| | XP Home Edition to Vista 32-bit Home Premium I'm trying to use the Vista Back Up utility to back up my notebook files to a Maxtor external hard drive installed on a desktop system running XP Home Edition SP2... I configured the maxtor drive to "shared on the network" read/write using the share tab on the drive properties... Vista can see the drive as network resource and can even copy files (notebook to maxtor and back), create folders, etc. When I try using the Vista Back Up utility, however, the wizard prompts for a user ID and Password... I enter my XP user ID and Password... and it tells me that it can't authenticate... I'm presuming there's some permission on the drive that needs set, but XP Home Edition doesn't give access to permissions the way XP Pro does... Is there any way to by-pass or set the permissions on XP so the Vista Back Up utility will work ? Cobian or some other back up utility would probably work but I'd prefer just using Vista... Any ideas folks ? thanks... m |
| | Re: XP Home Edition to Vista 32-bit Home Premium Hello, Windows XP Home Edition isn't supported as a backup location over a network because you cannot set permissions. You need to be running Windows XP Pro with Simple File Sharing disabled. For more details, please see: http://blogs.technet.com/filecab/arc...27/458871.aspx -- Eric Cross Microsoft MVP (Windows Networking) http://mvp.support.microsoft.com "timb" <mtguy26505@xxxxxx> wrote in message news:B4D5508F-420F-4884-A052-E735BD34E2A3@xxxxxx Quote: > I'm trying to use the Vista Back Up utility to back up my notebook files > to a Maxtor external hard drive installed on a desktop system running XP > Home Edition SP2... > > I configured the maxtor drive to "shared on the network" read/write using > the share tab on the drive properties... Vista can see the drive as > network resource and can even copy files (notebook to maxtor and back), > create folders, etc. > > When I try using the Vista Back Up utility, however, the wizard prompts > for a user ID and Password... I enter my XP user ID and Password... and it > tells me that it can't authenticate... I'm presuming there's some > permission on the drive that needs set, but XP Home Edition doesn't give > access to permissions the way XP Pro does... > > Is there any way to by-pass or set the permissions on XP so the Vista Back > Up utility will work ? Cobian or some other back up utility would > probably work but I'd prefer just using Vista... > > Any ideas folks ? thanks... m |
| | Re: XP Home Edition to Vista 32-bit Home Premium Thanks Eric... I upgarded the host to XP Pro... turned off simple file sharing and gave full contol permissions to "administrators", etc., and I get this error when trying to run the back up from the notebook (Vista Home) to the usb drive on the XP Pro box... "The network share could not be accessed for the following reason: No mapping between account names and security IDs was done. (0x800705534)" What am I missing or doing wrong ? "Eric Cross [MVP]" <ecross4@xxxxxx> wrote in message news:Oeuuf9fgIHA.4076@xxxxxx Quote: > Hello, > > Windows XP Home Edition isn't supported as a backup location over a > network because you cannot set permissions. You need to be running Windows > XP Pro with Simple File Sharing disabled. > > For more details, please see: > http://blogs.technet.com/filecab/arc...27/458871.aspx > > -- > Eric Cross > Microsoft MVP (Windows Networking) > http://mvp.support.microsoft.com > > > > "timb" <mtguy26505@xxxxxx> wrote in message > news:B4D5508F-420F-4884-A052-E735BD34E2A3@xxxxxx Quote: >> I'm trying to use the Vista Back Up utility to back up my notebook files >> to a Maxtor external hard drive installed on a desktop system running XP >> Home Edition SP2... >> >> I configured the maxtor drive to "shared on the network" read/write using >> the share tab on the drive properties... Vista can see the drive as >> network resource and can even copy files (notebook to maxtor and back), >> create folders, etc. >> >> When I try using the Vista Back Up utility, however, the wizard prompts >> for a user ID and Password... I enter my XP user ID and Password... and >> it tells me that it can't authenticate... I'm presuming there's some >> permission on the drive that needs set, but XP Home Edition doesn't give >> access to permissions the way XP Pro does... >> >> Is there any way to by-pass or set the permissions on XP so the Vista >> Back Up utility will work ? Cobian or some other back up utility would >> probably work but I'd prefer just using Vista... >> >> Any ideas folks ? thanks... m |
| | Re: XP Home Edition to Vista 32-bit Home Premium Does the account you are using the same on both computers with a password? -- Eric Cross Microsoft MVP (Windows Networking) http://mvp.support.microsoft.com "timb" <mtguy26505@xxxxxx> wrote in message news:77D7A68A-87A9-4EC5-BD0B-AA7C4A11E1BE@xxxxxx Quote: > Thanks Eric... > > I upgarded the host to XP Pro... turned off simple file sharing and gave > full contol permissions to "administrators", etc., and I get this error > when trying to run the back up from the notebook (Vista Home) to the usb > drive on the XP Pro box... > > "The network share could not be accessed for the following reason: > > No mapping between account names and security IDs was done. (0x800705534)" > > What am I missing or doing wrong ? > > "Eric Cross [MVP]" <ecross4@xxxxxx> wrote in message > news:Oeuuf9fgIHA.4076@xxxxxx Quote: >> Hello, >> >> Windows XP Home Edition isn't supported as a backup location over a >> network because you cannot set permissions. You need to be running >> Windows XP Pro with Simple File Sharing disabled. >> >> For more details, please see: >> http://blogs.technet.com/filecab/arc...27/458871.aspx >> >> -- >> Eric Cross >> Microsoft MVP (Windows Networking) >> http://mvp.support.microsoft.com >> >> >> >> "timb" <mtguy26505@xxxxxx> wrote in message >> news:B4D5508F-420F-4884-A052-E735BD34E2A3@xxxxxx Quote: >>> I'm trying to use the Vista Back Up utility to back up my notebook files >>> to a Maxtor external hard drive installed on a desktop system running XP >>> Home Edition SP2... >>> >>> I configured the maxtor drive to "shared on the network" read/write >>> using the share tab on the drive properties... Vista can see the drive >>> as network resource and can even copy files (notebook to maxtor and >>> back), create folders, etc. >>> >>> When I try using the Vista Back Up utility, however, the wizard prompts >>> for a user ID and Password... I enter my XP user ID and Password... and >>> it tells me that it can't authenticate... I'm presuming there's some >>> permission on the drive that needs set, but XP Home Edition doesn't give >>> access to permissions the way XP Pro does... >>> >>> Is there any way to by-pass or set the permissions on XP so the Vista >>> Back Up utility will work ? Cobian or some other back up utility would >>> probably work but I'd prefer just using Vista... >>> >>> Any ideas folks ? thanks... m |
| Windows Vista Home Premium and XP Home Edition | Vista installation & setup | |||
| Vista Home Premium Edition x64, take a look. | General Discussion | |||
| Sync Vista Home Premium with XP Home Edition | General Discussion | |||
| Remote Access from Vista Home Premium to Vista Home Premium and XP Home Edition | Network & Sharing | |||
| Vista Home premium edition | Vista General | |||
