Vista - Wireless Network Connection Problems
Old 03-16-2008   #1 (permalink)
Trinity
Hi there,
I've noticed a few posts regarding network connections. Some occur
sporadically. My problem is whenenver I open the computer (I leave it on all
the time - I assume it goes into hibernation or sleep mode but don't know for
sure) it cannot find any wireless networks. We live in a subdivision where
almost every home has a wireless conncetion, I know there are approximately
20 out there because my other computers pick them up. In order to get
connection I have to restart the laptop---everytime this happens. It is very
frustrating.
Now, I am technically challenged and have no idea what is the cause or why
this is happening. I bought this laptop at the same time as another
(identical laptops), and the second does not experience this connection
problem. All settings are the same (I think) and I would really like my
daughter to be able to "pop the top" and have internet connection without
restarting.
Any suggestions?
Thanks!!
Old 03-16-2008   #2 (permalink)
Barb Bowman
Re: Wireless Network Connection Problems
if you right click the wireless icon in the system tray and select
Diagnose and Repair, do you reconnect?
change your power scheme to high performance. does this help?
do you have the latest drivers for your wireless card? do you have
the latest firmware for your router? (what exactly are you
connecting TO?)
please post the TEXT output of ipconfig /all as a reply.
http://digitalmediaphile.wordpress.c...t-text-output/
On Sun, 16 Mar 2008 09:02:00 -0700, Trinity
<Trinity@xxxxxx> wrote:
Quote:
>Hi there,
>frustrating.
>restarting.
>Any suggestions?
>Thanks!!
Barb Bowman
MS-MVP
http://www.microsoft.com/windowsxp/e...ts/bowman.mspx
http://blogs.digitalmediaphile.com/barb/
Old 01-20-2009   #3 (permalink)
windows 7 64 bit
I have the same problem. When I shut my laptop and come back, windows 7 sees no networks where there are always 4 or 5 running. Need to shut down and restart and sees all networks immediately.
I have done this and it does not reconnect.
I have tried and it does not help.
>connecting TO?)
I do have the latest drivers for wireless card and router. the router is a linksys wrt54g. I'm not sure that the router is all that important as ALL networks disappear, not just mine.
not sure i want to post my ip address to everyone on the web?
I am using Windows 7 Build 7000 and my PC is a Toshiba Satellite P305-S8842.
Losing wireless connection to specific wireless network Vista networking & sharing
Wireless Network Connection Network & Sharing
Wireless network establishs a public network connection Vista networking & sharing
wireless network connection Vista performance & maintenance
Vista Ultimate: Wireless network connection problems and slow internet access Vista networking & sharing
