| | Vista-2000 Pro Printer sharing problem Hi fellows, After an ultimate match between Vista and 2000 Pro, I finally could share files between the two computers. I can read and write the files in the 2000 Pro Host from the Vista client. The problem now is the printer sharing, the printer is shared with all the permissions enabled in the 2000 Pro PC; but I can not connect the Vista laptop to the printer in the 2000 Pro host. The communications, users, permissions, etc, etc are working good. I can use the printer from other XP and 2000 Pro machines in the workgroup but I can not use the printer from the Vista laptop; it just says it can not connect to the printer. What could it be??? Thanks in advance Ibrahim -- Ibrahim |
| | Re: Vista-2000 Pro Printer sharing problem You may try to create local printer first and then re-map it as network printer. Or this search result may help. Vista Print IssuesSolved: Vista print Error 0x00000866 Resolution: 1. Add a Local Printer and then create a new port pointing to the shared printer. ... www.chicagotech.net/vista/vistaprint.htm -- Bob Lin, MS-MVP, MCSE & CNE Networking, Internet, Routing, VPN Troubleshooting on http://www.ChicagoTech.net How to Setup Windows, Network, VPN & Remote Access on http://www.HowToNetworking.com "Ibrahim" <Ibrahim@xxxxxx> wrote in message news EB77AEC-6F60-4C18-A3D6-0668CC1E9973@xxxxxxQuote: > Hi fellows, > > After an ultimate match between Vista and 2000 Pro, I finally could share > files between the two computers. I can read and write the files in the > 2000 > Pro Host from the Vista client. The problem now is the printer sharing, > the > printer is shared with all the permissions enabled in the 2000 Pro PC; but > I > can not connect the Vista laptop to the printer in the 2000 Pro host. > > The communications, users, permissions, etc, etc are working good. I can > use > the printer from other XP and 2000 Pro machines in the workgroup but I can > not use the printer from the Vista laptop; it just says it can not connect > to > the printer. > > What could it be??? > > Thanks in advance > > Ibrahim > > -- > Ibrahim |
| | Re: Vista-2000 Pro Printer sharing problem On Mar 20, 5:29*am, Ibrahim <Ibra...@xxxxxx> wrote: Quote: > Hi fellows, > > After an ultimate match betweenVistaand2000Pro, I finally could share > files between the two computers. I can read and write the files in the2000ProHost from theVistaclient. The problem now is the printer sharing, the > printer is shared with all the permissions enabled in the2000ProPC; but I > can not connect theVistalaptop to the printer in the2000Prohost. > > The communications, users, permissions, etc, etc are working good. I can use > the printer from other XP and2000Promachines in the workgroup but I can > not use the printer from theVistalaptop; it just says it can not connect to > the printer. > > What could it be??? > > Thanks in advance > > Ibrahim > > -- > Ibrahim I face the problem of sharing files between a 2000 pro laptop & a vista home basics laptop. Can u share how did u get this to work? Tks, starfish |
| Vista/XP Printer Sharing Problem | Vista networking & sharing | |||
| Vista to Windows 2000 printer sharing | Vista networking & sharing | |||
| win 2000 sharing printer with vista | Vista networking & sharing | |||
| Vista x64 printer sharing problem | Vista General | |||
| Vista & XP Printer Sharing Problem | Vista networking & sharing | |||
