1.    25 Apr 2008 #1
    William-Singapore Guest
    reset proxy problem
    under windows vista ulitmate i configured a proxy manually via the netsh
    winhttp set proxy command and all was working fine through my proxy. However
    now that I have removed the proxy server I'm unable to go back to direct
    settings via the netsh winhttp reset proxy command. Everytime I execute the
    command I get an access denied(5) error.
    Any usefull hints to solve this problem? as this is now preventing me from
    obtaining any furhter windows updates.
  2.    25 Apr 2008 #2
    Robert L. \(MS-MVP\) Guest
    Re: reset proxy problem
    Error 5 is permission issue. Try to open the cmd run as administrator.
    Bob Lin, MS-MVP, MCSE & CNE
    http://www.ChicagoTech.net
    "William-Singapore" <William-Singapore@xxxxxx> wrote in
    message news:FBB46E0C-4CE8-48DF-A624-BF547B8E235D@xxxxxx
    > However
    > the
  3.    25 Apr 2008 #3
    Robert, I"m running the command as the administrator on this machine.
    so not sure what else I can do here.
    > > However
    > > the
LAN Reset to Proxy Server
I have an ethernet connection to the router, I do not use a proxy server yet the LAN settings keep resetting to a proxy server that does not exist. ...
Network & Sharing
Re-installation of RPC HTTP proxy feature leads to big problem in
SBS 2008, being the odd duck that it is, moves certain virtual directories from the Default Web Site to the SBS Web Applications site during...
SBS Server
Re: Screen Resolution Reset Problem
sfdgg gfhj wrote: <snip - answer to a dead question> You are replying to an over 14-month old thread. Next time, when using Egghead's...
Virtual PC
trying to reset my spell check but one little problem
I'm getting the same error message about the spell check but once I get to the part to mark English I cannot get my cursor to get to the "apply" box...
Vista mail
Power Settings reset problem
My computer has been resetting its power settings at random points, and it's getting annoying. I've had to put them back more than a dozen times in...
Vista performance & maintenance
Reset Vista Proxy in Command Line
Hi everyone! I changed my proxy in order to try to connect the Internet, but Msn Messenger, Windows Update and Windows Mail can no longer connect!...
Vista networking & sharing
Setting proxy credentials and proxy server details
Has anyone got any referece documentation on how to set the proxy credentials and set proxy server details in WCF proxies? Basically I want to do...
Indigo
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
