| | Wireless Network Problem I'm running Windows XP on my main computer. I'm using it in combination with a Belkin DI 524 wireless router to serve my home network. Running Vista on my downstairs rig. When I try to access my network all I can get is the setup menu for the router. I have been reading the mail here for a couple of weeks and have tried all the suggested fixes. Nothing seems to work. Has anyone come across a similar situatiion using XP/Vista with a Belkin DI 524? Thanks... Scott.> |
| | Re: Wireless Network Problem The DI 524 is a dlink router. The IP address that you are seeing is 192.168.0.1. What happens (1) when you type hyyp://www.google.com in a broswer windows and (2) map a network share in Explorer? links http://support.dlink.com/products/vi...524%5FrevD#faq On Sun, 06 Aug 2006 14:54:54 GMT, Scott <shale132@hotmail.com> wrote: >I'm running Windows XP on my main computer. I'm using it in >combination with a Belkin DI 524 wireless router to serve my home >network. Running Vista on my downstairs rig. When I try to access my >network all I can get is the setup menu for the router. I have been >reading the mail here for a couple of weeks and have tried all the >suggested fixes. Nothing seems to work. Has anyone come across a >similar situatiion using XP/Vista with a Belkin DI 524? Thanks... >Scott.> |
| Problem with Network printer over wireless network. | Vista print fax & scan | |||
| Wireless Network Problem | Vista networking & sharing | |||
| Wireless network problem | Vista networking & sharing | |||
| Network Printer and Wireless Network problem | Vista installation & setup | |||
| Wireless network Problem | Vista networking & sharing | |||
