| | help with bluetooth! I have an Acer Laptop with Windows Vista Home Premium installed. Can anyone pls help me to find out how bluetooth works ? I am trying to understand how to connect it with other devices like my mobile (Nokia 6131) . Please notice that i am just now trying to understand what bluetooth means... thanx |
| Home Premium 32 bit | Re: help with bluetooth! Not all Acer laptops come with bluetooth, although they all come with a switch on the front (depending on model it should be next to the wirelss on/off slider switch). If you have bluetooth this should activate it, if not you will get a message on screen saying no bluetooth device. If this is the case you may be able to purchase an internal module to install (time consuming and not for the faint hearted), or the other option is to purchase a bluetooth dongle which plugs into a USB port. Check here for available internal modules: eBay.co.uk Shop - Oldegg Wireless Depot: Acer Bluetooth: Acer Laptop Internal Bluetooth 2.0 Module 8pin1.05cm S though it may be worth checking you have the neccessary socket first as it took me 2 hours to get to mine yesterday only to find it wasn't there. USB bluetooth dongles are available everywhere. |
| | Re: help with bluetooth! Do you have Bluetooth setup available in your control panel? "Veteran" <Veteran@xxxxxx> wrote in message news:07CE0DEE-187F-4CA1-BBB3-AC44425666F0@xxxxxx Quote: >I have an Acer Laptop with Windows Vista Home Premium installed. Can anyone > pls help me to find out how bluetooth works ? I am trying to understand > how > to connect it with other devices like my mobile (Nokia 6131) . Please > notice > that i am just now trying to understand what bluetooth means... thanx |
| | Re: help with bluetooth! JW no there is no Bluetooth setu up available in my control panel... "JW" wrote: Quote: > Do you have Bluetooth setup available in your control panel? > > "Veteran" <Veteran@xxxxxx> wrote in message > news:07CE0DEE-187F-4CA1-BBB3-AC44425666F0@xxxxxx Quote: > >I have an Acer Laptop with Windows Vista Home Premium installed. Can anyone > > pls help me to find out how bluetooth works ? I am trying to understand > > how > > to connect it with other devices like my mobile (Nokia 6131) . Please > > notice > > that i am just now trying to understand what bluetooth means... thanx |
| | Re: help with bluetooth! mb76 , thanks for all answers..yes there is switch on the front next to the wireless on/off slider switch, and when i push it ,i get a message on screen "no bluetooth device" If i undertood well , i might buy an internal module , or a USB bluetooth dongle...am i right? I really dont know if there is a socket in my laptop either.... thanks again for your advices.. "mb76" wrote: Quote: > > Not all Acer laptops come with bluetooth, although they all come with a > switch on the front (depending on model it should be next to the wirelss > on/off slider switch). > If you have bluetooth this should activate it, if not you will get a > message on screen saying no bluetooth device. > If this is the case you may be able to purchase an module to > install (time consuming and not for the faint hearted), or the other > option is to purchase a bluetooth dongle which plugs into a USB port. > Check here for available internal modules: 'eBay.co.uk Shop - Oldegg > Wireless Depot: Acer Bluetooth: Acer Laptop Internal Bluetooth 2.0 > Module 8pin1.05cm S' > (http://stores.ebay.co.uk/Oldegg-Wire...QQftidZ2QQtZkm) > though it may be worth checking you have the neccessary socket first as > it took me 2 hours to get to mine yesterday only to find it wasn't > there. > USB bluetooth dongles are available everywhere. > > > -- > mb76 > |
| | #6 (permalink) |
| Home Premium 32 bit | Re: help with bluetooth! In that case probably best to go with a USB dongle, it should come with all the neccessary software, there's plenty on eBay and they are now really cheap (mine cost me £3.65 including p&p) |
| Bluetooth software and drivers installed - but I don't have Bluetooth | Vista General | |||
| OBEX SyncLM Bluetooth Profile -> Bluetooth Peripheral Device not f | Vista hardware & devices | |||
| Bluetooth -- where is it?? | Vista General | |||
| Bluetooth | Vista hardware & devices | |||
