Vista - Vista 64 & 32 Slow wired LAN connection
Old 01-24-2008   #1 (permalink)
Scious
have a home network. Vista 32 ultimate and just installed vista 64 on a new
machine.
I have never transferred files between the computers much before but have
needed to transfer about 500gb to the new computer (vista 32 - vista 64).
However the transfer rate is under 10MB/sec which is actually pretty bloody
slow. It seems to be limited to 10 MB/sec.
The network goes through a router and is all cat5. The router is billion
bipac 7404VGP
The network adapters are on the motherboards - both gigabyte GA-P35-DS3P.
I have Unchecked "Remote Differential Compression" on both computer.
Any idea why so slow?
Old 01-25-2008   #2 (permalink)
Robert L. \(MS-MVP\)
Re: Vista 64 & 32 Slow wired LAN connection
You may want to disable auto-tuning. this how to may help.
Vista IPCONFIG and Network SettingsHow to disable Auto-tuning on Windows
Vista How to disable TCP/IPv6 How to remove IPv6 and Tunnel completely on
Vista How to disable ICS public connection ...
www.howtonetworking.com/vista/vistaipconfig.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"Scious" <Scious@xxxxxx> wrote in message
news:731D4DBA-1FC3-496D-ABB8-439043D69C98@xxxxxx
> new
> machine.
> bloody
> bipac 7404VGP
Vista Ultimate + Wired Connection - LOCAL ONLY on network change Vista networking & sharing
Lockups with wired connection Vista General
Vista laptop locks up with wired internet connection Vista General
Why can my wired Vista connection not see my wireless network setu Vista networking & sharing
Wired nor wireless connection available Vista networking & sharing
