Vista - LAN connection with SP1 not stable.
Old 03-19-2008   #1 (permalink)
Thorsten_de
Hallo together!
After install of Vista SP1 the LAN network connection is not stable
All 10-20 seconds the LAN network connection break down for 2 seconds!
And the orange LAN port led flicker!
My configuration:
-Vista Ultimate 32 with all updates.
-Bitdefender Internetsecurity 2008 with all updates.
-Asus P4C800 E Deluxe Mainboard
-Onboard Intel Pro1000CT network
-Intel Pentium4 3,06 Northwood
-3GB Ram
-ATI 2600XT
-Netgear GS608 Switch
After restore from a backup Vista without SP1 the network works
smoothly with 1000MBit
Has anybody an idee?
Best regards, Thorsten
Thorsten_de
Posted via http://www.vistaheads.com
Old 03-20-2008   #2 (permalink)
themajor100
Re: LAN connection with SP1 not stable.
On Mar 19, 11:59*am, Thorsten_de <Thorsten_de.36j...@xxxxxx-
mx.forums.vistaheads.com> wrote:
Quote:
> Hallo together!
> After install ofVistaSP1the LANnetworkconnection is not stable
> All 10-20 seconds the LANnetworkconnection break down for 2 seconds!
> My configuration:
> -VistaUltimate 32 with all updates.
> -OnboardIntelPro1000CTnetwork
> -IntelPentium4 3,06 Northwood
> -3GB Ram
> -ATI 2600XT
> After restore from a backupVistawithoutSP1thenetworkworks
> Thorsten_de
> Posted viahttp://www.vistaheads.com
You are not alone. I'm having the same issue.
My Configuration
- Windows Vista SP1 32 bit.
- Asus P4C800 E Deluxe Mother Board
- Intel 3.4 Ghz Pentium 4
- OnBoard Intel Pro1000CT NIC
- 1.5 GB RAM
- Nvidia GeForce 6800GT Video Card
- Dlink 1Gbit Switch (Don't remember the model).
- SoundBlaster Live
The problem only seems to manifest itself when I'm using Internet
Explorer. My other Internet applications run with no problems if IE
is closed.
Neither Asus nor Intel seem to have Vista drivers for this NIC. I
seem to remember having to install the XP drivers to get it to work.
I'm going to try re-installing the NIC drivers. If that fails I'm
going to try digging up my spare Netgear NIC over the weekend to see
if it corrects the problem.
-T
Old 03-21-2008   #3 (permalink)
Thorsten_de
Hello!
After 3 reinstalls I have solve the issue!
The Bitdefender Internet Security 2008 crashes the Intel pro1000CT
network
Now I use Norton internet security 2008 and all works smoothly
Best regards, Thorsten :-)
Thorsten_de
Old 03-21-2008   #4 (permalink)
themajor100
On Mar 21, 9:20*am, Thorsten_de <Thorsten_de.36m...@xxxxxx-
Quote:
> Hello!
> network
> Thorsten_de
Hmm... I'm not running BitDefender or Norton. Although reinstalling
the NIC drivers seems to have solved the problem for now. I'm
probably still going to install a Vista compliant NIC this weekend.
I'm glad you got your system running properly too.
-T
PC stable with 2GB, Unstable with 4GB? Overclocking & Cooling
vista 64 not stable with games Gaming
Internet Connection Not Stable Vista performance & maintenance
Stable drivers Drivers
Is Vista64 stable? What's your uptime? General Discussion
