Vista Logon problem in to 2000 Pro
  1. #1
    Ibrahim Guest
    Hi, I have a little workgroup. I have a printer server running 2000 Pro, 5
    PCs running XP, and 2 Laptops running Vista.
    I can print and access the files in the 2000 Pro server from any XP PC. From
    both Laptops running vista I can see all the computers in the workgroup, I
    can also see the files and use the printer of any PC running XP. The problem
    is between Vista and 2000 Pro. I can access files in the Vista Laptops from
    the 2000 Pro Server, but I can not see any shared folder or use any printer
    in the 2000 Pro Server from the Vista Laptops. Each time I try to connect to
    the 2000 Pro Server from the Vista laptops I get a logon dialog box; I
    defined in the 2000 Pro server the same users I have in the Vista laptops (I
    did't do so for the XP PCs and they work just fine) and no matter what user I
    use to logon (I try to use also the 2000 Pro administrator user) I always get
    a "Logon Unsucessful" error.
    The vista and 2000 Pro has the NetBUI on TCP/IP enabled.
    What can I do??
    Ibrahim
  2. #2
    Robert L. \(MS-MVP\) Guest
    Re: Vista Logon problem in to 2000 Pro
    try these command from the Vista:
    1. net view \\win2000ipaddtess.
    2. net view \\win2000hostname
    Do you receive any system errors?
    Bob Lin, MS-MVP, MCSE & CNE
    http://www.ChicagoTech.net
    "Ibrahim" <Ibrahim@xxxxxx> wrote in message
    news:5899E825-D22A-4A07-AFAD-2E012F53D99D@xxxxxx
    > From
    > problem
    > from
    > printer
    > to
    > (I
    > user I
    > get
    > What can I do??
    > Ibrahim
  3. #3
    Ibrahim Guest
    For both commands I get the following:
    The syntax of this command is:
    NET
    [ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP | HELPMSG |
    LOCALGROUP | PAUSE | PRINT | SESSION | SHARE | START | STATISTICS | STOP
    |TIME | USE | USER | VIEW]
    Ibrahim
    > > From
    > > problem
    > > from
    > > printer
    > > to
    > > (I
    > > user I
    > > get
    > > What can I do??
    > > Ibrahim
  4. #4
    Did you replace win2000ipaddress with the win 2000 IP address?
    news:EF7C711F-A0EC-40EA-97C4-EF6A2CB64937@xxxxxx
    > NET
    > Ibrahim
    >> > Pro, 5
    >> > From
    >> > workgroup, I
    >> > problem
    >> > from
    >> > printer
    >> > connect
    >> > to
    >> > laptops
    >> > (I
    >> > user I
    >> > always
    >> > get
    >> > What can I do??
    >> > Ibrahim
  5. #5
    Ibrahim Guest
    Yes, and the hostname with the computer name. I wrote the following:
    net view\\192.168.0.102 and net view\\Naa
    Ibrahim
    > > NET
    > > Ibrahim
    > >> > Pro, 5
    > >> > From
    > >> > workgroup, I
    > >> > problem
    > >> > from
    > >> > printer
    > >> > connect
    > >> > to
    > >> > laptops
    > >> > (I
    > >> > user I
    > >> > always
    > >> > get
    > >> > What can I do??
    > >> > Ibrahim
  6. #6
    You must give a space between "net view" "\\ip".
    news:4B0B5651-7BA8-41D0-997B-9E7AC38332EB@xxxxxx
    > Ibrahim
    >> > NET
    >> > HELPMSG |
    >> > STOP
    >> > Ibrahim
    >> >> > Pro, 5
    >> >> > PC.
    >> >> > From
    >> >> > workgroup, I
    >> >> > problem
    >> >> > Laptops
    >> >> > from
    >> >> > printer
    >> >> > connect
    >> >> > to
    >> >> > I
    >> >> > laptops
    >> >> > (I
    >> >> > what
    >> >> > user I
    >> >> > always
    >> >> > get
    >> >> > What can I do??
    >> >> > Ibrahim
  7. #7
    Ibrahim Guest
    Ok, I got and error, but i don't remember exactly which one, I will be back
    to you Monday morning; thanks a lot for your help
    Ibrahim
    > > Ibrahim
    > >> > NET
    > >> > HELPMSG |
    > >> > STOP
    > >> > Ibrahim
    > >> >> > Pro, 5
    > >> >> > PC.
    > >> >> > From
    > >> >> > workgroup, I
    > >> >> > problem
    > >> >> > Laptops
    > >> >> > from
    > >> >> > printer
    > >> >> > connect
    > >> >> > to
    > >> >> > I
    > >> >> > laptops
    > >> >> > (I
    > >> >> > what
    > >> >> > user I
    > >> >> > always
    > >> >> > get
    > >> >> > What can I do??
    > >> >> > Ibrahim
Vista Logon problem in to 2000 Pro problems?
Logon Problem between Vista and 2000 Pro Ibrahim Vista networking & sharing 2 18 Mar 2008
Outlook 2000 on Vista problem Jim Vista mail 3 06 Feb 2008
Vista only works with pre-Windows 2000 AD Logon name? Dewd Vista networking & sharing 2 12 Jan 2008
Vista Business Logon Unsuccessful on 2000 Domain Shared Folders Ezareth Vista networking & sharing 1 25 Oct 2007
2 computers in same workgroup -Vista and Win 2000 - Can't logon Angela Hey Vista networking & sharing 0 05 Oct 2007
