Vista - Problem with Axis Media Control
Old 01-20-2008   #1 (permalink)
il barbi
In order to see a webcam I'm prompted to download ActiveX Axis Media
Control, now I download and install it but then Vista says it is not able to
run it because of the security settings. I tried to lower the level of
security to the bottom (namely Medium) with no result, then I tried to
activate all parameters relative to ActiveX controls but nothing changed
someone can help?
il barbi
Axis & Allies Vista problem. Vista Games
ActiveX Installer Service (AxIS) problem Vista General
Strange error msgs and "Problem caused by AXIS Media Control" Vista General
The AXIS Media Control, which enables you to view live image streams in Microsoft Internet Explorer, could not be registered on your computer. Vista security
MS - AXIS Media Vista General
