Using a Wireless Ethernet bridge with Vista
  1. #1
    Andy1L Guest
    I just upgraded to Vista Business on my laptop and I can't get it to connect
    to the internet using my Netgear Wireless Ethernet Bridge.
    The Network Identification process identifies the wired LAN and the wireless
    network, tells me I'm connected to multiple networks and only grants me Local
    access. I can connect to LAN devices on the other end of the bridge but it
    won't connect outside of my subnet.
    I have an XP desktop machine that uses the same bridge to connect to the DSL
    router downstairs and it works fine. The laptop also worked fine when it was
    running XP.
    Any one got any ideas?
  2. #2
    Tom Godzone Guest
    RE: Using a Wireless Ethernet bridge with Vista
    Hi
    I have similar problem with Vista (Ultimate), XP and Netgear. Both machines
    connect fine to my broadband modem and the XP connects fine through the
    Netgear WPN824v2. But when i connect the Vista machine either into the
    Netgear (with or without the XP machine connected) the interconnect
    connection on both machines appears to drop every 15-30 mins and takes 5 mins
    to recover.
    I have spent many hours on the Netgear support line but the best they could
    do in the end was swap out the router. Unfortunately the new one has the
    same problem. My previous Linksys router displayed similar behaviour.
    Conclusion - there is something odd happening with Vista?
    HELP too!
    Tom
    Tom Godzone
    "Andy1L" wrote:
    > Hi,
    > running XP.
  3. #3
    Barb Bowman Guest
    Re: Using a Wireless Ethernet bridge with Vista
    please post the text output of ipconfig /all
    http://digitalmediaphile.wordpress.c...t-text-output/
    does the netgear device have the latest firmware?
    On Fri, 8 Feb 2008 00:47:00 -0800, Tom Godzone
    <tomgodzone@xxxxxx> wrote:
    >Hi
    >to recover.
    >HELP too!
    >Tom
    Barb Bowman
    MS-MVP
    http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
    http://blogs.digitalmediaphile.com/barb/
  4. #4
    Barb Bowman Guest
    On Fri, 8 Feb 2008 00:25:00 -0800, Andy1L
    <Andy1L@xxxxxx> wrote:
    >Hi,
    >running XP.
    Barb Bowman
    MS-MVP
  5. #5
    Andy1L Guest
    Hi Barb,
    The Netgear has the latest firmware on it and here's the ipconfig info:
    Microsoft Windows [Version 6.0.6000]
    Copyright (c) 2006 Microsoft Corporation. All rights reserved.
    C:\Users\w112507>ipconfig /all
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : GBCWBWHLA7061
    Primary Dns Suffix . . . . . . . : energis.corp.energis.com
    Node Type . . . . . . . . . . . . : Hybrid
    IP Routing Enabled. . . . . . . . : No
    WINS Proxy Enabled. . . . . . . . : No
    DNS Suffix Search List. . . . . . : localnet
    Ethernet adapter Bluetooth Network Connection:
    Media State . . . . . . . . . . . : Media disconnected
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Bluetooth Device (Personal Area
    Network)
    Physical Address. . . . . . . . . : 00-1E-37-5B-F8-7D
    DHCP Enabled. . . . . . . . . . . : Yes
    Autoconfiguration Enabled . . . . : Yes
    Wireless LAN adapter Wireless Network Connection:
    Description . . . . . . . . . . . : Intel(R) PRO/Wireless 3945ABG Network
    Con
    nection
    Physical Address. . . . . . . . . : 00-1C-BF-7B-F8-7F
    Link-local IPv6 Address . . . . . : fe80::1ca6:59c7:f30e:abfb%9(Preferred)
    IPv4 Address. . . . . . . . . . . : 172.16.0.10(Preferred)
    Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Default Gateway . . . . . . . . . : 172.16.0.1
    DHCPv6 IAID . . . . . . . . . . . : 151002303
    DNS Servers . . . . . . . . . . . : 212.159.13.50
    212.159.13.49
    NetBIOS over Tcpip. . . . . . . . : Enabled
    Ethernet adapter Local Area Connection:
    Description . . . . . . . . . . . : Broadcom NetXtreme 57xx Gigabit
    Controlle
    r
    Physical Address. . . . . . . . . : 00-1C-23-21-32-21
    Tunnel adapter Local Area Connection* 9:
    isatap.{A9623A01-6A6D-49E0-B5A2-AFB0803DF
    8AC}
    Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    DHCP Enabled. . . . . . . . . . . : No
    Link-local IPv6 Address . . . . . : fe80::5efe:172.16.0.10%19(Preferred)
    212.159.13.49
    NetBIOS over Tcpip. . . . . . . . : Disabled
    Tunnel adapter Local Area Connection* 7:
    isatap.{634D01AE-E18D-49F3-99FE-DEECDEEC8
    5F2}
    Tunnel adapter Local Area Connection* 13:
    isatap.{72313D8D-894A-4A68-BD9C-72D3F66FD
    8C4}
    Tunnel adapter Local Area Connection* 10:
    Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
    Physical Address. . . . . . . . . : 02-00-54-55-4E-01
    Tunnel adapter Local Area Connection* 17:
    Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
    > >Hi,
    > >running XP.
    > Barb Bowman
    > MS-MVP
  6. #6
    Gerald Guest
    Hi
    Vista's TCP/IP stack has an ability to auto-tune the TCP/IP Window size - se
    > Windows Scaling.
    > Some routers and security appliances are not fully RFC 1323 compliant and
    > they cannot yet handle Vista's
    > stack.
    > Go to a command prompt and open it as an administrator,
    > Issue the following command and reboot your system, netsh int tcp set global
    > autotuninglevel=disabled
    > ***Observe to ensure that the command shell returns an OK - to indicate the
    > command executed as desired.
    > ****You may have to navigate to actually execute the command - e.g., to
    > netsh and then to interface and then
    > issue, the command.
    > *****Do contact your appliance and or router vendor and advise them of the
    > SPI limitation and compliance issue
    > ref RFC 1323.
    "Andy1L" wrote:
    > Hi,
    > running XP.
  7. #7
    Andy1L Guest
    Hi Gerald,
    Thanks very much for the suggestion. I've tried it and it still refuses to
    extend the connection from a "Local" to an "Internet".
    I don't have a DHCP server accessible to the laptop so I have an Alternate
    Configuration specified under the TCP/IPv4 settings. This is on the same
    network as the bridge and the access point. Not sure if this would make a
    difference or not?
    "Gerald" wrote:
    > Hi
    > > Windows Scaling.
    > > stack.
    > > issue, the command.
    > > ref RFC 1323.
    > "Andy1L" wrote:
    > > Hi,
    > > running XP.
  8. #8
    Gerald Guest
    Hi
    Do u get the same error using wired and/or wireless connection to Netgear?
    Try disabling IPv6 and setting static ip on IPv4.
    Check the router firmware level.
    Disable all firewalls and AV/Spyware temporarily.
    I am using a Netgear DG834G Wireless and dont have any problems.
    "Andy1L" wrote:
    > Hi Gerald,
    > difference or not?
    > "Gerald" wrote:
    > > Hi
    > > > Windows Scaling.
    > > > stack.
    > > > issue, the command.
    > > > ref RFC 1323.
    > > "Andy1L" wrote:
    > > > Hi,
    > > > running XP.
  9. #9
    Barb Bowman Guest
    please unbind IPv6
    http://digitalmediaphile.wordpress.c...windows-vista/
    also please check to see that you have the latest driver for the
    Intel wireless
    let us know if this resolves your problem
    On Fri, 8 Feb 2008 03:35:02 -0800, Andy1L
    >Hi Barb,
    >Network)
    >Con
    >nection
    > 212.159.13.49
    >Controlle
    >r
    >8AC}
    > 212.159.13.49
    >5F2}
    >8C4}
    >> >Hi,
    >> >running XP.
    >> Barb Bowman
    >> MS-MVP
    Barb Bowman
    MS-MVP
  10. #10
    Barb Bowman Guest
    Symmetric NATs can be a problem with Vista. And it looks like UPnP
    support is not all there. Unless they have a firmware fix in the
    latest firmware http://kbserver.netgear.com/products/WPN824v2.asp
    you may need to replace this router.
    On Fri, 8 Feb 2008 14:01:01 -0800, Tom Godzone
    >Thanks. I have unbound ipv6.
    >I ran the IDGEvaluators test (ver 1.3.5.0) and everything was supported by
    >the router except:
    >NAT Type - "The IGD's NAT type is SYMMETRIC"
    >UPnP Support - (strange because this is a feature of the router). Came up
    >with the following
    >"Adding a new port mapping to the IGD:
    >External Port : 61630
    >Internal Port : 61591
    >Protocol : UDP
    >Internal Client : 192.168.1.2
    >Enabled : TRUE
    >Description : removeme5
    >get_StaticPortMappingCollection returned null IStaticPortMappingCollection
    >Failed to add the new port mappings
    >5 new port mappings have been added successfully
    >Deleting all the test port mappings from the IGD"
    >This may indicate that it can't do more than 5.
    >The connection to the internet is still up and down like a yoyo.
    >Thanks
    >Tom
    Barb Bowman
    MS-MVP
Page 1 of 2 12 LastLast
Wireless but no ethernet bmeng Network & Sharing 4 29 Jul 2010
Access Point and Wireless Bridge?! tatz93 Network & Sharing 0 21 Jun 2009
ethernet problems in Windows Vista with wireless connection raymondvillain Vista General 18 05 Dec 2007
Vista ics wireless wired bridge canalrun Vista networking & sharing 1 24 Sep 2007
Vista/Win 2K Pro wireless & ethernet connection Dan Vista networking & sharing 0 21 Jun 2007
