Limited Connectivity Issue with Wireless Router
  1. #1
    Martin Qian Guest
    Issue: Every time when boot up, the system CAN connect to the Wireless Router.
    But when using it for a while ( 10mins ~5 mins), the system pop up a message
    and shows Limited Connectivity and I lost the internet Connections...and the
    system shows that the Wireless Card ( intel 3945ABG) was disable.(which is
    not able to enabled unless reboot)
    The rest of my Laptop( XP SP2) just works Fine on the network 24X7 or if i
    connect the Vista laptop with Cable, it works just fine...this issue have
    already bugging me for month...
    I upgrade the drivers, Enable/Disable the IPv6, yet still in Vain... Any
    one got some ideas?
    list down is some general info of my networks
    ASDL Modem: Shanghai Bell
    Wireless Router: TP-link 541G+
    laptop: Dell Inspiron 1420 with Intel 3945ABG Wireless card.
    Driver&Patch: Vista Patch was automatic update to latest & I have manually
    update the wireless card driver to 2007.11.8 release from Intel.
  2. #2
    Robert L. \(MS-MVP\) Guest
    Re: Limited Connectivity Issue with Wireless Router
    Have you also upgraded the firmware for the router? Or check this search
    result,
    Vista Local Only and Limited or Not ConnectivityVista Limited connectivity ·
    Vista: Local only - no Internet issues · Vista - Local Connection Only ·
    Vista Wireless Limited or No Connectivity ...
    www.chicagotech.net/vista/vistalocalonly.htm
    Bob Lin, MS-MVP, MCSE & CNE
    http://www.ChicagoTech.net
    "Martin Qian" <Martin Qian@xxxxxx> wrote in message
    news:5C720E11-D181-47BB-9B40-E403FB8434A2@xxxxxx
    > Router.
    > message
    > the
    > one got some ideas?
Limited Connectivity Issue with Wireless Router problems?
Limited Connectivity to Wireless DarthNihilus Network & Sharing 3 21 Mar 2011
Limited Connectivity Issue posiden5665 Network & Sharing 1 12 Jun 2009
Limited Connectivity via Wireless. Synergy X26 Network & Sharing 2 25 May 2009
Limited or no connectivity when connecting to a wireless router The Unfortunate Soul Vista networking & sharing 5 16 Mar 2008
Wireless Limited or No Connectivity emoo Vista networking & sharing 3 27 Oct 2007
