wireless connection to printer won't work
  1.    19 Feb 2008 #1
    ogorki500 Guest
    hello all
    i've spent the whole day trying to set up a wireless connection between
    a laptop running vista and a printer connected to a print server on a
    wireless router...
    the setup is:
    sony vaio laptop with vista business (not SP1)
    canon pixma ip4300 printer
    siemens gigaset SE551 router.
    The printer is connected to the USB port on the wireless router (and
    the wireless connection to the printer works fine with my old xp laptop
    ). The printer worked fine when plugged directly into the usb
    port on the vista laptop. So I set up a TCP/IP local port with the
    router's IP address (network print server, 1 printer) and assigned the
    printer to that port. It worked! - once. It printed a short document
    from notepad but sometime in the next few hours its status went to
    'offline' and it has since refused to print anything else. Print jobs
    appear to spool to the printer, come up in the print monitor window,
    etc, but it doesn't print - neither tiny things from notepad nor
    multipage word docs.
    SO far I have tried: rebooting everything lots of times; setting the
    printer to 'use printer online' in the admin prefs; disabling
    bidirectional support; disabling spooling (i.e. printing direct to
    printer - this just makes MS Word hang); making a persistent mapping of
    LPT1 to the printer w net use (a bit out of my depth there so hope I
    haven't stuffed anything up, i just got a bunch of system error 66's).
    I would really appreciate it if someone could help as i am being driven
    insane by this latest piece of vista c**p!!
    cheers
    Kate
    ogorki500
    Posted via http://www.vistaheads.com
  2.    19 Feb 2008 #2
    Charlie Guest
    Re: wireless connection to printer won't work
    Does your router's firmware support Vista?
    "ogorki500" <ogorki500.351as6@xxxxxx-mx.forums.vistaheads.com> wrote in message
    newsgorki500.351as6@xxxxxx-mx.forums.vistaheads.com...
    > hello all
    > wireless router...
    > the setup is:
    > cheers
    > Kate
    > ogorki500
  3.    19 Feb 2008 #3
    Jack \(MVP-Networking\). Guest
    Hi
    Try to uninstall the printer driver from Vista, and reinstall it through the
    Control Panel/Printers, Add a Printer, and choose network installation (Not
    USB).
    Jack (MVP-Networking).
    > hello all
    > wireless router...
    > the setup is:
    > cheers
    > Kate
    > ogorki500
  4.    19 Feb 2008 #4
    ogorki500 Guest
    > message
    > > hello all
    > between
    > > wireless router...
    > > the setup is:
    > laptop
    > usb
    > the
    > of
    > 66's).
    > driven
    > > cheers
    > > Kate
    > > ogorki500
    hi charlie
    yes i updated the router's firmware when the printer didn't work
    (sorry, forgot to mention that). the new firmware version is from mid
    last year so i guess vista will be supported.
    cheers
    kate
    ogorki500
  5.    19 Feb 2008 #5
    ogorki500 Guest
    hi jack
    ok, i just tried that. vista didn't find any networked printers when it
    did its search, and i couldn't browse to the printer: i could see the
    router, but not the printer attached to it. the only other option seemed
    to be to install it on a tcp/ip address again, and again, it didn't
    work.
    one new datapoint - when i restarted the laptop with something still in
    the print queue (on the old setup, i.e. as 'local printer' on a tcp/ip
    address) it sprang into life and printed 3 pages of an approx 20 page
    document. then it locked up again. a bit weird.
    ogorki500
Cannot find wireless networks/Cannot enable wireless connection
I'm running a Toshiba Satellite L300 with Windows Vista Home Premium x64 and a T6400 processor. I haven't had any connection problems untill now. The...
Network & Sharing
Can not connect to work/home wireless Internet connection.... HELP!!!
I am currently using an Acer Laptop. (The Bosses!!!) but it will not connect or even recognize any network (Windows Vista) The Atheros AR5005G...
Network & Sharing
DSL Connection & Wireless Router Will Not Work For Vista
I bought a Netgear wireless router today so I can hook up multiple computers in my home. Problem is that when I hook everything according to the...
Vista General
cisco vpn client doesnt work on wireless connection
I have downloaded the cisco vpn client v 5.0.03.0390. I have a secondary internet connection at work which is wireless. When my laptop saw this...
Vista networking & sharing
Shared Printer Does Not Work from Wireless Network Laptop
I have a Windows XP Home desktop connected to a printer via USB and, I have a Windows Vista Premium laptop connected through a wireless network....
getting a printer to work over wireless network
I am tring to get my epson cx5300 to print from my laptop the printer is conected to a desktop with xp running and the laptop and desktop are...
Vista General
Blackberry Dialup connection interupts wireless connection
I have my blackberry 7130e setup to be used as a tethered modem when I am not at home, or work. But when I am using wireless, I keep getting taken...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • Old server
    About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
