   #1 (permalink)
lunarfall
my network location on vista home laptop stays where it is but my computer
with xp's home network location doesnt appear in the vista network and i get
this error when trying to access my xp computer on the network with my vista
laptop. however, when ever i connect my xp computer to my vista laptop with
an ethernet cable and i do network set up wizard on the xp computer it
temperarily connects to my network location but than when i unplug it after a
while the network location on the xp computer disappears. both computers are
in the same workgroup and can be seen. all i need to do is keep the xp
computer in the same network location as my vista laptop so i can print
through the workgroup.
Old 01-13-2008   #2 (permalink)
lunarfall
RE: I have a problem with my network location
now i cant get the network going with the ethernet cable and my xp computer
can see my vista laptop! help!
Old 01-13-2008   #3 (permalink)
lunarfall
"can" is actually "cant" sorry
Old 01-13-2008   #4 (permalink)
Robert L. \(MS-MVP\)
Re: I have a problem with my network location
Can you ping each other by IP? Or this search result may help.
Vista sharing issuesSolved: Vista sharing - Access denied ... To share a
folder, there are two places, you need to assign permission. sharing and
security tabs. ...
www.chicagotech.net/vista/vistasharing.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"lunarfall" <lunarfall@xxxxxx> wrote in message
news:17514320-7548-4ECB-8658-B4523A4E4D7F@xxxxxx
> get
> vista
> with
> after a
> are
Old 01-13-2008   #5 (permalink)
lunarfall
yes i can ping and what i forgot to mention was the error details. everything
works fine when both computers are on the network its just that i need to
keep my xp on my network. my vista laptop stays on the network just fine for
some reason its the xp computer thats giving me the problem. when ever i try
to access the xp computer i get this details- error code: 80070035 the
network path cannot be found. if i solve this issue and keep it solved i
should be able to print using shares again.
> security tabs. ...
> > get
> > vista
> > with
> > after a
> > are
Old 01-13-2008   #6 (permalink)
lunarfall
0x80070035 is the error code my fault
> > security tabs. ...
> > > get
> > > vista
> > > with
> > > after a
> > > are
Old 01-14-2008   #7 (permalink)
On the remote computer, do "net share" command and post back with the
result. Or you may want to check these posts.
Solved: error code 0x80070035 ...He receives Error Code 0x80070035 network
path not found. The problem is he types a wrong Ip address. It should be
10.0.0.11. ...
http://www.chicagotech.net/netforums...pic.php?p=2915 - Similar pages
chicagotech.net :: View topic - Cases: Vista networking
These are many causes regarding Error message 0x80070035. Try to
create the same username and the same password in all computers. Or check
the below post. ...
http://www.chicagotech.net/netforums...opic.php?t=356
news:B431E950-1306-40C6-B3AB-73958A4B7E1F@xxxxxx
> "lunarfall" wrote:
>> everything
>> for
>> try
>> > a
>> > and
>> > security tabs. ...
>> > > computer
>> > > and i
>> > > get
>> > > my
>> > > vista
>> > > laptop
>> > > with
>> > > it
>> > > after a
>> > > computers
>> > > are
>> > > xp
>> > > print
Old 08-08-2009   #8 (permalink)
roger4man
I have had similar intermittent problems. I finally discovered the
problem was in my Belkin gateway. Even though I had automatic update on
the gateway/router, it was not up to date. The new firmware fixes
several problems including the one that incorrectly indicates the
firmware is up to date. With the new firmware, the problem has almost
completely disappeared. Once in a while, one or more of the computers on
the network "loses" the network but can still see and update network
files. As soon as I reboot the gateway, the problem goes away. So, I
suggest you try rebooting the gateway is you Belkin/Cisco gateway of
router. If not, try it anyway, it's quick to do and may be the
unsuspected cause.
The latest Belkin firmware is on downloadable from their site
roger4man
roger4man's Profile: http://forums.techarena.in/members/122954.htm
View this thread: http://forums.techarena.in/windows-v...ork/891942.htm
Can't access network location. Network & Sharing
Add a Network Location Vista General
Add new network location Vista networking & sharing
Deleting a Network Location Vista networking & sharing
How do I add a network location Vista networking & sharing
