Vista - Sharing printer and seeing omputer problems
Old 03-05-2008   #1 (permalink)
vtivos
I have a simple home network set up at the office. There are 4 computers and
3 printers all hardwired. The three printers are all on 1 computer(XP OS)
and connected via usb and serial/IEEE port.
The problem is the laptop (Vista OS) because that computer doesn't see all
the others and doesn't print even thought the printer is installed on the
computer. The Vista laptop also has Norton on it. I am guessing that it is
a firewall problem because Norton and Windows firewall are arguing with each
other but I have no idea how to fix this.
Old 03-05-2008   #2 (permalink)
Robert L. \(MS-MVP\)
Re: Sharing printer and seeing omputer problems
To confirm that, start the Vista with clean boot. Can you print?
Windows generalHow to run Windows OS with a clean boot · How to Run Windows
Safe Mode with Networking · How to setup DHCP for IP Phone How to sort
programs in Start ...
http://www.howtonetworking.com/Windo...owsgeneral.htm
Bob Lin, MS-MVP, MCSE & CNE
http://www.ChicagoTech.net
"vtivos" <vtivos@xxxxxx> wrote in message
news:BA841072-AAA4-4991-916E-784DBC5F0D28@xxxxxx
>and
> is
> each
Old 03-05-2008   #3 (permalink)
Mick Murphy
RE: Sharing printer and seeing omputer problems
You can go into Norton's firewall, and alter Exceptions
http://technet.microsoft.com/en-us/l.../bb727037.aspx
Have a read of the above link re Vista File and Printer Sharing.
Permissions/Share info is there as well.
If using Norton, McAfee, Trend Micro I.S., make sure file and printer
sharing is enabled in THEIR firewall.
1st thing to do is make sure that the Workgroup Name of ALL the computers is
the SAME.
In Vista Network and Sharing:
Network Discovery: ON (So it can see the other computers)
Network set to Private (Public is for hotspots, airports, etc)
File Sharing: ON
Public Folder Sharing: ON (Vista’s Public Folder is the same as XP’s Shared
Docs)
Password Protected: OFF (unless you want to set up identical usernames and
passwords on ALL computers in your Network) If you have it ON, you will be
asked for a username and password when you try to access a Vista computer
from an XP computer.
Also, run the XP’s Home Network File and Printer Sharing Wizard to include
Vista in your “New” Network, even if you had an XP Network set up prior to
adding a Vista computer to it.
Mick Murphy - Qld - Australia
Old 03-05-2008   #4 (permalink)
Arjan
I finaly solved the problem. I think a lot of people have to do this and then
it works.
All my settings were OK.
BUT!!! I went to my network in XP, chose PROPERTIES and unchecked the filter
of my 3th party Virusscan/Firewall.
Hope this will work for other people. If it works, let me know.
Arjan
Old 03-05-2008   #5 (permalink)
Thank you for sharing your experience with us.
"Arjan" <Arjan@xxxxxx> wrote in message
news:B0A0AC22-2B99-40F6-8360-AB8D4086A723@xxxxxx
>then
> it works.
> filter
> Arjan
> "vtivos" wrote:
>> and
>> OS)
>> all
>> is
>> each
Vista64 and Xp HP printer sharing problems Network & Sharing
Problems Sharing HP Printer in Vista Vista networking & sharing
Sharing Printer Problems Vista networking & sharing
Two separate (?) problems - printer and file sharing Vista networking & sharing
Problems sharing Printer or files. Vista networking & sharing
Designer Media Ltd
