| | Going Wired kills Wireless...have to change SSID to fix Using Vista Home Premium on a Compaq Presario V6210US and a Netgear N Router. I usually connect wirelessly, but wanted to connect to my XBox 360 for media center so I connected an ethernet cable to be directly into the router for faster connection. Now after several reboots and even deleting the SSID of my home router, it basically fails to connect. Says it's a low signal. The last time this happened, I changed the SSID and it fixed the problem completely. We have the same router at work and I plugged in once and I had to do it there too. My wife though with XP HOME has no problems at all. She doesn't have the slightest difficulty with the network whether wired or wireless. Anyone heard of this problem with Vista, the Compaq Presarios, or the Netgear Router? |
| | Re: Going Wired kills Wireless...have to change SSID to fix Hi I am sorry but your explanation to what you are doing, and how you are connecting the systems is Not clear. There is No relations between SSID and wire connections. If your are complaining that your Wireless Compaq does not work after you disconnected the X-Box and any cables and returned to normal Network connections, then you should check the Wireless setting of your Compaq nothing should change in the Router if you connect or disconnect network Device to and from it. http://www.ezlan.net/wireless.html Otherwise explain precisely what and how is connected to what. Jack (MVP-Networking). "Russell Johnson" <RussellJohnson@xxxxxx> wrote in message news:C518F360-4515-44E3-8DB6-3D78358824A4@xxxxxx Quote: > Using Vista Home Premium on a Compaq Presario V6210US and a Netgear N > Router. > I usually connect wirelessly, but wanted to connect to my XBox 360 for > media > center so I connected an ethernet cable to be directly into the router for > faster connection. Now after several reboots and even deleting the SSID > of > my home router, it basically fails to connect. Says it's a low signal. > The > last time this happened, I changed the SSID and it fixed the problem > completely. We have the same router at work and I plugged in once and I > had > to do it there too. My wife though with XP HOME has no problems at all. > She > doesn't have the slightest difficulty with the network whether wired or > wireless. Anyone heard of this problem with Vista, the Compaq Presarios, > or > the Netgear Router? |
| change from wired to wireless not did well, I end up having to reb | Vista networking & sharing | |||
| Error connecting to a wireless network with disabled SSID | Vista networking & sharing | |||
| Broadcast SSID required to connect to wireless network - why ? | Vista General | |||
| Wireless doesn't connect if SSID is hidden | Vista General | |||
| Wireless connection to a non broadcasting SSID routed | Vista networking & sharing | |||
