Vista - Wireless NO - Wired Yes
Old 01-28-2008   #1 (permalink)
Bikini Browser
Hello...
I have two computers. The Windows XP Professional is wired directly to my 5
port SpeedTouch 780 10/100mb switch. The Vista Home Premium is a laptop
and is wireless connected to the same SpeedTouch 780 DSL Router.
Both computers can see each other on the network. I can browse all the
allowed folders on the Sony Vaio Vista Machine
**** but I cannot browse the folders on the XP machine from the Vista
machine. *** I CAN open the folders but I cannot copy files and if there are
a lot of folders, VISTA will sit there and hang while the progress bar
progresses and finally the Vista machine will kick back an error message
saying that Windows Explorer has quit with no explanation.
HOWEVER, IF I disconnect the Vista wireless connection, and I cable it, to
the same SpeedTouch 780 switch, THEN I CAN browse my folders on the XP
machine and EVERYTHING works like it is supposed to.
I have turned off the firewall and disabled anti virus on both machines.
What can I do to troubleshoot this problem?
And DOES ANYONE have a tech support phone number for SpeedTouch 780 DSL
Routers?
Dale
Old 01-29-2008   #2 (permalink)
PhilBiker
RE: Wireless NO - Wired Yes
Sorry I can't help, but I feel your pain. Home networking under XP is a
mess. I had similar problems and I fixed everything by replacing the XP
machine with a Vista one, and networking is slick as snot now. Sorry, but
networking is one of the major things that is better handled in Vista than XP.
-Phil
"Bikini Browser" wrote:
Quote:
> Hello...
> Routers?
> Dale
Old 01-29-2008   #3 (permalink)
Robert L. \(MS-MVP\)
Re: Wireless NO - Wired Yes
Try to disable IPv6 on the wireless first.
Vista How toHow to disable TCP/IPv6 · How to Disconnect Vista VPN connection
· How to disable ICS public connection ... How to disable Vista firewall
using Group Policy ...
www.howtonetworking.com/vista/vista.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"Bikini Browser" <delete.bikini.this.browser@xxxxxx> wrote in message
news:uXp%23j7iYIHA.5984@xxxxxx
Quote:
> Hello...
> 5 port SpeedTouch 780 10/100mb switch. The Vista Home Premium is a
> laptop and is wireless connected to the same SpeedTouch 780 DSL Router.
> are a lot of folders, VISTA will sit there and hang while the progress bar
> Routers?
> Dale
Old 01-29-2008   #4 (permalink)
Phillip Windell
"Gordon" <gbplinux@xxxxxx> wrote in message
news:Ov$QceoYIHA.4476@xxxxxx
Quote:
> "PhilBiker" <PhilBiker@xxxxxx> wrote in message
> news:4B79F939-81F3-4BDA-AFE5-4FC880E493D2@xxxxxx
>> but
>> than XP.
> Well I've never had ANY problem either networking or sharing files and
> folders on my XP network....and the setup was dead easy as well...always
> has been....
Same here. In fact it is Vista that I have all the problems with. Just
simple file copies between shares with Vista has always been a disaster. It
was easier to use a thumb drive or external USB drive and "sneeker-net" it
with Vista rather than mess with network copying.
Copying between XP machines was always fine.
Phillip Windell
www.wandtv.com
The views expressed, are my own and not those of my employer, or Microsoft,
or anyone else associated with me, including my cats.
wireless or wired Network & Sharing
Wired vs. Wireless Vista General
wired vs. wireless Network & Sharing
Wireless NO - Wired Yes Vista General
Vista+XP+Wired+Wireless Vista networking & sharing
