Vista - ICS problem with otherwise functioning network
Old 03-28-2008   #1 (permalink)
ZeroSP
Hi, Ive just had broadband connected to my house.
Currently I have a network consisting of four computers connected through an
internal switch on one of my computers in one of the bedrooms for ease of
cabling.
The computer with the broadband modem has been chosen as it is newest
and is closest to the telephone line socket. It has two network cards, one
connected to the modem and the other to the rest of the network.
Independantly, the network connections are running fine (all computers can
see each other and transfer data properly) and the internet connection is
working well for the computer connected directly to the modem.
The network is setup using Static IP Addresses 192.168.0.1-192.168.0.4 (With
0.1 being for the host) and the modem is connected using a different set of
IP addresses.
I have also set the internet connection sharing options according to what is
required on the microsoft website for both the internet host and clients.
I have both Norton Antivirus and Zonealarm activated on all computers but
have set them up to allow access to each other.
My problem therefore is, despite my broadband connection working on the one
computer, and my network connections working, I cannot get ICS to work.
Help would be appreciated
Mat
Old 03-28-2008   #2 (permalink)
Steve Winograd
Re: ICS problem with otherwise functioning network
On Fri, 28 Mar 2008 03:35:03 -0700, ZeroSP
>cabling.
>IP addresses.
>Mat
Do you use the free version of ZoneAlarm? That program, if running on
the host computer, can prevent the client computers from accessing the
Internet. To find out if that's the problem, enable the Windows
Firewall on the host, uninstall (don't just disable) ZoneAlarm on the
host, and reboot the host. BTW, the paid ZoneAlarm firewalls (Plus
and Pro) work OK with ICS on the host.
Are the clients properly configured? Their network connections'
TCP/IP properties should be:
IP Address: 192.168.0.x (1<x<255)
Subnet Mask: 255.255.255.0
Default Gateway: 192.168.0.1
DNS Server = 192.168.0.1 or your ISP's DNS server
Best Wishes,
Steve Winograd, MS-MVP (Windows Networking)
Please post any reply as a follow-up message in the news group
for everyone to see. I'm sorry, but I don't answer questions
addressed directly to me in E-mail or news groups.
Microsoft Most Valuable Professional Program
http://mvp.support.microsoft.com
Old 03-29-2008   #3 (permalink)
ZeroSP
> >cabling.
> >IP addresses.
> >Mat
> Best Wishes,
Thankyou Ive fixed it now.
The clients were properly configured, the problem was Zone Alarm as you
suggested. However through some experimentation, all I had to do was lower
the firewall setting on the internet connection from high to medium.
I hadnt thought of checking the firewall setting, as ICS was working with
the existing settings with my old dialup connection before broadband became
available in my area.
Thankyou very much
Old 03-29-2008   #4 (permalink)
Steve Winograd
On Fri, 28 Mar 2008 21:06:00 -0700, ZeroSP
>> >cabling.
>> >IP addresses.
>> >Mat
>Thankyou very much
You're welcome. I'm glad that my suggestion helped you solve the
problem.
So do I understand that you have the free version of ZoneAlarm and
made it work with ICS by just changing the firewall setting?
Is that level of firewall protection sufficient? I'd try a ShieldsUp!
full port scan at http://grc.com to see.
Best Wishes,
Old 03-30-2008   #5 (permalink)
ZeroSP
> >> >cabling.
> >> >IP addresses.
> >> >Mat
> >Thankyou very much
> problem.
> Best Wishes,
Thanks, I will try that.
Yes, I did have the free version of Zonealarm, but I made a mistake earlier,
I dont have Norton Antivirus on my computer I have Norton 360
Would both of them together along with the windows firewall be enough?
Old 03-31-2008   #6 (permalink)
Steve Winograd
On Sun, 30 Mar 2008 18:41:02 -0700, ZeroSP
>> >> >cabling.
>> >> >IP addresses.
>> >> >Mat
>> >Thankyou very much
>> problem.
You're welcome. Running more than one firewall can cause problems
with network and Internet access. Choose either ZoneAlarm, Norton
360's firewall, or Windows Firewall. Disable or un-install the other
two.
Best Wishes,
Old 05-28-2008   #7 (permalink)
ZeroSP
I tried shieldsup and the computers passed without a problem- 100%
> >> >> >cabling.
> >> >> >IP addresses.
> >> >> >Mat
> >> >Thankyou very much
> >> problem.
> two.
> Best Wishes,
Old 05-28-2008   #8 (permalink)
Steve Winograd
On Wed, 28 May 2008 01:32:00 -0700, ZeroSP
>> two.
That's good. Did you disable all but one firewall? Running more than
one firewall can interfere with your ability to access the Internet,
and there's no benefit to running more than one.
Best Wishes,
Vista Network Problem / Sharing / Computers not Showing on Network Vista networking & sharing
Home network has stopped functioning Vista networking & sharing
Strange network problem - Can't save in Office2007 on network driv Vista networking & sharing
mic is not functioning Vista hardware & devices
Network Card not functioning after Vista upgrade Vista installation & setup
